Hello All,
What is the minimum pulse width resolution for the nRF52840's PWM module?
johnwest
Hello All,
johnwest
I'm not quite sure what exactly you are asking for, so I'll just list the relevant timing specs:
Full specs: PWM — Pulse width modulation
16MHz clock gives 62.5 nSec minimum pulse width.
So, min pulse width is 1 / (base clock) - is that in the spec someplace?
No idea, but with a x1 divider each step is 1/16MHz; the 16MHz is fixed in stone (well, silicon), no way of changing that. To get 8MHz PWM at least 4 steps are required 0-1-0-1 as period (COUNTERTOP) cannot be less than 3. A COUNTERTOP value of 4 with the sequence 0-1-0-1 gives 8MHz PWM signal.
