[SeggerBackend] JLinkARM.dll reported "-1", "An unknown error.".
I am trying to program an nRF9160 chip using pynrfjprog v10.15.2 and JLinkARM.dll version: 6.88 with a Segger Flasher Compact. This flasher supportd the nRF9160. I downgraded the J-Link version from v7.60 as per the recommendation on a earlier ticket to be compatible with nRF Connect v3.7 (https://devzone.nordicsemi.com/f/nordic-q-a/84153/unsupported-device-the-detected-device-could-not-be-recognized-as-neither-jlink-device-nor-nordic-usb-device).
My problem is nrfjprog cannot reliably find the debugger. Sometimes it works miraculously even though nothing has changed but most of the time it cannot find it. When I try to connect to the debugger in  nRF Connect v3.7 I get this error:
Could not fetch memory size of target devkit: Error: Error occured when get library info. Errorcode: CouldNotOpenDevice (0x4) Lowlevel error: JLINKARM_DLL_ERROR (ffffff9a)
In nRF Connect v3.9 it says the debugger is not a recognized device.
I get this error using pynrfjprog:
[DebugProbe] Failed to connect to debug probe
The debugger can be seen in device manager:
and in nRF Connect:
For whatever reason, the nrfjprog cannot find the debugger on the backend. Any help would be very much appreciated.
    We recently released v3.10 of nRF Connect. Can you try updating to this version and see if the issue still persists? There should be a newer version of J-Link bundled with the update as well, but if J-Link is not updated automatically please download and install v7.58b from here: https://www.segger.com/downloads/jlink. You can check the version of J-Link with the command 'nrfjprog -v'. Remember to also update the Programmer app to v2.3.1.
    Let me know if you still get this issue after updating and I will forward it to our developers. If that is the case please share the logs from the Programmer. In the latest version there is an added feature to get additional logging. You can enable it by going to the About tab in the Programmer and selecting Verbose logging. To get logs from the beginning please select Restart with verbose logging. After the app restarts select Open log file at the bottom of the terminal to get the log file and upload it here with Insert -> Image/Video/File. Please be aware that verbose logging will lead to rather large log files, so you should not have the option enabled unless you need to send the logs for support, as they can fill up the space on your computer quickly.
    Marte
  • Hi Marte,
    I followed your instructions and updated to the most recent versions. Unfortunately I am still experiencing the same issue. It would  not let me attach the log file so please see the output below:
    2022-02-04T19:59:25.337Z INFO Application data folder: C:\Users\kdimmell\AppData\Roaming\nrfconnect\pc-nrfconnect-programmer
    2022-02-04T19:59:25.509Z VERBOSE [nrfdl][trace](12:59:25.355) DeviceLister::enumerate: Checking future_status of enumerate_task_status
    2022-02-04T19:59:25.511Z VERBOSE [nrfdl][trace](12:59:25.355) DeviceLister::enumerate: Waiting for enumerate task to complete
    2022-02-04T19:59:25.512Z VERBOSE [nrfdl][trace](12:59:25.355) DeviceLister::enumerate::enumerate_task: Start
    2022-02-04T19:59:25.513Z VERBOSE [nrfdl][trace](12:59:25.355) DeviceLister::enumerate::enumerate_task: Device_pool is empty
    2022-02-04T19:59:25.514Z VERBOSE [nrfdl][trace](12:59:25.355) DeviceLister::enumerate::enumerate_task: Before async_lister->enumarate
    2022-02-04T19:59:25.516Z DEBUG [nrfdl][debug](12:59:25.357) [->] NRFDL::Win32::USBPlatformAPI::copyDeviceToUSB
    2022-02-04T19:59:25.517Z DEBUG [nrfdl][debug](12:59:25.357) Hub device path: \\?\USB#VID_0BDA&PID_5411#6&271A80A5&0&2#{f18a0e88-c30c-11d0-8815-00a0c906bed8}, port number: 1, origin: {63625DD5-77E3-11EC-9DA9-D4D252955827}
    2022-02-04T19:59:25.519Z DEBUG [nrfdl][debug](12:59:25.357) Starting DeviceIoControl
    2022-02-04T19:59:25.520Z DEBUG [nrfdl][debug](12:59:25.357) Getting config descriptor
    2022-02-04T19:59:25.522Z DEBUG [nrfdl][debug](12:59:25.357) Iterating descriptors.
    2022-02-04T19:59:25.523Z DEBUG [nrfdl][debug](12:59:25.357) [<-] NRFDL::Win32::USBPlatformAPI::copyDeviceToUSB [took 0ms]
    2022-02-04T19:59:25.525Z DEBUG [nrfdl][debug](12:59:25.358) [->] NRFDL::Win32::USBPlatformAPI::copyDeviceToUSB
    2022-02-04T19:59:25.526Z DEBUG [nrfdl][debug](12:59:25.358) Hub device path: \\?\USB#VID_0BDA&PID_5411#6&271A80A5&0&2#{f18a0e88-c30c-11d0-8815-00a0c906bed8}, port number: 2, origin: {09846104-91F4-5CF5-B82E-F613CD4365F9}
    2022-02-04T19:59:25.527Z DEBUG [nrfdl][debug](12:59:25.358) Starting DeviceIoControl
    2022-02-04T19:59:25.528Z DEBUG [nrfdl][debug](12:59:25.362) Getting config descriptor
    2022-02-04T19:59:25.529Z DEBUG [nrfdl][debug](12:59:25.362) Iterating descriptors.
    2022-02-04T19:59:25.530Z DEBUG [nrfdl][debug](12:59:25.362) [<-] NRFDL::Win32::USBPlatformAPI::copyDeviceToUSB [took 4ms]
    2022-02-04T19:59:25.531Z DEBUG [nrfdl][debug](12:59:25.363) [->] NRFDL::Win32::USBPlatformAPI::copyDeviceToUSB
    2022-02-04T19:59:25.532Z DEBUG [nrfdl][debug](12:59:25.363) Hub device path: \\?\USB#VID_0BDA&PID_5411#6&271A80A5&0&2#{f18a0e88-c30c-11d0-8815-00a0c906bed8}, port number: 4, origin: {E4D77A90-8249-5DF3-911E-A804CABFBB1C}
    2022-02-04T19:59:25.534Z DEBUG [nrfdl][debug](12:59:25.363) Starting DeviceIoControl
    2022-02-04T19:59:25.535Z DEBUG [nrfdl][debug](12:59:25.363) Getting config descriptor
    2022-02-04T19:59:25.538Z DEBUG [nrfdl][debug](12:59:25.363) Iterating descriptors.
    2022-02-04T19:59:25.539Z DEBUG [nrfdl][debug](12:59:25.363) [<-] NRFDL::Win32::USBPlatformAPI::copyDeviceToUSB [took 0ms]
    2022-02-04T19:59:25.542Z DEBUG [nrfdl][debug](12:59:25.363) [->] NRFDL::Win32::USBPlatformAPI::copyDeviceToUSB
    2022-02-04T19:59:25.544Z DEBUG [nrfdl][debug](12:59:25.363) Hub device path: \\?\USB#ROOT_HUB30#4&281379B0&0&0#{f18a0e88-c30c-11d0-8815-00a0c906bed8}, port number: 5, origin: {00000000-0000-0000-FFFF-FFFFFFFFFFFF}
    2022-02-04T19:59:25.546Z DEBUG [nrfdl][debug](12:59:25.363) Starting DeviceIoControl
    2022-02-04T19:59:25.548Z DEBUG [nrfdl][debug](12:59:25.363) Getting config descriptor
    2022-02-04T19:59:25.549Z DEBUG [nrfdl][debug](12:59:25.363) Iterating descriptors.
    2022-02-04T19:59:25.552Z DEBUG [nrfdl][debug](12:59:25.363) [<-] NRFDL::Win32::USBPlatformAPI::copyDeviceToUSB [took 0ms]
    2022-02-04T19:59:25.553Z DEBUG [nrfdl][debug](12:59:25.364) [->] NRFDL::Win32::USBPlatformAPI::copyDeviceToUSB
    2022-02-04T19:59:25.555Z DEBUG [nrfdl][debug](12:59:25.364) Hub device path: \\?\USB#ROOT_HUB30#4&281379B0&0&0#{f18a0e88-c30c-11d0-8815-00a0c906bed8}, port number: 6, origin: {00000000-0000-0000-FFFF-FFFFFFFFFFFF}
    2022-02-04T19:59:25.557Z DEBUG [nrfdl][debug](12:59:25.364) Starting DeviceIoControl
    2022-02-04T19:59:25.558Z DEBUG [nrfdl][debug](12:59:25.364) Getting config descriptor
    2022-02-04T19:59:25.560Z DEBUG [nrfdl][debug](12:59:25.364) Iterating descriptors.
    2022-02-04T19:59:25.561Z DEBUG [nrfdl][debug](12:59:25.364) [<-] NRFDL::Win32::USBPlatformAPI::copyDeviceToUSB [took 0ms]
    2022-02-04T19:59:25.563Z DEBUG [nrfdl][debug](12:59:25.364) [->] NRFDL::Win32::USBPlatformAPI::copyDeviceToUSB
    2022-02-04T19:59:25.564Z DEBUG [nrfdl][debug](12:59:25.364) Hub device path: \\?\USB#VID_2109&PID_2817#5&71963A1&0&2#{f18a0e88-c30c-11d0-8815-00a0c906bed8}, port number: 3, origin: {13F3CBD4-FCA9-54C2-8577-8006E01F7F4D}
    2022-02-04T19:59:25.566Z DEBUG [nrfdl][debug](12:59:25.364) Starting DeviceIoControl
    2022-02-04T19:59:25.567Z DEBUG [nrfdl][debug](12:59:25.365) Getting config descriptor
    2022-02-04T19:59:25.568Z DEBUG [nrfdl][debug](12:59:25.365) Iterating descriptors.
    2022-02-04T19:59:25.570Z DEBUG [nrfdl][debug](12:59:25.365) [<-] NRFDL::Win32::USBPlatformAPI::copyDeviceToUSB [took 0ms]
    2022-02-04T19:59:25.571Z DEBUG [nrfdl][debug](12:59:25.365) [->] NRFDL::Win32::USBPlatformAPI::copyDeviceToUSB
    2022-02-04T19:59:25.573Z DEBUG [nrfdl][debug](12:59:25.365) Hub device path: \\?\USB#ROOT_HUB30#4&281379B0&0&0#{f18a0e88-c30c-11d0-8815-00a0c906bed8}, port number: 1, origin: {5EF93C1D-65C4-5CD1-82C2-092F33DEFAB0}
    2022-02-04T19:59:25.574Z DEBUG [nrfdl][debug](12:59:25.365) Starting DeviceIoControl
    2022-02-04T19:59:25.575Z DEBUG [nrfdl][debug](12:59:25.365) Getting config descriptor
    2022-02-04T19:59:25.577Z DEBUG [nrfdl][debug](12:59:25.366) Iterating descriptors.
    2022-02-04T19:59:25.577Z DEBUG [nrfdl][debug](12:59:25.366) [<-] NRFDL::Win32::USBPlatformAPI::copyDeviceToUSB [took 0ms]
    2022-02-04T19:59:25.578Z DEBUG [nrfdl][debug](12:59:25.366) [->] NRFDL::Win32::USBPlatformAPI::copyDeviceToUSB
    2022-02-04T19:59:25.579Z DEBUG [nrfdl][debug](12:59:25.366) Hub device path: \\?\USB#ROOT_HUB30#4&281379B0&0&0#{f18a0e88-c30c-11d0-8815-00a0c906bed8}, port number: 3, origin: {94190868-251F-11EC-9D91-D4D25295582A}
    2022-02-04T19:59:25.581Z DEBUG [nrfdl][debug](12:59:25.366) Starting DeviceIoControl
    2022-02-04T19:59:25.581Z DEBUG [nrfdl][debug](12:59:25.366) Getting config descriptor
    2022-02-04T19:59:25.583Z DEBUG [nrfdl][debug](12:59:25.366) Iterating descriptors.
