TIMER1 compare not triggered for CC=0x00
I am using a TIMER1 compare event to generate an interrupt. Generally the code all works fine, but I have noticed some strange behaviour when loading the CC register with 0x00. If the timer is allowed to run freely and overflow, then it is possible to generate a compare event when the timer rolls-over to 0. No problem there. But then I tried to limit the maximum timer count using;
NRF_TIMER1->SHORTS |= TIMER_SHORTS_COMPARE2_CLEAR_Enabled << TIMER_SHORTS_COMPARE2_CLEAR_Pos;
NRF_TIMER1->CC[2] = T1_TICKS_MAX;
My understanding is that this should cause the timer to reset to zero when it hits the value in CC2 (T1_TICKS_MAX). However, when I do this I no longer get any compare events generated for CC=0x00. Any other CC value less than or equal to T1_TICKS_MAX works fine.
This seems a bit unexpected to me. Is this normal behaviour? Or do I perhaps have a bug in my code somewhere?
