PWM consume high power near 300uA
I am using SDK15.3.0 and s132_nrf52_6.1.1_softdevice.  (nRF52832)
Getting higher current consumption (300uA) while using the PWM library. (https://infocenter.nordicsemi.com/topic/com.nordic.infocenter.sdk5.v15.3.0/pwm_example.html)
Also tried to generate using PPI, But the same result as PWM library.
I wonder when used a low-power PWM library and got 460uA. (https://infocenter.nordicsemi.com/topic/com.nordic.infocenter.sdk5.v15.3.0/low_power_pwm_example.html
200uA somewhat expected as per the datasheet, But is there any other way to generate PWM using low power? (<200uA)
Nirav Patel
     This is for the PWM peripheral, but as mentioned in the PS, it does not include GPIO, DMA current. I don't think clock current is part of this either. But PWM library and low_power_pwm_example does not use the PWM peripheral.
    What PWM frequency and duty cycle do you need ?
  • Thanks, Sigurd
    1kHz frequency and duty cycle 0 to 100%.
    PWM library uses timers so I doubt that it consumes power. (120uA max while using a timer at 16Mhz)
    Also used timers while generated PWM using PPI(custom logic). (300uA)
    Got the link to the case in which RTC used for PWM. But getting 120uA while using this.
    https://devzone.nordicsemi.com/f/nordic-q-a/58091/glitches-when-toggling-pin-with-rtc-ppi-gpiote-and-reading-rtc-s-counter
    Is there any other way except above to generate PWM but consumption shouldn't increase more than 20-30uA.
  • Sigurd,
    I got another code from the below link by using this ability to generate PWM using RTC with <30uA (Frequency 1kHz)
    https://devzone.nordicsemi.com/f/nordic-q-a/32673/current-consumption-rtc--ppi---gpiote-on-nrf52
    Did minor modification to generate PWM with different duty cycle (1 to 99%). Used COMPARE_1 to handle it.
    In between, I observed that sometimes getting inverted PWM output when changing CC value of COMPARE_1 to change duty cycle.
    Ex. Duty cycle change to 20%, with 20% duty cycle it must be HIGH for 20% and LOW for rest 80% but when the issue occurred it will be HIGH for 80% and LOW for 20%.
    May be issue occurred because the pin configured to do the TOGGLE operation.
    void gpiote_config(void)
        ret_code_t err_code = NRF_SUCCESS;
        nrf_drv_gpiote_out_config_t config = GPIOTE_CONFIG_OUT_TASK_TOGGLE(true);
        err_code = nrf_drv_gpiote_out_init(GPIO_OUTPUT_PIN_NUMBER, &config);
        nrf_drv_gpiote_out_task_enable(GPIO_OUTPUT_PIN_NUMBER);
    /** @brief Function for initializing the PPI peripheral.
    void ppi_init(void)
        uint32_t err_code = NRF_SUCCESS;
        err_code = nrf_drv_ppi_channel_alloc(&ppi_channel);
        err_code = nrf_drv_ppi_channel_assign(ppi_channel,
                                              nrf_rtc_event_address_get(rtc.p_reg, NRF_RTC_EVENT_COMPARE_0),
                                              nrf_drv_gpiote_out_task_addr_get(GPIO_OUTPUT_PIN_NUMBER));
        err_code = nrf_drv_ppi_channel_fork_assign(ppi_channel, nrf_rtc_task_address_get(rtc.p_reg, NRF_RTC_TASK_CLEAR));
    	/* Modification */
    	err_code = nrf_drv_ppi_channel_alloc(&ppi_channel2);
        err_code = nrf_drv_ppi_channel_assign(ppi_channel2,
                                              nrf_rtc_event_address_get(rtc.p_reg, NRF_RTC_EVENT_COMPARE_1),
                                              nrf_drv_gpiote_out_task_addr_get(_pwmPin));
    	/* END */
        // Enable both configured PPI channels
        err_code = nrf_drv_ppi_channel_enable(ppi_channel);
    	/* Modification */
    	err_code = nrf_drv_ppi_channel_enable(ppi_channel2);
    	/* END */
    Can we configure the pin to set high while CC_0 event and low when CC_1 compared?