    2022-02-04T19:59:25.586Z DEBUG [nrfdl][debug](12:59:25.367) [<-] NRFDL::Win32::USBPlatformAPI::copyDeviceToUSB [took 0ms]
    2022-02-04T19:59:25.588Z DEBUG [nrfdl][debug](12:59:25.367) [->] NRFDL::Win32::USBPlatformAPI::copyDeviceToUSB
    2022-02-04T19:59:25.590Z DEBUG [nrfdl][debug](12:59:25.367) Hub device path: \\?\USB#VID_0BDA&PID_5411#6&271A80A5&0&2#{f18a0e88-c30c-11d0-8815-00a0c906bed8}, port number: 3, origin: {D90C8AF6-8509-5FF6-9D3A-EE737E0DD0A7}
    2022-02-04T19:59:25.592Z DEBUG [nrfdl][debug](12:59:25.367) Starting DeviceIoControl
    2022-02-04T19:59:25.597Z DEBUG [nrfdl][debug](12:59:25.372) Getting config descriptor
    2022-02-04T19:59:25.599Z DEBUG [nrfdl][debug](12:59:25.372) Iterating descriptors.
    2022-02-04T19:59:25.601Z DEBUG [nrfdl][debug](12:59:25.372) [<-] NRFDL::Win32::USBPlatformAPI::copyDeviceToUSB [took 4ms]
    2022-02-04T19:59:25.602Z DEBUG [nrfdl][debug](12:59:25.372) [->] NRFDL::Win32::USBPlatformAPI::copyDeviceToUSB
    2022-02-04T19:59:25.604Z DEBUG [nrfdl][debug](12:59:25.372) Hub device path: \\?\USB#VID_2109&PID_2817#5&71963A1&0&2#{f18a0e88-c30c-11d0-8815-00a0c906bed8}, port number: 5, origin: {D8631B00-9684-5861-B614-BDFCD3ACA8D4}
    2022-02-04T19:59:25.606Z DEBUG [nrfdl][debug](12:59:25.372) Starting DeviceIoControl
    2022-02-04T19:59:25.607Z DEBUG [nrfdl][debug](12:59:25.372) Getting config descriptor
    2022-02-04T19:59:25.608Z DEBUG [nrfdl][debug](12:59:25.372) Iterating descriptors.
    2022-02-04T19:59:25.610Z DEBUG [nrfdl][debug](12:59:25.372) [<-] NRFDL::Win32::USBPlatformAPI::copyDeviceToUSB [took 0ms]
    2022-02-04T19:59:25.611Z DEBUG [nrfdl][debug](12:59:25.372) [->] NRFDL::Win32::USBPlatformAPI::copyDeviceToUSB
    2022-02-04T19:59:25.612Z DEBUG [nrfdl][debug](12:59:25.372) Hub device path: \\?\USB#ROOT_HUB30#4&281379B0&0&0#{f18a0e88-c30c-11d0-8815-00a0c906bed8}, port number: 8, origin: {00000000-0000-0000-FFFF-FFFFFFFFFFFF}
    2022-02-04T19:59:25.614Z DEBUG [nrfdl][debug](12:59:25.372) Starting DeviceIoControl
    2022-02-04T19:59:25.615Z DEBUG [nrfdl][debug](12:59:25.372) Getting config descriptor
    2022-02-04T19:59:25.617Z DEBUG [nrfdl][debug](12:59:25.372) Iterating descriptors.
    2022-02-04T19:59:25.618Z DEBUG [nrfdl][debug](12:59:25.372) [<-] NRFDL::Win32::USBPlatformAPI::copyDeviceToUSB [took 0ms]
    2022-02-04T19:59:25.620Z DEBUG [nrfdl][debug](12:59:25.372) USBLister: Adding device with serial number: {63625DD5-77E3-11EC-9DA9-D4D252955827}
    2022-02-04T19:59:25.622Z DEBUG [nrfdl][debug](12:59:25.372) USBLister: Adding device with serial number: FT5OMITZ
    2022-02-04T19:59:25.624Z DEBUG [nrfdl][debug](12:59:25.372) USBLister: Adding device with serial number: 0024001C3156501920323443
    2022-02-04T19:59:25.626Z DEBUG [nrfdl][debug](12:59:25.372) USBLister: Adding device with serial number: {00000000-0000-0000-FFFF-FFFFFFFFFFFF}
    2022-02-04T19:59:25.628Z DEBUG [nrfdl][debug](12:59:25.372) USBLister: Adding device with serial number: {00000000-0000-0000-FFFF-FFFFFFFFFFFF}
    2022-02-04T19:59:25.629Z DEBUG [nrfdl][debug](12:59:25.372) USBLister: Adding device with serial number: {13F3CBD4-FCA9-54C2-8577-8006E01F7F4D}
    2022-02-04T19:59:25.631Z DEBUG [nrfdl][debug](12:59:25.372) USBLister: Adding device with serial number: 001015000264
    2022-02-04T19:59:25.633Z DEBUG [nrfdl][debug](12:59:25.372) USBLister: Adding device with serial number: {94190868-251F-11EC-9D91-D4D25295582A}
    2022-02-04T19:59:25.634Z DEBUG [nrfdl][debug](12:59:25.372) USBLister: Adding device with serial number: FT5OMIES
    2022-02-04T19:59:25.636Z DEBUG [nrfdl][debug](12:59:25.372) USBLister: Adding device with serial number: {D8631B00-9684-5861-B614-BDFCD3ACA8D4}
    2022-02-04T19:59:25.638Z DEBUG [nrfdl][debug](12:59:25.372) USBLister: Adding device with serial number: {00000000-0000-0000-FFFF-FFFFFFFFFFFF}
    2022-02-04T19:59:25.639Z VERBOSE [nrfdl][trace](12:59:25.372) DeviceLister::enumerate::enumerate_task: After async_lister->enumarate
    2022-02-04T19:59:25.641Z VERBOSE [nrfdl][trace](12:59:25.372) DeviceLister::enumerate: Enumerating with sync lister
    2022-02-04T19:59:25.642Z VERBOSE [nrfdl][trace](12:59:25.372) SerialPortLister::enumerate
    2022-02-04T19:59:25.644Z DEBUG [nrfdl][debug](12:59:25.381) Could not open register key: SYSTEM\CurrentControlSet\Enum\USB\VID_&PID_
    2022-02-04T19:59:25.645Z DEBUG [nrfdl][debug](12:59:25.388) Could not open register key: SYSTEM\CurrentControlSet\Enum\USB\VID_&PID_
    2022-02-04T19:59:25.647Z VERBOSE [nrfdl][trace](12:59:25.388) DeviceLister::enumerate: Enumerating with sync lister
    2022-02-04T19:59:25.648Z VERBOSE [nrfdl][trace](12:59:25.388) JLinkLister::enumerate
    2022-02-04T19:59:25.651Z DEBUG [nrfdl][debug](12:59:25.388) [->] NRFDL::UniversalPlatform::JLinkHW::enumerate
    2022-02-04T19:59:25.652Z VERBOSE [nrfdl][trace](12:59:25.388) [NRFJPROG] [HighLevel] [Debug] dll_open
    2022-02-04T19:59:25.654Z DEBUG [nrfdl][debug](12:59:25.388) nrfjprog_function return value: 0
    2022-02-04T19:59:25.655Z VERBOSE [nrfdl][trace](12:59:25.388) [NRFJPROG] [HighLevel] [Debug] get_connected_probes
    2022-02-04T19:59:25.657Z DEBUG [nrfdl][debug](12:59:25.407) nrfjprog_function return value: 0
    2022-02-04T19:59:25.658Z VERBOSE [nrfdl][trace](12:59:25.407) [NRFJPROG] [HighLevel] [Debug] probe_init
    2022-02-04T19:59:25.659Z VERBOSE [nrfdl][trace](12:59:25.407) [NRFJPROG] [HighLevel] [Info] Creating new probe
    2022-02-04T19:59:25.661Z VERBOSE [nrfdl][trace](12:59:25.407) [NRFJPROG] [DebugProbe] [Debug] User set clock_speed == 0, setting default clock speed to default value 2000.
    2022-02-04T19:59:25.663Z VERBOSE [nrfdl][trace](12:59:25.407) [NRFJPROG] [HighLevel] [Info] Initialize new probe.
    2022-02-04T19:59:25.665Z VERBOSE [nrfdl][trace](12:59:25.407) [NRFJPROG] [DebugProbe] [Debug] initialize
    2022-02-04T19:59:25.666Z VERBOSE [nrfdl][trace](12:59:25.408) [NRFJPROG] [DebugProbe] [Info] Load library at \\?\C:\Users\kdimmell\AppData\Local\Programs\nrfconnect\resources\app.asar.unpacked\node_modules\@nordicsemiconductor\nrf-device-lib-js\Release\nrfjprog.dll.
    2022-02-04T19:59:25.668Z VERBOSE [nrfdl][trace](12:59:25.410) [NRFJPROG] [DebugProbe] [Info] Library loaded, loading member functions.
    2022-02-04T19:59:25.670Z VERBOSE [nrfdl][trace](12:59:25.410) [NRFJPROG] [DebugProbe] [Info] Member functions succesfully loaded.
    2022-02-04T19:59:25.671Z VERBOSE [nrfdl][trace](12:59:25.410) [NRFJPROG] [DebugProbe] [Info] Connecting to device from UNKNOWN family.
    2022-02-04T19:59:25.681Z DEBUG App pc-nrfconnect-programmer v2.3.1 official
    2022-02-04T19:59:25.682Z DEBUG App path: C:\Users\kdimmell\.nrfconnect-apps\node_modules\pc-nrfconnect-programmer
    2022-02-04T19:59:25.682Z DEBUG nRFConnect 3.10.0, required by the app is (^3.10.0)
    2022-02-04T19:59:25.682Z DEBUG nRFConnect path: C:\Users\kdimmell\AppData\Local\Programs\nrfconnect\resources\app.asar
    2022-02-04T19:59:25.682Z DEBUG HomeDir: C:\Users\kdimmell
    2022-02-04T19:59:25.682Z DEBUG TmpDir: C:\Users\kdimmell\AppData\Local\Temp
    2022-02-04T19:59:25.914Z VERBOSE [nrfdl][trace](12:59:25.812) [NRFJPROG] [Client] [Debug] open
    2022-02-04T19:59:25.915Z VERBOSE [nrfdl][trace](12:59:25.812) [NRFJPROG] [Client] [Debug] start
    2022-02-04T19:59:25.975Z VERBOSE [nrfdl][trace](12:59:25.974) [NRFJPROG] [Client] [Info] stdout: Jlinkarm nRF Worker ready. Handling sequence 6300779c-db85-4445-b04c-00f9e3afd971.
    2022-02-04T19:59:25.994Z VERBOSE [nrfdl][trace](12:59:25.992) [NRFJPROG] [SeggerBackend] [Debug] Logger sink registered in Segger backend logger
    2022-02-04T19:59:25.995Z VERBOSE [nrfdl][trace](12:59:25.992) [NRFJPROG] [JLink] [Debug] Logger sink registered in JLink logger
    2022-02-04T19:59:25.996Z VERBOSE [nrfdl][trace](12:59:25.992) [NRFJPROG] [nRFXX] [Debug] open
    2022-02-04T19:59:25.998Z VERBOSE [nrfdl][trace](12:59:25.992) [NRFJPROG] [nRFXX] [Debug] just_check_family
    2022-02-04T19:59:25.999Z VERBOSE [nrfdl][trace](12:59:25.992) [NRFJPROG] [SeggerBackend] [Debug] open_dll
    2022-02-04T19:59:26.000Z VERBOSE [nrfdl][trace](12:59:25.992) [NRFJPROG] [SeggerBackend] [Debug] No J-Link DLL path was provided. Attempting to auto detect.
