NRF52840 and Installing SoftDevice SS340-SD-v6.1.1 ANT / BLE 5
I'm stuck with trying to install Nordic/ANT+ SoftDevice SS340-SD-v6.1.1 on the Adafruit Itsy Bitsy NRF52840.
Within nRF Connect - Programmer, I am getting the following error: "Unsupported device. The detected device could not be recognized as neither JLink device nor Nordic USB device."
Please help. Thanks.
  • Thanks Amanda!
    I've been able to order the very popular and often sold out J-Link mini edu. I am seeing it is compatible with the NRF52/Cortex M chips. There are SWDIO and SWCLK pads on the bottom of the board, then of course the available VRef/3V and Gnd pins, supposedly those are the only valid and needed connections on the J-Link's 10 pin SWD (the other 6 links, so I'm hoping Dupont terminals and a bit of soldering on the two small board pads will accomplish communication.
    The first project is for an indoor spin bike. With a gyro/accelerometer (MPU6050) and a quality ADC (HX711 or ADS1115) connected to a set of strain gauges in a wheatstone bridge circuit on a drivetrain component (crank arm, pedal spindle, chainring, or bottom bracket axle) one can measure cadence (RPM), speed, crank angle (phi), torque (bending/twisting moment, Newtons), and power (watts).  Then sending this data wirelessly to a Garmin Edge head unit or custom made smart phone app. Then after, ultimately make a similar one for outdoor, rugged mountain bike use. Maybe also learning to condense all of this into the smallest form fitting PCB/battery package later. This will provide much more fulfillment, customization, and learning than buying a commercial unit.
    Since the predominance of Garmin fitness products communicate using the ANT protocol, I was wanting to start there first. I have more investigation with understanding the latest updates with BLE and ANT+ (Smart, 5, mesh, network topology, concurrent connections, connection integrity, packet loss, transmission rate, range/power/gain, crypto, etc.). So with the latest and greatest S340 SoftDevice I should have plenty to 'chew' and can go in any direction with learning.
    Thanks for your help in getting me through this update hurdle.
    Happy to help. Don't hesitate to create a new support case if you have any issues with the development. We are always on Devzone with you. Slight smile
    -Amanda
  • I was able to install the S340 SoftDevice with nRF Connect-Programmer and the J-Link, however the board was no longer recognized in Arduino IDE. Is there a way to keep the ordinating Adafruit NRF52 Itsy Bitsy Express bootloader and just update the S340 SoftDevice?
  • I would suggest to use nRF Command Line Tools to execute "nrfjprog --program S340_SoftDevice.hex --sectorerase -r" command to program the S340 SoftDevice. The "--sectorerase" will on erase the targeted area instead of all the flash.
    -Amanda
  • Thanks Amanda,
    Can you help me with starting from scratch with the NRF52840 SoC on this board...
    I think the first few steps that are necessary is to simply achieve some tests with the S340 SoftDevice
    Having the J-Link now, through NRF Connect-Programmer I have erased the memory on the NRF52840 SOC and flashed it with Nordic's MBR/bootloader and the S340 SoftDevice. I have the Segger Embedded Studio IDE installed and would like to run any beginner sketch to test maybe a blinking LED (which is GPIO Pin #3) on the board. Can you help me with this first step in making sure the board accepted the flash update?
    Thanks.
