Thermostat cluster enable issue
Hi All,
I am developing product using nRF52840 and SDK nRF5_SDK_for_Thread_and_Zigbee_v3.0.0_d310e71.
This product is basically, using the Thermostat cluster and Zigbee protocol to communicate with the Zigbee gateway.
So, I referred light_bulb example and followed steps to enable "Thermostat cluster and attributes".
I have included the respective files also but I am unable to execute the below callback function case statement,
static zb_void_t zcl_device_cb(zb_uint8_t param)
    zb_uint8_t                       cluster_id;
    zb_uint8_t                       attr_id;
    zb_buf_t                       * p_buffer = ZB_BUF_FROM_REF(param);
    zb_zcl_device_callback_param_t * p_device_cb_param =
                     ZB_GET_BUF_PARAM(p_buffer, zb_zcl_device_callback_param_t);
    NRF_LOG_INFO("zcl_device_cb id %hd", p_device_cb_param->device_cb_id);
    /* Set default response value. */
    p_device_cb_param->status = RET_OK;
    switch (p_device_cb_param->device_cb_id)
        case ZB_ZCL_SET_ATTR_VALUE_CB_ID:
            cluster_id = p_device_cb_param->cb_param.set_attr_value_param.cluster_id;
            attr_id    = p_device_cb_param->cb_param.set_attr_value_param.attr_id;
            if (cluster_id == ZB_ZCL_CLUSTER_ID_THERMOSTAT)
                uint16_t value = p_device_cb_param->cb_param.set_attr_value_param.values.data16;
                NRF_LOG_INFO("thermostat local temperature: %d", value);
                if (attr_id == ZB_ZCL_ATTR_THERMOSTAT_LOCAL_TEMPERATURE_ID)
                    local_temperature_value(value);
                /* Other clusters can be processed here */
                NRF_LOG_INFO("Unhandled cluster attribute id: %d", cluster_id);
            p_device_cb_param->status = RET_ERROR;
    NRF_LOG_INFO("zcl_device_cb status: %hd", p_device_cb_param->status);
Also, I am attaching code for reference please let me know what else I forgot to enable the functions. It is urgent for me to solve this issue.
Radiator_nRF_v0.9.0.zip
And, with these attributes, for some of the commands, I need to implement custom attributes so if you share how to add custom attributes to this cluster.
Thanks in advance.
Rohit R
  • Hi Rohit,
    All the Zigbee examples in our SDK are by default power optimized such that the CPU enter low power mode in times of inactivity.
    If your device is an end device, you can use Sleepy End Device to reduce current consumption. You can see Power saving for ZED for more information. This is used in the light switch example in our SDK. With this, the CPU enter sleep mode when there is nothing happening on the stack, and the device will automatically wake up on an event, as well as waking up from time to time to ensure correct processing of the stack.
    In the projects I have received from you, your device has had the router role. Routers enter low power mode, instead of sleep mode, when the stack has nothing to do. You can for example use the weak function zb_osif_go_idle(), which can be found in external/zboss/osif/zb_nrf52_common.c. This functions is defined to check if the logger has anything to process, and if it does not, then the CPU goes idle. You can also redefine this function to check for other things or to do something else. An example of this is used in the light bulb example.
    Please make sure to do power consumption measurements. For more information you can check out this page.
    Marte
  • Hi Marte,
    Thank you so much for the details.
    - With reference to multi sensor example I have changed to end point role.
    - Okay, I will check the switch example. Is there any explanation regarding switch example work flow to understand sleep?.
    I will go through the links and If any unclear points i will get back to you.
    Thanks and Regards
    Rohit R
  • Hi Rohit,
    If you enable sleepy end device, then the signal ZB_COMMON_SIGNAL_CAN_SLEEP is generated when the device can be put to sleep. In the light switch example, sleepy end device is enabled by pressing Button 3 on the board while resetting the board. However, you can enable it by simply calling zb_set_rx_on_when_idle(ZB_FALSE) in main(), as in the multi sensor example.
    Since you are using SDK v3.0.0, which does not have the default signal handler in zigbee_helpers.c, you will have to handle the signal ZB_COMMON_SIGNAL_CAN_SLEEP in zboss_signal_handler(). You should call the function zb_sleep_now() to put the device to sleep when this signal is received. This is done in multiple examples in v3.0.0 already, such as the light switch and the multi sensor examples, so you can look at those to see how to do this.
    Marte
  • Hi Marte,
    Thank you for the response.
    - I saw the code, this means If button is pressed device will not go into sleep correct? or is it wake up from sleep when button pressed?
    - Means, only calling this function device will go to sleep correct? But when it wake up ? Is it wake up periodically or any other way?
    - Okay, I will enable this by referring both codes.
    My wake up mechanism should be.
    - If there is no activity or any data on UART  go to sleep.
    - Wake up if there is interrupt from GPIO or any UART data
    - Wake up if there is Zigbee command.
    Let me know your feedback.
    Thanks and Regards
    Rohit R
  • Hi Rohit,
     The button does not make the device go into sleep mode or wake up from sleep when it is pressed. What it does is to enable sleepy end device behavior. This is there so that the user can decide, when resetting the device, whether they want the behavior enabled or not. In the multi sensor example it is enabled from start, as zb_set_rx_on_when_idle(ZB_FALSE) is called in main() before the Zigbee stack is started. Light switch instead calls sleepy_device_setup(), which checks whether the button for enabling sleepy end device is pressed or not, and will enable the behavior if the button is pressed. Additionally, the button must be pressed while resetting the board. Pressing the button while the device is on will not affect the sleepy end device behavior.
     No, it will not go to sleep. As I explained in my previous reply and above, zb_set_rx_on_when_idle(ZB_FALSE) will not make it go to sleep, it will enable sleepy end device behavior. It will go to sleep when there is nothing to do and the signal ZB_COMMON_SIGNAL_CAN_SLEEP is generated. This happens when there is no immediate callback for execution and there is no outgoing packet on the MAC level. If there are any alarms in the queue, then the device will wake up when the first alarm is called. If there are no alarms in the queue, then the sleep duration is set to 10 seconds.
    You will not be able to use sleepy end device if you want your device to wake up if there is a Zigbee command. When using sleepy end device, the device will not receive messages while it is asleep, but will poll it's parent at intervals to see if there are any messages waiting for it.
    You can also change the sleep functionality if you do not want to use the default behavior by using the weak functions zb_osif_go_idle or zb_nrf52840_sleep. See Zigbee stack sleep routines for more information. This documentation is for v4.1.0, as the "Zigbee application helper functions" is not in the documentation for v3.0.0, but the weak functions exist in both versions.
    Please also see Power saving for ZED to get a clearer understanding of the power saving mechanisms for end devices in the SDK.
    Marte