    2022-02-04T19:59:26.006Z VERBOSE [nrfdl][trace](12:59:26.004) [NRFJPROG] [Client] [None] Command open executed for 180 milliseconds with result 0
    2022-02-04T19:59:26.007Z VERBOSE [nrfdl][trace](12:59:26.004) [NRFJPROG] [Client] [Debug] connect_to_emu_with_snr
    2022-02-04T19:59:26.010Z VERBOSE [nrfdl][trace](12:59:26.008) [NRFJPROG] [SeggerBackend] [Info] Load library at C:\Program Files\SEGGER\JLink\JLinkARM.dll.
    2022-02-04T19:59:26.012Z VERBOSE [nrfdl][trace](12:59:26.008) [NRFJPROG] [SeggerBackend] [Info] Library loaded, loading member functions.
    2022-02-04T19:59:26.013Z VERBOSE [nrfdl][trace](12:59:26.008) [NRFJPROG] [SeggerBackend] [Info] Member functions succesfully loaded.
    2022-02-04T19:59:26.014Z VERBOSE [nrfdl][trace](12:59:26.008) [NRFJPROG] [SeggerBackend] [Debug] dll_version
    2022-02-04T19:59:26.015Z VERBOSE [nrfdl][trace](12:59:26.009) [NRFJPROG] [SeggerBackend] [Info] Segger dll version 7.58.b loaded.
    2022-02-04T19:59:26.016Z VERBOSE [nrfdl][trace](12:59:26.009) [NRFJPROG] [Worker] [None] Command open executed for 30 milliseconds with result 0
    2022-02-04T19:59:26.017Z VERBOSE [nrfdl][trace](12:59:26.009) [NRFJPROG] [nRFXX] [Debug] connect_to_emu_with_snr
    2022-02-04T19:59:26.018Z VERBOSE [nrfdl][trace](12:59:26.009) [NRFJPROG] [SeggerBackend] [Debug] is_connected_to_emu
    2022-02-04T19:59:26.019Z VERBOSE [nrfdl][trace](12:59:26.009) [NRFJPROG] [SeggerBackend] [Debug] connect_to_emu_with_snr
    2022-02-04T19:59:26.021Z VERBOSE [nrfdl][trace](12:59:26.009) [NRFJPROG] [SeggerBackend] [Debug] is_connected_to_emu
    2022-02-04T19:59:26.022Z VERBOSE [nrfdl][trace](12:59:26.009) [NRFJPROG] [SeggerBackend] [Debug] ---just_enum_emu_snr
    2022-02-04T19:59:26.024Z VERBOSE [nrfdl][trace](12:59:26.009) [NRFJPROG] [SeggerBackend] [Debug] ---just_get_num_emus
    2022-02-04T19:59:26.031Z VERBOSE [nrfdl][trace](12:59:26.030) [NRFJPROG] [SeggerBackend] [Debug] ---just_connect_to_emu_with_snr
    2022-02-04T19:59:26.032Z VERBOSE [nrfdl][trace](12:59:26.030) [NRFJPROG] [SeggerBackend] [Debug] ---just_connect_to_emu_without_snr
    2022-02-04T19:59:26.033Z VERBOSE [nrfdl][trace](12:59:26.030) [NRFJPROG] [SeggerBackend] [Debug] Segger logging enabled.
    2022-02-04T19:59:26.327Z VERBOSE [nrfdl][trace](12:59:26.313) [NRFJPROG] [JLink] [None] Firmware: J-Link / Flasher Compact V5 compiled Jan 19 2022 10:23:57
    2022-02-04T19:59:26.341Z VERBOSE [nrfdl][trace](12:59:26.313) [NRFJPROG] [JLink] [None] Firmware: J-Link / Flasher Compact V5 compiled Jan 19 2022 10:23:57
    2022-02-04T19:59:26.343Z VERBOSE [nrfdl][trace](12:59:26.313) [NRFJPROG] [JLink] [None] Decompressing FW timestamp took 267 us
    2022-02-04T19:59:26.346Z VERBOSE [nrfdl][trace](12:59:26.327) [NRFJPROG] [JLink] [None] Hardware: V5.00
    2022-02-04T19:59:26.347Z VERBOSE [nrfdl][trace](12:59:26.327) [NRFJPROG] [JLink] [None] S/N: 1015000264
    2022-02-04T19:59:26.349Z VERBOSE [nrfdl][trace](12:59:26.327) [NRFJPROG] [JLink] [None] OEM: SEGGER
    2022-02-04T19:59:26.351Z VERBOSE [nrfdl][trace](12:59:26.327) [NRFJPROG] [JLink] [None] Feature(s): JFlash, GDB
    2022-02-04T19:59:26.353Z VERBOSE [nrfdl][trace](12:59:26.327) [NRFJPROG] [JLink] [None] TELNET listener socket opened on port 19021
    2022-02-04T19:59:26.355Z VERBOSE [nrfdl][trace](12:59:26.327) [NRFJPROG] [JLink] [None] WEBSRV WEBSRV_Init(): Starting webserver thread(s)
    2022-02-04T19:59:26.357Z VERBOSE [nrfdl][trace](12:59:26.327) [NRFJPROG] [JLink] [None] WEBSRV Webserver running on local port 19080
    2022-02-04T19:59:26.408Z VERBOSE [nrfdl][trace](12:59:26.407) [NRFJPROG] [JLink] [None] - 92.147ms returns "O.K."
    2022-02-04T19:59:26.410Z VERBOSE [nrfdl][trace](12:59:26.407) [NRFJPROG] [JLink] [None] JLINK_HasError()
    2022-02-04T19:59:26.411Z VERBOSE [nrfdl][trace](12:59:26.407) [NRFJPROG] [JLink] [None] JLINK_Lock()
    2022-02-04T19:59:26.412Z VERBOSE [nrfdl][trace](12:59:26.407) [NRFJPROG] [JLink] [None] JLINK_GetHWStatus(...)
    2022-02-04T19:59:26.412Z VERBOSE [nrfdl][trace](12:59:26.407) [NRFJPROG] [JLink] [None] - 0.158ms returns 0
    2022-02-04T19:59:26.413Z VERBOSE [nrfdl][trace](12:59:26.407) [NRFJPROG] [JLink] [None] JLINK_HasError()
    2022-02-04T19:59:26.414Z VERBOSE [nrfdl][trace](12:59:26.407) [NRFJPROG] [JLink] [None] JLINK_ExecCommand("SetRestartOnClose = 0", ...).
    2022-02-04T19:59:26.415Z VERBOSE [nrfdl][trace](12:59:26.407) [NRFJPROG] [JLink] [None] - 0.006ms returns 0x01
    2022-02-04T19:59:26.416Z VERBOSE [nrfdl][trace](12:59:26.407) [NRFJPROG] [JLink] [None] JLINK_HasError()
    2022-02-04T19:59:26.417Z VERBOSE [nrfdl][trace](12:59:26.407) [NRFJPROG] [JLink] [None] JLINK_ExecCommand("DisableFlashDL", ...).
    2022-02-04T19:59:26.418Z VERBOSE [nrfdl][trace](12:59:26.407) [NRFJPROG] [JLink] [None] - 0.013ms returns 0x00
    2022-02-04T19:59:26.419Z VERBOSE [nrfdl][trace](12:59:26.407) [NRFJPROG] [JLink] [None] JLINK_HasError()
    2022-02-04T19:59:26.420Z VERBOSE [nrfdl][trace](12:59:26.407) [NRFJPROG] [JLink] [None] JLINK_ExecCommand("ExcludeFlashCacheRange 0x0-0xFFFFFFFF", ...).
    2022-02-04T19:59:26.421Z VERBOSE [nrfdl][trace](12:59:26.407) [NRFJPROG] [JLink] [None] - 0.025ms returns 0x00
    2022-02-04T19:59:26.422Z VERBOSE [nrfdl][trace](12:59:26.407) [NRFJPROG] [JLink] [None] JLINK_HasError()
    2022-02-04T19:59:26.424Z VERBOSE [nrfdl][trace](12:59:26.407) [NRFJPROG] [JLink] [None] JLINK_SetHookUnsecureDialog
    2022-02-04T19:59:26.425Z VERBOSE [nrfdl][trace](12:59:26.407) [NRFJPROG] [JLink] [None] JLINK_SetHookUnsecureDialog(...)
    2022-02-04T19:59:26.426Z VERBOSE [nrfdl][trace](12:59:26.407) [NRFJPROG] [JLink] [None] - 0.077ms returns 0
    2022-02-04T19:59:26.427Z VERBOSE [nrfdl][trace](12:59:26.407) [NRFJPROG] [JLink] [None] JLINK_HasError()
    2022-02-04T19:59:26.428Z VERBOSE [nrfdl][trace](12:59:26.407) [NRFJPROG] [JLink] [None] JLINK_TIF_Select(JLINKARM_TIF_SWD)
    2022-02-04T19:59:26.429Z VERBOSE [nrfdl][trace](12:59:26.407) [NRFJPROG] [JLink] [None] - 0.501ms returns 0x00
    2022-02-04T19:59:26.430Z VERBOSE [nrfdl][trace](12:59:26.407) [NRFJPROG] [JLink] [None] JLINK_HasError()
    2022-02-04T19:59:26.430Z VERBOSE [nrfdl][trace](12:59:26.407) [NRFJPROG] [JLink] [None] JLINK_SetSpeed(2000)
    2022-02-04T19:59:26.431Z VERBOSE [nrfdl][trace](12:59:26.407) [NRFJPROG] [JLink] [None] - 0.103ms
    2022-02-04T19:59:26.432Z VERBOSE [nrfdl][trace](12:59:26.407) [NRFJPROG] [JLink] [None] JLINK_HasError()
    2022-02-04T19:59:26.433Z VERBOSE [nrfdl][trace](12:59:26.407) [NRFJPROG] [JLink] [None] JLINK_GetSN()
    2022-02-04T19:59:26.434Z VERBOSE [nrfdl][trace](12:59:26.407) [NRFJPROG] [JLink] [None] - 0.028ms returns 1015000264
    2022-02-04T19:59:26.435Z VERBOSE [nrfdl][trace](12:59:26.407) [NRFJPROG] [JLink] [None] JLINK_HasError()
    2022-02-04T19:59:26.436Z VERBOSE [nrfdl][trace](12:59:26.407) [NRFJPROG] [SeggerBackend] [Debug] read_debug_port_idr
    2022-02-04T19:59:26.437Z VERBOSE [nrfdl][trace](12:59:26.407) [NRFJPROG] [SeggerBackend] [Debug] read_debug_port_register
    2022-02-04T19:59:26.438Z VERBOSE [nrfdl][trace](12:59:26.407) [NRFJPROG] [SeggerBackend] [Debug] ---just_read_debug_port_register
    2022-02-04T19:59:26.439Z VERBOSE [nrfdl][trace](12:59:26.407) [NRFJPROG] [SeggerBackend] [Debug] coresight_configure
    2022-02-04T19:59:26.440Z VERBOSE [nrfdl][trace](12:59:26.407) [NRFJPROG] [JLink] [None] JLINK_CORESIGHT_Configure()
    2022-02-04T19:59:26.509Z VERBOSE [nrfdl][trace](12:59:26.508) [NRFJPROG] [JLink] [None] - 101.083ms returns 0
    2022-02-04T19:59:26.510Z VERBOSE [nrfdl][trace](12:59:26.508) [NRFJPROG] [JLink] [None] JLINK_HasError()
    2022-02-04T19:59:26.511Z VERBOSE [nrfdl][trace](12:59:26.508) [NRFJPROG] [SeggerBackend] [Debug] ---just_select_debug_port_register
    2022-02-04T19:59:26.512Z VERBOSE [nrfdl][trace](12:59:26.508) [NRFJPROG] [SeggerBackend] [Debug] Select AP 255, DP Bank 0, AP Bank 255
    2022-02-04T19:59:26.512Z VERBOSE [nrfdl][trace](12:59:26.508) [NRFJPROG] [JLink] [None] JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x02, 0x00000000)
    2022-02-04T19:59:26.513Z VERBOSE [nrfdl][trace](12:59:26.508) [NRFJPROG] [JLink] [None] - 0.578ms returns -1
    2022-02-04T19:59:26.514Z VERBOSE [nrfdl][trace](12:59:26.508) [NRFJPROG] [JLink] [None] JLINK_HasError()
    2022-02-04T19:59:26.515Z VERBOSE [nrfdl][trace](12:59:26.508) [NRFJPROG] [SeggerBackend] [Error] JLinkARM.dll reported "-1", "An unknown error.".
