Thermostat cluster enable issue
Hi All,
I am developing product using nRF52840 and SDK nRF5_SDK_for_Thread_and_Zigbee_v3.0.0_d310e71.
This product is basically, using the Thermostat cluster and Zigbee protocol to communicate with the Zigbee gateway.
So, I referred light_bulb example and followed steps to enable "Thermostat cluster and attributes".
I have included the respective files also but I am unable to execute the below callback function case statement,
static zb_void_t zcl_device_cb(zb_uint8_t param)
    zb_uint8_t                       cluster_id;
    zb_uint8_t                       attr_id;
    zb_buf_t                       * p_buffer = ZB_BUF_FROM_REF(param);
    zb_zcl_device_callback_param_t * p_device_cb_param =
                     ZB_GET_BUF_PARAM(p_buffer, zb_zcl_device_callback_param_t);
    NRF_LOG_INFO("zcl_device_cb id %hd", p_device_cb_param->device_cb_id);
    /* Set default response value. */
    p_device_cb_param->status = RET_OK;
    switch (p_device_cb_param->device_cb_id)
        case ZB_ZCL_SET_ATTR_VALUE_CB_ID:
            cluster_id = p_device_cb_param->cb_param.set_attr_value_param.cluster_id;
            attr_id    = p_device_cb_param->cb_param.set_attr_value_param.attr_id;
            if (cluster_id == ZB_ZCL_CLUSTER_ID_THERMOSTAT)
                uint16_t value = p_device_cb_param->cb_param.set_attr_value_param.values.data16;
                NRF_LOG_INFO("thermostat local temperature: %d", value);
                if (attr_id == ZB_ZCL_ATTR_THERMOSTAT_LOCAL_TEMPERATURE_ID)
                    local_temperature_value(value);
                /* Other clusters can be processed here */
                NRF_LOG_INFO("Unhandled cluster attribute id: %d", cluster_id);
            p_device_cb_param->status = RET_ERROR;
    NRF_LOG_INFO("zcl_device_cb status: %hd", p_device_cb_param->status);
Also, I am attaching code for reference please let me know what else I forgot to enable the functions. It is urgent for me to solve this issue.
Radiator_nRF_v0.9.0.zip
And, with these attributes, for some of the commands, I need to implement custom attributes so if you share how to add custom attributes to this cluster.
Thanks in advance.
Rohit R
  • Hi Marte,
    I have compared .h files from both SDK 3.0 and SDK 4.1 both are same.
    Have you checked whether the problem can be with the manufacturer code, as it was previously?
    - yes manufacturer code is = 0x1037 it is same defined.
    - In SDK 3.0 I have kept ZB_ZCL_MANUF_CODE_INVALID in zb_custom_thermostat.h file. It worked here.
    - And in SDK 4.1 I have changed to as per your suggestion. Please find the attached .h file for the same.
    Still I see that attributes are not visible on GUI.
    zb_custom1_thermostat.h
    - On node descriptor on GUI I can see that Power source = "Mains". How to set this battery? I have checked API for set but couldn't found anyone.
    Thanks and Regards
    Rohit R
  • Hi Rohit,
     Did you compare both the cluster files and the zb_custom_thermostat file? What about main.c?
    Previously you were able to extend the thermostat attribute list with your custom attribute, and you were able to see it in the GUI. Have you made any other changes since that version besides adding more attributes to your attribute lists, both custom and not? Not just to the .h files, but the main.c file as well.
    I compared your latest zb_custom_thermostat file with the zb_custom_thermostat file I was sent by one of your colleagues previously. I cannot find any reason why the changes between the two should cause issues. Previously, there were only a few attributes in the thermostat attribute list, only local temperature, occupied heating setpoint and current setpoint. I do not know if the problem might be caused by specific attributes, by the number of attributes in the attribute list, or something else. Have you tried increasing the attribute list with just a few attributes at a time and testing with the GUI, to see when the problem arises, and to check if it is at a certain amount of attributes, or if there are specific attributes causing this? Since it did work previously you might be able to get some more information about what the problem can be doing this.
    It is also difficult to say what the problem might be by just looking at one file, as that does not give a complete picture of the project, and I am unable to test it.
    I do not know what options deCONZ has when it comes to debugging, as the attribute simply being grey does not help when trying to understand why the attribute is unsupported. When you send ZCL commands to the device, are you able to see the response from the device in deCONZ? If you send the Discover Attributes command, do you see the response? If so, are the attributes lacking in this response as well? Are you only able to send more general commands from somewhere in the program? For example, can you only read attributes using the "read" button above the attribute table, or are you able to send a Read Attributes command from somewhere where you can send ZCL commands? If you can, do you get any response when trying to send a Read Attributes command to one of the grey attributes?
     The power source attribute is part of the Basic cluster. Setting this attribute to ZB_ZCL_BASIC_POWER_SOURCE_BATTERY should fix this, but I see in your file zb_custom_thermostat.h that you have already defined THERMOSTAT_INIT_BASIC_POWER_SOURCE to be this. Have you tried reading this attribute to see what the value is?
    Marte
  • Hi Marte,
    Thank you for the response.
    Yes, I have compared all the files but I didn't see any change. Even I have followed the same steps in SDK3.0 to enable attributes and here I can see that whatever attributes I have extended are visible and able to edit also.
    But not possible in SDK 4.1. Attached is the code built in SDK 4.1. Hope this will help us to find reason.
    - Yes, I have done that but still it shows main power source only.
    0020.Radiator_nRF_v0.9.6.zip
    modified file, zb_zcl_thermostat.h file
    2148.zb_zcl_thermostat.h
    Thanks and Regards
    Rohit R
  • Hi Rohit,
    I have started looking into your latest project, but I have not been able to figure out the issue yet. All the commands work as expected, and I do not get any errors when testing.
    Have you tried debugging using some of the things I suggested in my last reply?
    Marte
  • Hi Marte,
    Thank you for the response and support.
    yes, I had compared both project as per my knowledge. But due to completion pressure we have decided to develop product using SDK 3.0 has we can see attribute access and edit is possible here. And when product in testing phase we will look into the issue with SDK 4.1.
    So, I have started degrading the code to SDK 3.0 and my development is in progress.
    I will inform you once if i get anything and you also let me know if you found the issue here.
    Along with this I need one more information regarding power management. As you know we are developing Radiator device using nRF52840 and this device is powered up using 2xAA batteries.
    Requirement of device is battery should last long for 2 year. It should in hibernation unless and until any interrupts.
    I have one GPIO interrupt and any Zigbee commands from gateway. If either of interrupt device it should wake up from sleep.
    Can you guide me what all things I should take care while implementing sleep mode. And I get maximum battery life.
    If you have any example with similar configuration it will help me to quick implementation.
    Let me know your feedback on this sleep configuration.
    Thanks and Regards
    Rohit R
