I updated nRFConnect from 3.6.1 to 3.7.1 and it started to have intermittent issues with the following error:
Please try to disable the mass storage class on your j-link as instructed here link and see if it improves the reliability. I've seen this issue on some Windows systems even though only macOS and Linux are mentioned. I will check internally if others have reported the same after upgrading to v3.7.1 in the meantime.
Vidar
Hi Vidar,
Disabled the mass storage class/unplugged/plugged the device - got the same error on both versions of Jlink (6.44 and 7.54). Do you have any other ideas?
Thanks!
There doesn't appear to be any known stability issues introduced in the latest nRF connect release. Could you please try to quickly revert back to the the old 3.6.1 release to confirm that it still resolves the stability issue (i.e. confirm is not related to J-link updates, etc) ?
Vidar, I tested again in 3.6.1 and 3.7.1. It seems that MSDDisable command required some time to propagate - when I tested earlier I was getting the error, I unplugged and then plugged after a few seconds. Now, when I tested it I do not see the error with MS Disabled.
I enabled MSD again (MSDEnable) and it started having the same error in both versions of nRF Connect. After disabling MSD again and waiting a few min, the error is not showing on both.
Thus I believe now MSDDisable improves reliability.
That's great news, thanks for the update! Not sure if this is what happened here, but note that the MSDDisable procedure requires that you power cycle the board at the end for the change to go into effect.