    2022-02-04T19:59:26.516Z VERBOSE [nrfdl][trace](12:59:26.508) [NRFJPROG] [SeggerBackend] [Debug] ---just_abort_debug_action
    2022-02-04T19:59:26.516Z VERBOSE [nrfdl][trace](12:59:26.508) [NRFJPROG] [SeggerBackend] [Debug] Attempting to clear any configuration errors in debug port before closing connection.
    2022-02-04T19:59:26.518Z VERBOSE [nrfdl][trace](12:59:26.508) [NRFJPROG] [JLink] [None] JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F)
    2022-02-04T19:59:26.519Z VERBOSE [nrfdl][trace](12:59:26.508) [NRFJPROG] [JLink] [None] - 0.473ms returns -1
    2022-02-04T19:59:26.520Z VERBOSE [nrfdl][trace](12:59:26.508) [NRFJPROG] [JLink] [None] JLINK_HasError()
    2022-02-04T19:59:26.521Z VERBOSE [nrfdl][trace](12:59:26.508) [NRFJPROG] [SeggerBackend] [Error] JLinkARM.dll reported "-1", "An unknown error.".
    2022-02-04T19:59:26.523Z VERBOSE [nrfdl][trace](12:59:26.508) [NRFJPROG] [JLink] [None] JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F)
    2022-02-04T19:59:26.524Z VERBOSE [nrfdl][trace](12:59:26.508) [NRFJPROG] [JLink] [None] - 0.531ms returns -1
    2022-02-04T19:59:26.525Z VERBOSE [nrfdl][trace](12:59:26.508) [NRFJPROG] [JLink] [None] JLINK_HasError()
    2022-02-04T19:59:26.526Z VERBOSE [nrfdl][trace](12:59:26.508) [NRFJPROG] [SeggerBackend] [Error] JLinkARM.dll reported "-1", "An unknown error.".
    2022-02-04T19:59:26.527Z VERBOSE [nrfdl][trace](12:59:26.508) [NRFJPROG] [JLink] [None] JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F)
    2022-02-04T19:59:26.528Z VERBOSE [nrfdl][trace](12:59:26.508) [NRFJPROG] [JLink] [None] - 0.588ms returns -1
    2022-02-04T19:59:26.529Z VERBOSE [nrfdl][trace](12:59:26.508) [NRFJPROG] [JLink] [None] JLINK_HasError()
    2022-02-04T19:59:26.530Z VERBOSE [nrfdl][trace](12:59:26.508) [NRFJPROG] [SeggerBackend] [Error] JLinkARM.dll reported "-1", "An unknown error.".
    2022-02-04T19:59:26.531Z VERBOSE [nrfdl][trace](12:59:26.508) [NRFJPROG] [JLink] [None] JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F)
    2022-02-04T19:59:26.532Z VERBOSE [nrfdl][trace](12:59:26.508) [NRFJPROG] [JLink] [None] - 0.497ms returns -1
    2022-02-04T19:59:26.533Z VERBOSE [nrfdl][trace](12:59:26.508) [NRFJPROG] [JLink] [None] JLINK_HasError()
    2022-02-04T19:59:26.535Z VERBOSE [nrfdl][trace](12:59:26.508) [NRFJPROG] [SeggerBackend] [Error] JLinkARM.dll reported "-1", "An unknown error.".
    2022-02-04T19:59:26.536Z VERBOSE [nrfdl][trace](12:59:26.508) [NRFJPROG] [JLink] [None] JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F)
    2022-02-04T19:59:26.538Z VERBOSE [nrfdl][trace](12:59:26.508) [NRFJPROG] [JLink] [None] - 0.544ms returns -1
    2022-02-04T19:59:26.539Z VERBOSE [nrfdl][trace](12:59:26.508) [NRFJPROG] [JLink] [None] JLINK_HasError()
    2022-02-04T19:59:26.540Z VERBOSE [nrfdl][trace](12:59:26.508) [NRFJPROG] [SeggerBackend] [Error] JLinkARM.dll reported "-1", "An unknown error.".
    2022-02-04T19:59:26.541Z VERBOSE [nrfdl][trace](12:59:26.508) [NRFJPROG] [JLink] [None] JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x02, 0x00000000)
    2022-02-04T19:59:26.542Z VERBOSE [nrfdl][trace](12:59:26.508) [NRFJPROG] [JLink] [None] - 0.527ms returns -1
    2022-02-04T19:59:26.543Z VERBOSE [nrfdl][trace](12:59:26.508) [NRFJPROG] [JLink] [None] JLINK_HasError()
    2022-02-04T19:59:26.545Z VERBOSE [nrfdl][trace](12:59:26.508) [NRFJPROG] [SeggerBackend] [Error] JLinkARM.dll reported "-1", "An unknown error.".
    2022-02-04T19:59:26.546Z VERBOSE [nrfdl][trace](12:59:26.508) [NRFJPROG] [SeggerBackend] [Debug] ---just_abort_debug_action
    2022-02-04T19:59:26.547Z VERBOSE [nrfdl][trace](12:59:26.508) [NRFJPROG] [SeggerBackend] [Debug] Attempting to clear any configuration errors in debug port before closing connection.
    2022-02-04T19:59:26.549Z VERBOSE [nrfdl][trace](12:59:26.508) [NRFJPROG] [JLink] [None] JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F)
    2022-02-04T19:59:26.550Z VERBOSE [nrfdl][trace](12:59:26.520) [NRFJPROG] [Client] [None] Command connect_to_emu_with_snr executed for 516 milliseconds with result -102
    2022-02-04T19:59:26.551Z VERBOSE [nrfdl][trace](12:59:26.520) [NRFJPROG] [DebugProbe] [Error] Failed to connect to debug probe
    2022-02-04T19:59:26.552Z VERBOSE [nrfdl][trace](12:59:26.520) [NRFJPROG] [DebugProbe] [Error] With serial number "1015000264".
    2022-02-04T19:59:26.555Z VERBOSE [nrfdl][trace](12:59:26.520) [NRFJPROG] [DebugProbe] [Error] And clockspeed "2000".
    2022-02-04T19:59:26.556Z VERBOSE [nrfdl][trace](12:59:26.520) [NRFJPROG] [DebugProbe] [Info] Uninitializing probe with serial number 1015000264.
    2022-02-04T19:59:26.557Z VERBOSE [nrfdl][trace](12:59:26.522) [NRFJPROG] [JLink] [None] - 0.535ms returns -1
    2022-02-04T19:59:26.559Z VERBOSE [nrfdl][trace](12:59:26.522) [NRFJPROG] [JLink] [None] JLINK_HasError()
    2022-02-04T19:59:26.560Z VERBOSE [nrfdl][trace](12:59:26.522) [NRFJPROG] [SeggerBackend] [Error] JLinkARM.dll reported "-1", "An unknown error.".
    2022-02-04T19:59:26.561Z VERBOSE [nrfdl][trace](12:59:26.522) [NRFJPROG] [JLink] [None] JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F)
    2022-02-04T19:59:26.564Z VERBOSE [nrfdl][trace](12:59:26.522) [NRFJPROG] [JLink] [None] - 0.515ms returns -1
    2022-02-04T19:59:26.568Z VERBOSE [nrfdl][trace](12:59:26.522) [NRFJPROG] [JLink] [None] JLINK_HasError()
    2022-02-04T19:59:26.569Z VERBOSE [nrfdl][trace](12:59:26.522) [NRFJPROG] [SeggerBackend] [Error] JLinkARM.dll reported "-1", "An unknown error.".
    2022-02-04T19:59:26.571Z VERBOSE [nrfdl][trace](12:59:26.522) [NRFJPROG] [JLink] [None] JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F)
    2022-02-04T19:59:26.572Z VERBOSE [nrfdl][trace](12:59:26.522) [NRFJPROG] [JLink] [None] - 0.509ms returns -1
    2022-02-04T19:59:26.574Z VERBOSE [nrfdl][trace](12:59:26.522) [NRFJPROG] [JLink] [None] JLINK_HasError()
    2022-02-04T19:59:26.575Z VERBOSE [nrfdl][trace](12:59:26.522) [NRFJPROG] [SeggerBackend] [Error] JLinkARM.dll reported "-1", "An unknown error.".
    2022-02-04T19:59:26.576Z VERBOSE [nrfdl][trace](12:59:26.522) [NRFJPROG] [JLink] [None] JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F)
    2022-02-04T19:59:26.576Z VERBOSE [nrfdl][trace](12:59:26.522) [NRFJPROG] [JLink] [None] - 0.459ms returns -1
    2022-02-04T19:59:26.577Z VERBOSE [nrfdl][trace](12:59:26.522) [NRFJPROG] [JLink] [None] JLINK_HasError()
    2022-02-04T19:59:26.578Z VERBOSE [nrfdl][trace](12:59:26.522) [NRFJPROG] [SeggerBackend] [Error] JLinkARM.dll reported "-1", "An unknown error.".
    2022-02-04T19:59:26.579Z VERBOSE [nrfdl][trace](12:59:26.522) [NRFJPROG] [JLink] [None] JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F)
    2022-02-04T19:59:26.580Z VERBOSE [nrfdl][trace](12:59:26.522) [NRFJPROG] [JLink] [None] - 0.495ms returns -1
    2022-02-04T19:59:26.582Z VERBOSE [nrfdl][trace](12:59:26.522) [NRFJPROG] [JLink] [None] JLINK_HasError()
    2022-02-04T19:59:26.583Z VERBOSE [nrfdl][trace](12:59:26.522) [NRFJPROG] [SeggerBackend] [Error] JLinkARM.dll reported "-1", "An unknown error.".
    2022-02-04T19:59:26.584Z VERBOSE [nrfdl][trace](12:59:26.522) [NRFJPROG] [JLink] [None] JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x02, 0x00000000)
    2022-02-04T19:59:26.585Z VERBOSE [nrfdl][trace](12:59:26.522) [NRFJPROG] [JLink] [None] - 0.459ms returns -1
    2022-02-04T19:59:26.586Z VERBOSE [nrfdl][trace](12:59:26.522) [NRFJPROG] [JLink] [None] JLINK_HasError()
    2022-02-04T19:59:26.587Z VERBOSE [nrfdl][trace](12:59:26.522) [NRFJPROG] [SeggerBackend] [Error] JLinkARM.dll reported "-1", "An unknown error.".
    2022-02-04T19:59:26.588Z VERBOSE [nrfdl][trace](12:59:26.522) [NRFJPROG] [SeggerBackend] [Debug] ---just_abort_debug_action
    2022-02-04T19:59:26.589Z VERBOSE [nrfdl][trace](12:59:26.522) [NRFJPROG] [SeggerBackend] [Debug] Attempting to clear any configuration errors in debug port before closing connection.
    2022-02-04T19:59:26.590Z VERBOSE [nrfdl][trace](12:59:26.522) [NRFJPROG] [JLink] [None] JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F)
    2022-02-04T19:59:26.591Z VERBOSE [nrfdl][trace](12:59:26.522) [NRFJPROG] [JLink] [None] - 0.480ms returns -1
    2022-02-04T19:59:26.592Z VERBOSE [nrfdl][trace](12:59:26.522) [NRFJPROG] [JLink] [None] JLINK_HasError()
    2022-02-04T19:59:26.593Z VERBOSE [nrfdl][trace](12:59:26.522) [NRFJPROG] [SeggerBackend] [Error] JLinkARM.dll reported "-1", "An unknown error.".
