Using UART1 for the serial communication
I am using nRF5340DK and would like to send and receive data to computer via UART1 and pins "TX", "RX", "CTS" and "RTS" using USB TO RS232 SERIAL CONVERTER.
This way I would keep UART0 for logging.
But I can't receive or send data via UART1.
I'm using the Segger IDE and the Peripheral_UART for the first nRF5340 DK board and the Central_UART example for the second board.
Im trying to use UART1 in Peripheral_UART example.
For now I changed settings for UART1 in zephyr.dst file
uart1: uart@9000 {
  reg = < 0x9000 0x1000 >;
  interrupts = < 0x9 0x1 >;
  status = "okay";
  label = "UART_1";
  current-speed = < 0x4b00 >;
  tx-pin = < 0x21 >;
  rx-pin = < 0x20 >;
  rts-pin = < 0x0b >;
  cts-pin = < 0x0a >;
And i added in autoconfig.h
#define CONFIG_NRFX_UARTE1 1
#define CONFIG_UART_NRFX 1
#define CONFIG_UART_1_NRF_UARTE 1
#define CONFIG_UART_1_ENHANCED_POLL_OUT 1
#define CONFIG_UART_1_ASYNC 1
#define CONFIG_UART_1_NRF_TX_BUFFER_SIZE 32
It won't work with UART1.
When I switch back to UART0 it works fine.
What could be a problem?
  • Does this happen the first time you use k_malloc(), or after running for a time? If it runs for a time before failing, make sure that the buffers are being freed properly. If you are changing anything about how the buffers are made or used, you may be avoiding the k_free(buf).
    Have you modified the sample other than changing to uart1?
  • Does this happen the first time you use k_malloc() --> No
    When I run Perhiperal_UART example everything starts normally, without error ...
    An error occurs when I enter something on UART1 on a connected computer, in my case USB TO RS232 SERIAL CONVERTER on COM75 then several times the k_malloc() is done correctly and after a few times an error starts to occur
    OUTPUT
    Bluetooth initializedStarting Nordic UART service example
    Allocate UART receive buffer0 DONE
    Allocate UART receive buffer1 DONE
    Not able to allocate UART receive buffer0
    Not able to allocate UART receive buffer2
    and continue to report Not able to allocate UART receive buffer2
    Have you modified the sample other than changing to uart1? --> No, I only added printk() in a few places
  • Could you zip the project and attach it here using Insert->Image/video/file ?
    Looks like the ble_write_thread is stuck on the k_sem_take and is not able to free the buffers.
  • I included zip file peripheral_uart_20220208
    peripheral_uart_20220208.zip
    Is there another simpler SEGGER example of using a UART without Bluetooth in SDK 1.6.1?
  • Looks like the problem was in the bad USB TO RS232 SERIAL adapter ...
    It works now...
    I still needed help with redirecting the communication on uart1, so thank you for that, you were very helpful, now everything works.