    Like, configure the same pin in "NRFX_GPIOTE_CONFIG_OUT_TASK_LOW" and NRFX_GPIOTE_CONFIG_OUT_TASK_HIGH".
    In this way, I can fix the issue of an inverted waveform.
        nrf_drv_gpiote_out_config_t config = GPIOTE_CONFIG_OUT_TASK_HIGH;
    	nrf_drv_gpiote_out_config_t config1 = GPIOTE_CONFIG_OUT_TASK_LOW;
    	err_code = nrf_drv_gpiote_out_init(GPIO_OUTPUT_PIN_NUMBER, &config1);
    Is it possible?
    Nirav Patel
  • Is it possible?
    Yes. Try something like this:
     * Copyright (c) 2014 - 2021, Nordic Semiconductor ASA
     * All rights reserved.
    /** @file
     * @defgroup rtc_example_main main.c
     * @ingroup rtc_example
     * @brief Real Time Counter Example Application main file.
     * This file contains the source code for a sample application using the Real Time Counter (RTC).
    #include "nrf.h"
    #include "nrf_gpio.h"
    #include "nrf_drv_rtc.h"
    #include "nrf_drv_clock.h"
    #include "boards.h"
    #include "app_error.h"
    #include <stdint.h>
    #include <stdbool.h>
    #include "nrf_drv_gpiote.h"
    #include "nrf_drv_ppi.h"
    #define USE_PPI 1
    #define GPIO_OUTPUT_PIN_NUMBER 3
    // Set RTC2_ENABLED to 1 in sdk_config.h
    static nrf_drv_rtc_t rtc = NRF_DRV_RTC_INSTANCE(2); /**< Declaring an instance of nrf_drv_rtc for RTC2. */
    static nrf_ppi_channel_t ppi_channel;s
    static nrf_ppi_channel_t ppi_channel2;
    void rtc_event_handler(nrf_drv_rtc_int_type_t int_type)
        nrf_drv_rtc_disable(&rtc);
        nrf_drv_rtc_counter_clear(&rtc);
        nrf_drv_rtc_int_enable(&rtc, NRF_RTC_INT_COMPARE0_MASK);
        nrf_drv_rtc_enable(&rtc);
        nrf_gpio_pin_toggle(GPIO_OUTPUT_PIN_NUMBER);
    /** @brief Function starting the internal LFCLK XTAL oscillator.
    static void lfclk_config(void)
        ret_code_t err_code = nrf_drv_clock_init();
    void gpio_config(void)
        nrf_gpio_cfg_output(GPIO_OUTPUT_PIN_NUMBER);
    void ppi_init(void)
        	/* Modification */
    	/* END */
                err_code = nrf_drv_ppi_channel_fork_assign(ppi_channel2, nrf_rtc_task_address_get(rtc.p_reg, NRF_RTC_TASK_CLEAR));
        	/* Modification */
    	/* END */
    /** @brief Function initialization and configuration of RTC driver instance.
    static void rtc_config(void)
        uint32_t err_code;
        uint32_t compare_val = RTC_US_TO_TICKS(20000UL, RTC_DEFAULT_CONFIG_FREQUENCY);
        uint32_t compare_val2 = RTC_US_TO_TICKS(100000UL, RTC_DEFAULT_CONFIG_FREQUENCY);
        //Initialize RTC instance
        nrf_drv_rtc_config_t config = NRF_DRV_RTC_DEFAULT_CONFIG;
    #ifdef USE_PPI
        err_code = nrf_drv_rtc_init(&rtc, &config, NULL);
        //Set compare channel to trigger interrupt after COMPARE_COUNTERTIME seconds
        err_code = nrf_drv_rtc_cc_set(&rtc,0, compare_val, false);
        err_code = nrf_drv_rtc_cc_set(&rtc,1, compare_val2, false);
    #else
        err_code = nrf_drv_rtc_init(&rtc, &config, rtc_event_handler);
        err_code = nrf_drv_rtc_cc_set(&rtc,0, compare_val, true);
     * @brief Function for application main entry.
        lfclk_config();
        rtc_config();
    #ifdef USE_PPI
        gpiote_config();
        ppi_init();
    #else
        gpio_config();
        //Power on RTC instance
        while (true)
            __SEV();
            __WFE();
            __WFE();