    2022-02-04T19:59:26.594Z VERBOSE [nrfdl][trace](12:59:26.522) [NRFJPROG] [JLink] [None] JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F)
    2022-02-04T19:59:26.594Z VERBOSE [nrfdl][trace](12:59:26.522) [NRFJPROG] [JLink] [None] - 0.484ms returns -1
    2022-02-04T19:59:26.595Z VERBOSE [nrfdl][trace](12:59:26.522) [NRFJPROG] [JLink] [None] JLINK_HasError()
    2022-02-04T19:59:26.596Z VERBOSE [nrfdl][trace](12:59:26.522) [NRFJPROG] [SeggerBackend] [Error] JLinkARM.dll reported "-1", "An unknown error.".
    2022-02-04T19:59:26.597Z VERBOSE [nrfdl][trace](12:59:26.522) [NRFJPROG] [JLink] [None] JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F)
    2022-02-04T19:59:26.598Z VERBOSE [nrfdl][trace](12:59:26.522) [NRFJPROG] [JLink] [None] - 0.452ms returns -1
    2022-02-04T19:59:26.600Z VERBOSE [nrfdl][trace](12:59:26.522) [NRFJPROG] [JLink] [None] JLINK_HasError()
    2022-02-04T19:59:26.601Z VERBOSE [nrfdl][trace](12:59:26.522) [NRFJPROG] [SeggerBackend] [Error] JLinkARM.dll reported "-1", "An unknown error.".
    2022-02-04T19:59:26.602Z VERBOSE [nrfdl][trace](12:59:26.522) [NRFJPROG] [JLink] [None] JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F)
    2022-02-04T19:59:26.603Z VERBOSE [nrfdl][trace](12:59:26.522) [NRFJPROG] [JLink] [None] - 0.555ms returns -1
    2022-02-04T19:59:26.605Z VERBOSE [nrfdl][trace](12:59:26.522) [NRFJPROG] [JLink] [None] JLINK_HasError()
    2022-02-04T19:59:26.606Z VERBOSE [nrfdl][trace](12:59:26.522) [NRFJPROG] [SeggerBackend] [Error] JLinkARM.dll reported "-1", "An unknown error.".
    2022-02-04T19:59:26.607Z VERBOSE [nrfdl][trace](12:59:26.522) [NRFJPROG] [JLink] [None] JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F)
    2022-02-04T19:59:26.608Z VERBOSE [nrfdl][trace](12:59:26.522) [NRFJPROG] [JLink] [None] - 0.559ms returns -1
    2022-02-04T19:59:26.609Z VERBOSE [nrfdl][trace](12:59:26.522) [NRFJPROG] [JLink] [None] JLINK_HasError()
    2022-02-04T19:59:26.610Z VERBOSE [nrfdl][trace](12:59:26.522) [NRFJPROG] [SeggerBackend] [Error] JLinkARM.dll reported "-1", "An unknown error.".
    2022-02-04T19:59:26.611Z VERBOSE [nrfdl][trace](12:59:26.522) [NRFJPROG] [JLink] [None] JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x02, 0x00000000)
    2022-02-04T19:59:26.611Z VERBOSE [nrfdl][trace](12:59:26.522) [NRFJPROG] [JLink] [None] - 0.462ms returns -1
    2022-02-04T19:59:26.612Z VERBOSE [nrfdl][trace](12:59:26.522) [NRFJPROG] [JLink] [None] JLINK_HasError()
    2022-02-04T19:59:26.613Z VERBOSE [nrfdl][trace](12:59:26.522) [NRFJPROG] [SeggerBackend] [Error] JLinkARM.dll reported "-1", "An unknown error.".
    2022-02-04T19:59:26.615Z VERBOSE [nrfdl][trace](12:59:26.522) [NRFJPROG] [SeggerBackend] [Debug] ---just_abort_debug_action
    2022-02-04T19:59:26.616Z VERBOSE [nrfdl][trace](12:59:26.522) [NRFJPROG] [SeggerBackend] [Debug] Attempting to clear any configuration errors in debug port before closing connection.
    2022-02-04T19:59:26.617Z VERBOSE [nrfdl][trace](12:59:26.522) [NRFJPROG] [JLink] [None] JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F)
    2022-02-04T19:59:26.618Z VERBOSE [nrfdl][trace](12:59:26.522) [NRFJPROG] [JLink] [None] - 0.491ms returns -1
    2022-02-04T19:59:26.619Z VERBOSE [nrfdl][trace](12:59:26.522) [NRFJPROG] [JLink] [None] JLINK_HasError()
    2022-02-04T19:59:26.620Z VERBOSE [nrfdl][trace](12:59:26.522) [NRFJPROG] [SeggerBackend] [Error] JLinkARM.dll reported "-1", "An unknown error.".
    2022-02-04T19:59:26.622Z VERBOSE [nrfdl][trace](12:59:26.522) [NRFJPROG] [JLink] [None] JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F)
    2022-02-04T19:59:26.624Z VERBOSE [nrfdl][trace](12:59:26.522) [NRFJPROG] [JLink] [None] - 0.495ms returns -1
    2022-02-04T19:59:26.625Z VERBOSE [nrfdl][trace](12:59:26.522) [NRFJPROG] [JLink] [None] JLINK_HasError()
    2022-02-04T19:59:26.626Z VERBOSE [nrfdl][trace](12:59:26.522) [NRFJPROG] [SeggerBackend] [Error] JLinkARM.dll reported "-1", "An unknown error.".
    2022-02-04T19:59:26.627Z VERBOSE [nrfdl][trace](12:59:26.522) [NRFJPROG] [JLink] [None] JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F)
    2022-02-04T19:59:26.628Z VERBOSE [nrfdl][trace](12:59:26.522) [NRFJPROG] [JLink] [None] - 0.503ms returns -1
    2022-02-04T19:59:26.629Z VERBOSE [nrfdl][trace](12:59:26.522) [NRFJPROG] [JLink] [None] JLINK_HasError()
    2022-02-04T19:59:26.630Z VERBOSE [nrfdl][trace](12:59:26.522) [NRFJPROG] [SeggerBackend] [Error] JLinkARM.dll reported "-1", "An unknown error.".
    2022-02-04T19:59:26.631Z VERBOSE [nrfdl][trace](12:59:26.522) [NRFJPROG] [JLink] [None] JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F)
    2022-02-04T19:59:26.633Z VERBOSE [nrfdl][trace](12:59:26.522) [NRFJPROG] [JLink] [None] - 0.439ms returns -1
    2022-02-04T19:59:26.633Z VERBOSE [nrfdl][trace](12:59:26.522) [NRFJPROG] [JLink] [None] JLINK_HasError()
    2022-02-04T19:59:26.634Z VERBOSE [nrfdl][trace](12:59:26.522) [NRFJPROG] [SeggerBackend] [Error] JLinkARM.dll reported "-1", "An unknown error.".
    2022-02-04T19:59:26.635Z VERBOSE [nrfdl][trace](12:59:26.522) [NRFJPROG] [JLink] [None] JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F)
    2022-02-04T19:59:26.636Z VERBOSE [nrfdl][trace](12:59:26.522) [NRFJPROG] [JLink] [None] - 0.486ms returns -1
    2022-02-04T19:59:26.637Z VERBOSE [nrfdl][trace](12:59:26.522) [NRFJPROG] [JLink] [None] JLINK_HasError()
    2022-02-04T19:59:26.639Z VERBOSE [nrfdl][trace](12:59:26.522) [NRFJPROG] [SeggerBackend] [Error] JLinkARM.dll reported "-1", "An unknown error.".
    2022-02-04T19:59:26.640Z VERBOSE [nrfdl][trace](12:59:26.522) [NRFJPROG] [JLink] [None] JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x02, 0x00000000)
    2022-02-04T19:59:26.641Z VERBOSE [nrfdl][trace](12:59:26.522) [NRFJPROG] [JLink] [None] - 0.560ms returns -1
    2022-02-04T19:59:26.642Z VERBOSE [nrfdl][trace](12:59:26.522) [NRFJPROG] [JLink] [None] JLINK_HasError()
    2022-02-04T19:59:26.644Z VERBOSE [nrfdl][trace](12:59:26.522) [NRFJPROG] [SeggerBackend] [Error] JLinkARM.dll reported "-1", "An unknown error.".
    2022-02-04T19:59:26.645Z VERBOSE [nrfdl][trace](12:59:26.522) [NRFJPROG] [SeggerBackend] [Debug] ---just_abort_debug_action
    2022-02-04T19:59:26.646Z VERBOSE [nrfdl][trace](12:59:26.522) [NRFJPROG] [SeggerBackend] [Debug] Attempting to clear any configuration errors in debug port before closing connection.
    2022-02-04T19:59:26.647Z VERBOSE [nrfdl][trace](12:59:26.522) [NRFJPROG] [JLink] [None] JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F)
    2022-02-04T19:59:26.648Z VERBOSE [nrfdl][trace](12:59:26.522) [NRFJPROG] [JLink] [None] - 0.496ms returns -1
    2022-02-04T19:59:26.649Z VERBOSE [nrfdl][trace](12:59:26.522) [NRFJPROG] [JLink] [None] JLINK_HasError()
    2022-02-04T19:59:26.650Z VERBOSE [nrfdl][trace](12:59:26.522) [NRFJPROG] [SeggerBackend] [Error] JLinkARM.dll reported "-1", "An unknown error.".
    2022-02-04T19:59:26.651Z VERBOSE [nrfdl][trace](12:59:26.522) [NRFJPROG] [JLink] [None] JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F)
    2022-02-04T19:59:26.651Z VERBOSE [nrfdl][trace](12:59:26.522) [NRFJPROG] [JLink] [None] - 0.523ms returns -1
    2022-02-04T19:59:26.652Z VERBOSE [nrfdl][trace](12:59:26.522) [NRFJPROG] [JLink] [None] JLINK_HasError()
    2022-02-04T19:59:26.653Z VERBOSE [nrfdl][trace](12:59:26.522) [NRFJPROG] [SeggerBackend] [Error] JLinkARM.dll reported "-1", "An unknown error.".
    2022-02-04T19:59:26.654Z VERBOSE [nrfdl][trace](12:59:26.522) [NRFJPROG] [JLink] [None] JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F)
    2022-02-04T19:59:26.655Z VERBOSE [nrfdl][trace](12:59:26.522) [NRFJPROG] [JLink] [None] - 0.556ms returns -1
    2022-02-04T19:59:26.655Z VERBOSE [nrfdl][trace](12:59:26.522) [NRFJPROG] [JLink] [None] JLINK_HasError()
    2022-02-04T19:59:26.656Z VERBOSE [nrfdl][trace](12:59:26.522) [NRFJPROG] [SeggerBackend] [Error] JLinkARM.dll reported "-1", "An unknown error.".
    2022-02-04T19:59:26.657Z VERBOSE [nrfdl][trace](12:59:26.522) [NRFJPROG] [JLink] [None] JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F)
    2022-02-04T19:59:26.658Z VERBOSE [nrfdl][trace](12:59:26.522) [NRFJPROG] [JLink] [None] - 0.491ms returns -1
    2022-02-04T19:59:26.658Z VERBOSE [nrfdl][trace](12:59:26.522) [NRFJPROG] [JLink] [None] JLINK_HasError()
    2022-02-04T19:59:26.660Z VERBOSE [nrfdl][trace](12:59:26.522) [NRFJPROG] [SeggerBackend] [Error] JLinkARM.dll reported "-1", "An unknown error.".
    2022-02-04T19:59:26.661Z VERBOSE [nrfdl][trace](12:59:26.522) [NRFJPROG] [JLink] [None] JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F)
    2022-02-04T19:59:26.662Z VERBOSE [nrfdl][trace](12:59:26.522) [NRFJPROG] [JLink] [None] - 0.510ms returns -1
    2022-02-04T19:59:26.663Z VERBOSE [nrfdl][trace](12:59:26.522) [NRFJPROG] [JLink] [None] JLINK_HasError()
    2022-02-04T19:59:26.664Z VERBOSE [nrfdl][trace](12:59:26.522) [NRFJPROG] [SeggerBackend] [Error] JLinkARM.dll reported "-1", "An unknown error.".
