Thermostat cluster enable issue
Hi All,
I am developing product using nRF52840 and SDK nRF5_SDK_for_Thread_and_Zigbee_v3.0.0_d310e71.
This product is basically, using the Thermostat cluster and Zigbee protocol to communicate with the Zigbee gateway.
So, I referred light_bulb example and followed steps to enable "Thermostat cluster and attributes".
I have included the respective files also but I am unable to execute the below callback function case statement,
static zb_void_t zcl_device_cb(zb_uint8_t param)
    zb_uint8_t                       cluster_id;
    zb_uint8_t                       attr_id;
    zb_buf_t                       * p_buffer = ZB_BUF_FROM_REF(param);
    zb_zcl_device_callback_param_t * p_device_cb_param =
                     ZB_GET_BUF_PARAM(p_buffer, zb_zcl_device_callback_param_t);
    NRF_LOG_INFO("zcl_device_cb id %hd", p_device_cb_param->device_cb_id);
    /* Set default response value. */
    p_device_cb_param->status = RET_OK;
    switch (p_device_cb_param->device_cb_id)
        case ZB_ZCL_SET_ATTR_VALUE_CB_ID:
            cluster_id = p_device_cb_param->cb_param.set_attr_value_param.cluster_id;
            attr_id    = p_device_cb_param->cb_param.set_attr_value_param.attr_id;
            if (cluster_id == ZB_ZCL_CLUSTER_ID_THERMOSTAT)
                uint16_t value = p_device_cb_param->cb_param.set_attr_value_param.values.data16;
                NRF_LOG_INFO("thermostat local temperature: %d", value);
                if (attr_id == ZB_ZCL_ATTR_THERMOSTAT_LOCAL_TEMPERATURE_ID)
                    local_temperature_value(value);
                /* Other clusters can be processed here */
                NRF_LOG_INFO("Unhandled cluster attribute id: %d", cluster_id);
            p_device_cb_param->status = RET_ERROR;
    NRF_LOG_INFO("zcl_device_cb status: %hd", p_device_cb_param->status);
Also, I am attaching code for reference please let me know what else I forgot to enable the functions. It is urgent for me to solve this issue.
Radiator_nRF_v0.9.0.zip
And, with these attributes, for some of the commands, I need to implement custom attributes so if you share how to add custom attributes to this cluster.
Thanks in advance.
Rohit R
  • Hi Marte,
    Sorry for this inconvenience. I am not getting reply option to your latest feedback. I don't know what is wrong.
    And to last post reply -
    1. Yes, I have tried only current_setpoint_attribute() function also then also same problem. code line are not executing as marked in previous image.
    2. I tried your suggestion also but still the same problem. You find the attached image where i am not able to put break point.
    Should I share the code. but is same to last only thing is I have enabled more extended attributes.
    Rohit R
  • Hi Marte,
    Rohit R
  • Hi Marte,
    Rohit R
  • Hi Marte,
    Rohit R
  • Hi Marte,
    Rohit R