    2022-02-04T19:59:26.665Z VERBOSE [nrfdl][trace](12:59:26.522) [NRFJPROG] [JLink] [None] - 0.053ms
    2022-02-04T19:59:26.666Z VERBOSE [nrfdl][trace](12:59:26.522) [NRFJPROG] [Worker] [None] Command connect_to_emu_with_snr executed for 515 milliseconds with result -102
    2022-02-04T19:59:26.667Z VERBOSE [nrfdl][trace](12:59:26.522) [NRFJPROG] [nRFXX] [Debug] close
    2022-02-04T19:59:26.668Z VERBOSE [nrfdl][trace](12:59:26.522) [NRFJPROG] [SeggerBackend] [Debug] is_connected_to_emu
    2022-02-04T19:59:26.669Z VERBOSE [nrfdl][trace](12:59:26.522) [NRFJPROG] [JLink] [None] JLINK_IsOpen()
    2022-02-04T19:59:26.670Z VERBOSE [nrfdl][trace](12:59:26.522) [NRFJPROG] [JLink] [None] - 0.023ms returns 0x01
    2022-02-04T19:59:26.671Z VERBOSE [nrfdl][trace](12:59:26.522) [NRFJPROG] [JLink] [None] JLINK_HasError()
    2022-02-04T19:59:26.672Z VERBOSE [nrfdl][trace](12:59:26.522) [NRFJPROG] [JLink] [None] JLINK_Lock()
    2022-02-04T19:59:26.673Z VERBOSE [nrfdl][trace](12:59:26.522) [NRFJPROG] [SeggerBackend] [Debug] close
    2022-02-04T19:59:26.674Z VERBOSE [nrfdl][trace](12:59:26.522) [NRFJPROG] [SeggerBackend] [Debug] disconnect_from_emu
    2022-02-04T19:59:26.675Z VERBOSE [nrfdl][trace](12:59:26.522) [NRFJPROG] [SeggerBackend] [Debug] ---just_disconnect_from_emu
    2022-02-04T19:59:26.675Z VERBOSE [nrfdl][trace](12:59:26.522) [NRFJPROG] [SeggerBackend] [Debug] is_connected_to_device
    2022-02-04T19:59:26.676Z VERBOSE [nrfdl][trace](12:59:26.522) [NRFJPROG] [JLink] [None] JLINK_IsConnected()
    2022-02-04T19:59:26.677Z VERBOSE [nrfdl][trace](12:59:26.522) [NRFJPROG] [JLink] [None] - 0.022ms returns FALSE
    2022-02-04T19:59:26.678Z VERBOSE [nrfdl][trace](12:59:26.522) [NRFJPROG] [JLink] [None] JLINK_HasError()
    2022-02-04T19:59:26.680Z VERBOSE [nrfdl][trace](12:59:26.522) [NRFJPROG] [SeggerBackend] [Debug] ---just_is_debug_region_powered
    2022-02-04T19:59:26.681Z VERBOSE [nrfdl][trace](12:59:26.522) [NRFJPROG] [SeggerBackend] [Debug] ---just_read_debug_port_register
    2022-02-04T19:59:26.681Z VERBOSE [nrfdl][trace](12:59:26.522) [NRFJPROG] [SeggerBackend] [Debug] ---just_select_debug_port_register
    2022-02-04T19:59:26.682Z VERBOSE [nrfdl][trace](12:59:26.522) [NRFJPROG] [SeggerBackend] [Debug] Select AP 255, DP Bank 0, AP Bank 255
    2022-02-04T19:59:26.683Z VERBOSE [nrfdl][trace](12:59:26.522) [NRFJPROG] [JLink] [None] JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x02, 0x00000000)
    2022-02-04T19:59:26.684Z VERBOSE [nrfdl][trace](12:59:26.522) [NRFJPROG] [JLink] [None] - 0.506ms returns -1
    2022-02-04T19:59:26.685Z VERBOSE [nrfdl][trace](12:59:26.522) [NRFJPROG] [JLink] [None] JLINK_HasError()
    2022-02-04T19:59:26.686Z VERBOSE [nrfdl][trace](12:59:26.522) [NRFJPROG] [SeggerBackend] [Error] JLinkARM.dll reported "-1", "An unknown error.".
    2022-02-04T19:59:26.687Z VERBOSE [nrfdl][trace](12:59:26.522) [NRFJPROG] [SeggerBackend] [Debug] ---just_abort_debug_action
    2022-02-04T19:59:26.687Z VERBOSE [nrfdl][trace](12:59:26.522) [NRFJPROG] [SeggerBackend] [Debug] Attempting to clear any configuration errors in debug port before closing connection.
    2022-02-04T19:59:26.688Z VERBOSE [nrfdl][trace](12:59:26.522) [NRFJPROG] [JLink] [None] JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F)
    2022-02-04T19:59:26.689Z VERBOSE [nrfdl][trace](12:59:26.522) [NRFJPROG] [JLink] [None] - 0.521ms returns -1
    2022-02-04T19:59:26.690Z VERBOSE [nrfdl][trace](12:59:26.522) [NRFJPROG] [JLink] [None] JLINK_HasError()
    2022-02-04T19:59:26.690Z VERBOSE [nrfdl][trace](12:59:26.522) [NRFJPROG] [SeggerBackend] [Error] JLinkARM.dll reported "-1", "An unknown error.".
    2022-02-04T19:59:26.691Z VERBOSE [nrfdl][trace](12:59:26.533) [NRFJPROG] [JLink] [None] JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F)
    2022-02-04T19:59:26.692Z VERBOSE [nrfdl][trace](12:59:26.533) [NRFJPROG] [JLink] [None] - 0.520ms returns -1
    2022-02-04T19:59:26.693Z VERBOSE [nrfdl][trace](12:59:26.533) [NRFJPROG] [JLink] [None] JLINK_HasError()
    2022-02-04T19:59:26.695Z VERBOSE [nrfdl][trace](12:59:26.533) [NRFJPROG] [SeggerBackend] [Error] JLinkARM.dll reported "-1", "An unknown error.".
    2022-02-04T19:59:26.696Z VERBOSE [nrfdl][trace](12:59:26.533) [NRFJPROG] [JLink] [None] JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F)
    2022-02-04T19:59:26.697Z VERBOSE [nrfdl][trace](12:59:26.533) [NRFJPROG] [JLink] [None] - 0.520ms returns -1
    2022-02-04T19:59:26.698Z VERBOSE [nrfdl][trace](12:59:26.533) [NRFJPROG] [JLink] [None] JLINK_HasError()
    2022-02-04T19:59:26.698Z VERBOSE [nrfdl][trace](12:59:26.533) [NRFJPROG] [SeggerBackend] [Error] JLinkARM.dll reported "-1", "An unknown error.".
    2022-02-04T19:59:26.699Z VERBOSE [nrfdl][trace](12:59:26.533) [NRFJPROG] [JLink] [None] JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F)
    2022-02-04T19:59:26.700Z VERBOSE [nrfdl][trace](12:59:26.533) [NRFJPROG] [JLink] [None] - 0.562ms returns -1
    2022-02-04T19:59:26.701Z VERBOSE [nrfdl][trace](12:59:26.533) [NRFJPROG] [JLink] [None] JLINK_HasError()
    2022-02-04T19:59:26.702Z VERBOSE [nrfdl][trace](12:59:26.533) [NRFJPROG] [SeggerBackend] [Error] JLinkARM.dll reported "-1", "An unknown error.".
    2022-02-04T19:59:26.703Z VERBOSE [nrfdl][trace](12:59:26.533) [NRFJPROG] [JLink] [None] JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F)
    2022-02-04T19:59:26.707Z VERBOSE [nrfdl][trace](12:59:26.533) [NRFJPROG] [JLink] [None] - 0.444ms returns -1
    2022-02-04T19:59:26.708Z VERBOSE [nrfdl][trace](12:59:26.533) [NRFJPROG] [JLink] [None] JLINK_HasError()
    2022-02-04T19:59:26.709Z VERBOSE [nrfdl][trace](12:59:26.533) [NRFJPROG] [SeggerBackend] [Error] JLinkARM.dll reported "-1", "An unknown error.".
    2022-02-04T19:59:26.710Z VERBOSE [nrfdl][trace](12:59:26.533) [NRFJPROG] [JLink] [None] JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x02, 0x00000000)
    2022-02-04T19:59:26.711Z VERBOSE [nrfdl][trace](12:59:26.533) [NRFJPROG] [JLink] [None] - 0.618ms returns -1
    2022-02-04T19:59:26.712Z VERBOSE [nrfdl][trace](12:59:26.533) [NRFJPROG] [JLink] [None] JLINK_HasError()
    2022-02-04T19:59:26.713Z VERBOSE [nrfdl][trace](12:59:26.533) [NRFJPROG] [SeggerBackend] [Error] JLinkARM.dll reported "-1", "An unknown error.".
    2022-02-04T19:59:26.714Z VERBOSE [nrfdl][trace](12:59:26.533) [NRFJPROG] [SeggerBackend] [Debug] ---just_abort_debug_action
    2022-02-04T19:59:26.715Z VERBOSE [nrfdl][trace](12:59:26.533) [NRFJPROG] [SeggerBackend] [Debug] Attempting to clear any configuration errors in debug port before closing connection.
    2022-02-04T19:59:26.716Z VERBOSE [nrfdl][trace](12:59:26.533) [NRFJPROG] [JLink] [None] JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F)
    2022-02-04T19:59:26.717Z VERBOSE [nrfdl][trace](12:59:26.533) [NRFJPROG] [JLink] [None] - 0.537ms returns -1
    2022-02-04T19:59:26.718Z VERBOSE [nrfdl][trace](12:59:26.533) [NRFJPROG] [JLink] [None] JLINK_HasError()
    2022-02-04T19:59:26.719Z VERBOSE [nrfdl][trace](12:59:26.533) [NRFJPROG] [SeggerBackend] [Error] JLinkARM.dll reported "-1", "An unknown error.".
    2022-02-04T19:59:26.720Z VERBOSE [nrfdl][trace](12:59:26.533) [NRFJPROG] [JLink] [None] JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F)
    2022-02-04T19:59:26.721Z VERBOSE [nrfdl][trace](12:59:26.533) [NRFJPROG] [JLink] [None] - 0.577ms returns -1
    2022-02-04T19:59:26.723Z VERBOSE [nrfdl][trace](12:59:26.533) [NRFJPROG] [JLink] [None] JLINK_HasError()
    2022-02-04T19:59:26.724Z VERBOSE [nrfdl][trace](12:59:26.533) [NRFJPROG] [SeggerBackend] [Error] JLinkARM.dll reported "-1", "An unknown error.".
    2022-02-04T19:59:26.725Z VERBOSE [nrfdl][trace](12:59:26.533) [NRFJPROG] [JLink] [None] JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F)
    2022-02-04T19:59:26.726Z VERBOSE [nrfdl][trace](12:59:26.533) [NRFJPROG] [JLink] [None] - 0.533ms returns -1
    2022-02-04T19:59:26.727Z VERBOSE [nrfdl][trace](12:59:26.533) [NRFJPROG] [JLink] [None] JLINK_HasError()
    2022-02-04T19:59:26.728Z VERBOSE [nrfdl][trace](12:59:26.533) [NRFJPROG] [SeggerBackend] [Error] JLinkARM.dll reported "-1", "An unknown error.".
    2022-02-04T19:59:26.728Z VERBOSE [nrfdl][trace](12:59:26.533) [NRFJPROG] [JLink] [None] JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F)
    2022-02-04T19:59:26.729Z VERBOSE [nrfdl][trace](12:59:26.533) [NRFJPROG] [JLink] [None] - 0.500ms returns -1
    2022-02-04T19:59:26.730Z VERBOSE [nrfdl][trace](12:59:26.533) [NRFJPROG] [JLink] [None] JLINK_HasError()
    2022-02-04T19:59:26.731Z VERBOSE [nrfdl][trace](12:59:26.533) [NRFJPROG] [SeggerBackend] [Error] JLinkARM.dll reported "-1", "An unknown error.".
    2022-02-04T19:59:26.731Z VERBOSE [nrfdl][trace](12:59:26.533) [NRFJPROG] [JLink] [None] JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F)
    2022-02-04T19:59:26.732Z VERBOSE [nrfdl][trace](12:59:26.533) [NRFJPROG] [JLink] [None] - 0.497ms returns -1
    2022-02-04T19:59:26.733Z VERBOSE [nrfdl][trace](12:59:26.533) [NRFJPROG] [JLink] [None] JLINK_HasError()
    2022-02-04T19:59:26.733Z VERBOSE [nrfdl][trace](12:59:26.533) [NRFJPROG] [SeggerBackend] [Error] JLinkARM.dll reported "-1", "An unknown error.".
    2022-02-04T19:59:26.734Z VERBOSE [nrfdl][trace](12:59:26.533) [NRFJPROG] [JLink] [None] JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x02, 0x00000000)
    2022-02-04T19:59:26.735Z VERBOSE [nrfdl][trace](12:59:26.533) [NRFJPROG] [JLink] [None] - 0.494ms returns -1
    2022-02-04T19:59:26.736Z VERBOSE [nrfdl][trace](12:59:26.533) [NRFJPROG] [JLink] [None] JLINK_HasError()
    2022-02-04T19:59:26.737Z VERBOSE [nrfdl][trace](12:59:26.533) [NRFJPROG] [SeggerBackend] [Error] JLinkARM.dll reported "-1", "An unknown error.".
    2022-02-04T19:59:26.737Z VERBOSE [nrfdl][trace](12:59:26.533) [NRFJPROG] [SeggerBackend] [Debug] ---just_abort_debug_action
    2022-02-04T19:59:26.738Z VERBOSE [nrfdl][trace](12:59:26.533) [NRFJPROG] [SeggerBackend] [Debug] Attempting to clear any configuration errors in debug port before closing connection.
    2022-02-04T19:59:26.739Z VERBOSE [nrfdl][trace](12:59:26.533) [NRFJPROG] [JLink] [None] JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F)
    2022-02-04T19:59:26.740Z VERBOSE [nrfdl][trace](12:59:26.533) [NRFJPROG] [JLink] [None] - 0.482ms returns -1
    2022-02-04T19:59:26.741Z VERBOSE [nrfdl][trace](12:59:26.533) [NRFJPROG] [JLink] [None] JLINK_HasError()
    2022-02-04T19:59:26.742Z VERBOSE [nrfdl][trace](12:59:26.533) [NRFJPROG] [SeggerBackend] [Error] JLinkARM.dll reported "-1", "An unknown error.".
    2022-02-04T19:59:26.743Z VERBOSE [nrfdl][trace](12:59:26.533) [NRFJPROG] [JLink] [None] JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F)
    2022-02-04T19:59:26.744Z VERBOSE [nrfdl][trace](12:59:26.533) [NRFJPROG] [JLink] [None] - 0.510ms returns -1
    2022-02-04T19:59:26.745Z VERBOSE [nrfdl][trace](12:59:26.533) [NRFJPROG] [JLink] [None] JLINK_HasError()
    2022-02-04T19:59:26.745Z VERBOSE [nrfdl][trace](12:59:26.533) [NRFJPROG] [SeggerBackend] [Error] JLinkARM.dll reported "-1", "An unknown error.".
    2022-02-04T19:59:26.746Z VERBOSE [nrfdl][trace](12:59:26.533) [NRFJPROG] [JLink] [None] JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F)
    2022-02-04T19:59:26.747Z VERBOSE [nrfdl][trace](12:59:26.533) [NRFJPROG] [JLink] [None] - 0.526ms returns -1
    2022-02-04T19:59:26.747Z VERBOSE [nrfdl][trace](12:59:26.533) [NRFJPROG] [JLink] [None] JLINK_HasError()
    2022-02-04T19:59:26.748Z VERBOSE [nrfdl][trace](12:59:26.533) [NRFJPROG] [SeggerBackend] [Error] JLinkARM.dll reported "-1", "An unknown error.".
    2022-02-04T19:59:26.749Z VERBOSE [nrfdl][trace](12:59:26.533) [NRFJPROG] [JLink] [None] JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F)
    2022-02-04T19:59:26.749Z VERBOSE [nrfdl][trace](12:59:26.533) [NRFJPROG] [JLink] [None] - 0.499ms returns -1
    2022-02-04T19:59:26.750Z VERBOSE [nrfdl][trace](12:59:26.533) [NRFJPROG] [JLink] [None] JLINK_HasError()
    2022-02-04T19:59:26.751Z VERBOSE [nrfdl][trace](12:59:26.533) [NRFJPROG] [SeggerBackend] [Error] JLinkARM.dll reported "-1", "An unknown error.".
    2022-02-04T19:59:26.752Z VERBOSE [nrfdl][trace](12:59:26.533) [NRFJPROG] [JLink] [None] JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F)
    2022-02-04T19:59:26.752Z VERBOSE [nrfdl][trace](12:59:26.533) [NRFJPROG] [JLink] [None] - 0.519ms returns -1
    2022-02-04T19:59:26.753Z VERBOSE [nrfdl][trace](12:59:26.533) [NRFJPROG] [JLink] [None] JLINK_HasError()
    2022-02-04T19:59:26.754Z VERBOSE [nrfdl][trace](12:59:26.533) [NRFJPROG] [SeggerBackend] [Error] JLinkARM.dll reported "-1", "An unknown error.".
    2022-02-04T19:59:26.754Z VERBOSE [nrfdl][trace](12:59:26.533) [NRFJPROG] [JLink] [None] JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x02, 0x00000000)
    2022-02-04T19:59:26.756Z VERBOSE [nrfdl][trace](12:59:26.533) [NRFJPROG] [JLink] [None] - 0.530ms returns -1
    2022-02-04T19:59:26.757Z VERBOSE [nrfdl][trace](12:59:26.533) [NRFJPROG] [JLink] [None] JLINK_HasError()
    2022-02-04T19:59:26.757Z VERBOSE [nrfdl][trace](12:59:26.533) [NRFJPROG] [SeggerBackend] [Error] JLinkARM.dll reported "-1", "An unknown error.".
    2022-02-04T19:59:26.758Z VERBOSE [nrfdl][trace](12:59:26.534) [NRFJPROG] [SeggerBackend] [Debug] ---just_abort_debug_action
    2022-02-04T19:59:26.759Z VERBOSE [nrfdl][trace](12:59:26.534) [NRFJPROG] [SeggerBackend] [Debug] Attempting to clear any configuration errors in debug port before closing connection.
    2022-02-04T19:59:26.760Z VERBOSE [nrfdl][trace](12:59:26.534) [NRFJPROG] [JLink] [None] JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F)
    2022-02-04T19:59:26.762Z VERBOSE [nrfdl][trace](12:59:26.534) [NRFJPROG] [JLink] [None] - 0.457ms returns -1
    2022-02-04T19:59:26.763Z VERBOSE [nrfdl][trace](12:59:26.534) [NRFJPROG] [JLink] [None] JLINK_HasError()
    2022-02-04T19:59:26.764Z VERBOSE [nrfdl][trace](12:59:26.534) [NRFJPROG] [SeggerBackend] [Error] JLinkARM.dll reported "-1", "An unknown error.".
    2022-02-04T19:59:26.764Z VERBOSE [nrfdl][trace](12:59:26.534) [NRFJPROG] [JLink] [None] JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F)
    2022-02-04T19:59:26.765Z VERBOSE [nrfdl][trace](12:59:26.548) [NRFJPROG] [JLink] [None] - 0.552ms returns -1
    2022-02-04T19:59:26.766Z VERBOSE [nrfdl][trace](12:59:26.548) [NRFJPROG] [JLink] [None] JLINK_HasError()
    2022-02-04T19:59:26.767Z VERBOSE [nrfdl][trace](12:59:26.548) [NRFJPROG] [SeggerBackend] [Error] JLinkARM.dll reported "-1", "An unknown error.".
    2022-02-04T19:59:26.767Z VERBOSE [nrfdl][trace](12:59:26.548) [NRFJPROG] [JLink] [None] JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F)
    2022-02-04T19:59:26.768Z VERBOSE [nrfdl][trace](12:59:26.548) [NRFJPROG] [JLink] [None] - 0.531ms returns -1
    2022-02-04T19:59:26.769Z VERBOSE [nrfdl][trace](12:59:26.548) [NRFJPROG] [JLink] [None] JLINK_HasError()
    2022-02-04T19:59:26.770Z VERBOSE [nrfdl][trace](12:59:26.548) [NRFJPROG] [SeggerBackend] [Error] JLinkARM.dll reported "-1", "An unknown error.".
    2022-02-04T19:59:26.770Z VERBOSE [nrfdl][trace](12:59:26.548) [NRFJPROG] [JLink] [None] JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F)
    2022-02-04T19:59:26.771Z VERBOSE [nrfdl][trace](12:59:26.548) [NRFJPROG] [JLink] [None] - 0.667ms returns -1
    2022-02-04T19:59:26.772Z VERBOSE [nrfdl][trace](12:59:26.548) [NRFJPROG] [JLink] [None] JLINK_HasError()
    2022-02-04T19:59:26.773Z VERBOSE [nrfdl][trace](12:59:26.548) [NRFJPROG] [SeggerBackend] [Error] JLinkARM.dll reported "-1", "An unknown error.".
    2022-02-04T19:59:26.774Z VERBOSE [nrfdl][trace](12:59:26.548) [NRFJPROG] [JLink] [None] JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F)
    2022-02-04T19:59:26.775Z VERBOSE [nrfdl][trace](12:59:26.548) [NRFJPROG] [JLink] [None] - 0.547ms returns -1
    2022-02-04T19:59:26.775Z VERBOSE [nrfdl][trace](12:59:26.548) [NRFJPROG] [JLink] [None] JLINK_HasError()
    2022-02-04T19:59:26.776Z VERBOSE [nrfdl][trace](12:59:26.548) [NRFJPROG] [SeggerBackend] [Error] JLinkARM.dll reported "-1", "An unknown error.".
    2022-02-04T19:59:26.777Z VERBOSE [nrfdl][trace](12:59:26.548) [NRFJPROG] [JLink] [None] JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x02, 0x00000000)
    2022-02-04T19:59:26.778Z VERBOSE [nrfdl][trace](12:59:26.548) [NRFJPROG] [JLink] [None] - 0.525ms returns -1
    2022-02-04T19:59:26.778Z VERBOSE [nrfdl][trace](12:59:26.548) [NRFJPROG] [JLink] [None] JLINK_HasError()
    2022-02-04T19:59:26.779Z VERBOSE [nrfdl][trace](12:59:26.548) [NRFJPROG] [SeggerBackend] [Error] JLinkARM.dll reported "-1", "An unknown error.".
    2022-02-04T19:59:26.780Z VERBOSE [nrfdl][trace](12:59:26.548) [NRFJPROG] [SeggerBackend] [Debug] ---just_abort_debug_action
    2022-02-04T19:59:26.780Z VERBOSE [nrfdl][trace](12:59:26.548) [NRFJPROG] [SeggerBackend] [Debug] Attempting to clear any configuration errors in debug port before closing connection.
    2022-02-04T19:59:26.781Z VERBOSE [nrfdl][trace](12:59:26.548) [NRFJPROG] [JLink] [None] JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F)
    2022-02-04T19:59:26.782Z VERBOSE [nrfdl][trace](12:59:26.548) [NRFJPROG] [JLink] [None] - 0.496ms returns -1
    2022-02-04T19:59:26.783Z VERBOSE [nrfdl][trace](12:59:26.548) [NRFJPROG] [JLink] [None] JLINK_HasError()
    2022-02-04T19:59:26.784Z VERBOSE [nrfdl][trace](12:59:26.548) [NRFJPROG] [SeggerBackend] [Error] JLinkARM.dll reported "-1", "An unknown error.".
    2022-02-04T19:59:26.785Z VERBOSE [nrfdl][trace](12:59:26.548) [NRFJPROG] [JLink] [None] JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F)
    2022-02-04T19:59:26.785Z VERBOSE [nrfdl][trace](12:59:26.548) [NRFJPROG] [JLink] [None] - 0.520ms returns -1
    2022-02-04T19:59:26.786Z VERBOSE [nrfdl][trace](12:59:26.548) [NRFJPROG] [JLink] [None] JLINK_HasError()
    2022-02-04T19:59:26.787Z VERBOSE [nrfdl][trace](12:59:26.548) [NRFJPROG] [SeggerBackend] [Error] JLinkARM.dll reported "-1", "An unknown error.".
    2022-02-04T19:59:26.788Z VERBOSE [nrfdl][trace](12:59:26.548) [NRFJPROG] [JLink] [None] JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F)
    2022-02-04T19:59:26.789Z VERBOSE [nrfdl][trace](12:59:26.548) [NRFJPROG] [JLink] [None] - 0.506ms returns -1
    2022-02-04T19:59:26.790Z VERBOSE [nrfdl][trace](12:59:26.548) [NRFJPROG] [JLink] [None] JLINK_HasError()
    2022-02-04T19:59:26.791Z VERBOSE [nrfdl][trace](12:59:26.548) [NRFJPROG] [SeggerBackend] [Error] JLinkARM.dll reported "-1", "An unknown error.".
    2022-02-04T19:59:26.791Z VERBOSE [nrfdl][trace](12:59:26.548) [NRFJPROG] [JLink] [None] JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F)
    2022-02-04T19:59:26.792Z VERBOSE [nrfdl][trace](12:59:26.548) [NRFJPROG] [JLink] [None] - 0.562ms returns -1
    2022-02-04T19:59:26.793Z VERBOSE [nrfdl][trace](12:59:26.548) [NRFJPROG] [JLink] [None] JLINK_HasError()
    2022-02-04T19:59:26.793Z VERBOSE [nrfdl][trace](12:59:26.548) [NRFJPROG] [SeggerBackend] [Error] JLinkARM.dll reported "-1", "An unknown error.".
    2022-02-04T19:59:26.794Z VERBOSE [nrfdl][trace](12:59:26.548) [NRFJPROG] [JLink] [None] JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F)
    2022-02-04T19:59:26.795Z VERBOSE [nrfdl][trace](12:59:26.548) [NRFJPROG] [JLink] [None] - 0.517ms returns -1
    2022-02-04T19:59:26.795Z VERBOSE [nrfdl][trace](12:59:26.548) [NRFJPROG] [JLink] [None] JLINK_HasError()
    2022-02-04T19:59:26.796Z VERBOSE [nrfdl][trace](12:59:26.548) [NRFJPROG] [SeggerBackend] [Error] JLinkARM.dll reported "-1", "An unknown error.".
    2022-02-04T19:59:26.797Z VERBOSE [nrfdl][trace](12:59:26.548) [NRFJPROG] [JLink] [None] - 0.091ms
    2022-02-04T19:59:26.797Z VERBOSE [nrfdl][trace](12:59:26.558) [NRFJPROG] [JLink] [None] JLINK_Close()
    2022-02-04T19:59:26.798Z VERBOSE [nrfdl][trace](12:59:26.581) [NRFJPROG] [SeggerBackend] [Debug] Segger Backend closed.
    2022-02-04T19:59:26.799Z VERBOSE [nrfdl][trace](12:59:26.581) [NRFJPROG] [nRFXX] [Debug] nRF family DLL closed
    2022-02-04T19:59:26.800Z VERBOSE [nrfdl][trace](12:59:26.597) [NRFJPROG] [Client] [None] Command close executed for 76 milliseconds with result 0
    2022-02-04T19:59:26.800Z VERBOSE [nrfdl][trace](12:59:26.597) [NRFJPROG] [Client] [Debug] terminate
    2022-02-04T19:59:26.801Z VERBOSE [nrfdl][trace](12:59:26.597) [NRFJPROG] [Client] [None] Command terminate executed for 0 milliseconds with result 0
    2022-02-04T19:59:26.802Z VERBOSE [nrfdl][trace](12:59:26.598) [NRFJPROG] [Worker] [None] Command close executed for 76 milliseconds with result 0
    2022-02-04T19:59:26.803Z VERBOSE [nrfdl][trace](12:59:26.613) [NRFJPROG] [Worker] [None] Command terminate executed for 0 milliseconds with result 0
    2022-02-04T19:59:26.803Z VERBOSE [nrfdl][trace](12:59:26.613) [NRFJPROG] [Worker] [None] Executed 4 commands for 621 milliseconds
    2022-02-04T19:59:26.805Z VERBOSE [nrfdl][trace](12:59:26.638) [NRFJPROG] [Client] [Debug] Worker process exited with code: 0
    2022-02-04T19:59:26.806Z VERBOSE [nrfdl][trace](12:59:26.638) [NRFJPROG] [Client] [Debug] Worker process exited with code: 0
    2022-02-04T19:59:26.806Z VERBOSE [nrfdl][trace](12:59:26.640) [NRFJPROG] [Client] [Debug] Child process terminated with result 0
    2022-02-04T19:59:26.807Z VERBOSE [nrfdl][trace](12:59:26.714) [NRFJPROG] [Client] [None] Executed 4 commands for 772 milliseconds
    2022-02-04T19:59:26.808Z VERBOSE [nrfdl][trace](12:59:26.714) [NRFJPROG] [Client] [Debug] terminate
    2022-02-04T19:59:26.809Z VERBOSE [nrfdl][trace](12:59:26.722) [NRFJPROG] [DebugProbe] [Debug] uninitialize
    2022-02-04T19:59:26.809Z VERBOSE [nrfdl][trace](12:59:26.722) [NRFJPROG] [HighLevel] [Error] Failed while initializing probe
    2022-02-04T19:59:26.810Z DEBUG [nrfdl][debug](12:59:26.722) nrfjprog_function return value: -102
    2022-02-04T19:59:26.811Z ERROR [nrfdl][error](12:59:26.722) JLink ignore error -102 for serialnumber 001015000264 and continue
    2022-02-04T19:59:26.811Z VERBOSE [nrfdl][trace](12:59:26.722) [NRFJPROG] [HighLevel] [Debug] dll_close
    2022-02-04T19:59:26.812Z VERBOSE [nrfdl][trace](12:59:26.722) [NRFJPROG] [HighLevel] [Info] Closing and freeing sub dlls.
    2022-02-04T19:59:26.915Z DEBUG [nrfdl][debug](12:59:26.914) [<-] NRFDL::UniversalPlatform::JLinkHW::enumerate [took 1525ms]
    2022-02-04T19:59:26.918Z VERBOSE [nrfdl][trace](12:59:26.914) DeviceLister::enumerate: Enumerating with sync lister
    2022-02-04T19:59:26.920Z VERBOSE [nrfdl][trace](12:59:26.914) BrokenLister::enumerate
    2022-02-04T19:59:26.921Z VERBOSE [nrfdl][trace](12:59:26.914) DeviceLister::enumerate: Found device with serial number: FT5OMIES
    2022-02-04T19:59:26.922Z VERBOSE [nrfdl][trace](12:59:26.914) DeviceLister::enumerate: device registered to device list
    2022-02-04T19:59:26.923Z VERBOSE [nrfdl][trace](12:59:26.914) DeviceLister::enumerate: Found device with serial number: {63625DD5-77E3-11EC-9DA9-D4D252955827}
    2022-02-04T19:59:26.924Z VERBOSE [nrfdl][trace](12:59:26.914) DeviceLister::enumerate: Found device with serial number: FT5OMITZ
    2022-02-04T19:59:26.925Z VERBOSE [nrfdl][trace](12:59:26.914) DeviceLister::enumerate: device registered to device list
    2022-02-04T19:59:26.925Z VERBOSE [nrfdl][trace](12:59:26.914) DeviceLister::enumerate: Found device with serial number: 0024001C3156501920323443
    2022-02-04T19:59:26.927Z VERBOSE [nrfdl][trace](12:59:26.914) DeviceLister::enumerate: device registered to device list
    2022-02-04T19:59:26.927Z VERBOSE [nrfdl][trace](12:59:26.914) DeviceLister::enumerate: Found device with serial number: {00000000-0000-0000-FFFF-FFFFFFFFFFFF}
    2022-02-04T19:59:26.928Z VERBOSE [nrfdl][trace](12:59:26.914) DeviceLister::enumerate: device registered to device list
    2022-02-04T19:59:26.929Z VERBOSE [nrfdl][trace](12:59:26.914) DeviceLister::enumerate: Found device with serial number: {00000000-0000-0000-FFFF-FFFFFFFFFFFF}
    2022-02-04T19:59:26.930Z VERBOSE [nrfdl][trace](12:59:26.914) DeviceLister::enumerate: Found device with serial number: {13F3CBD4-FCA9-54C2-8577-8006E01F7F4D}
    2022-02-04T19:59:26.931Z VERBOSE [nrfdl][trace](12:59:26.914) DeviceLister::enumerate: Found device with serial number: 001015000264
    2022-02-04T19:59:26.932Z VERBOSE [nrfdl][trace](12:59:26.914) DeviceLister::enumerate: device registered to device list
    2022-02-04T19:59:26.933Z VERBOSE [nrfdl][trace](12:59:26.914) DeviceLister::enumerate: Found device with serial number: {94190868-251F-11EC-9D91-D4D25295582A}
    2022-02-04T19:59:26.934Z VERBOSE [nrfdl][trace](12:59:26.914) DeviceLister::enumerate: Found device with serial number: {D8631B00-9684-5861-B614-BDFCD3ACA8D4}
    2022-02-04T19:59:26.936Z VERBOSE [nrfdl][trace](12:59:26.914) DeviceLister::enumerate: Found device with serial number: {00000000-0000-0000-FFFF-FFFFFFFFFFFF}
    2022-02-04T19:59:26.937Z VERBOSE [nrfdl][trace](12:59:26.914) DeviceLister::enumerate: device registered to device list
    2022-02-04T19:59:26.938Z VERBOSE [nrfdl][trace](12:59:26.914) DeviceLister::enumerate: Completed waiting for enumerate task
    2022-02-04T19:59:26.939Z VERBOSE [nrfdl][trace](12:59:26.914) DeviceLister::enumerate: done
    2022-02-04T19:59:28.103Z DEBUG iface: Ethernet
    2022-02-04T19:59:28.103Z DEBUG IP4:
    2022-02-04T19:59:28.103Z DEBUG IP6:
    2022-02-04T19:59:28.103Z DEBUG MAC: 98:fa:9b:52:5b:31
    2022-02-04T19:59:28.104Z DEBUG Client Id: b9e8e0f1b35388a537ee8d2efd6496a0d1bdff5e
    2022-02-04T19:59:28.105Z DEBUG Google Analytics for category pc-nrfconnect-programmer has initialized
    2022-02-04T19:59:33.090Z ERROR Unsupported device.
    The detected device could not be recognized as
    neither JLink device nor Nordic USB device.
    2022-02-04T19:59:33.098Z VERBOSE [nrfdl][trace](12:59:33.090) DeviceLister::enumerate: Checking future_status of enumerate_task_status
    2022-02-04T19:59:33.099Z VERBOSE [nrfdl][trace](12:59:33.090) DeviceLister::enumerate: Waiting for enumerate task to complete
    2022-02-04T19:59:33.100Z VERBOSE [nrfdl][trace](12:59:33.090) DeviceLister::enumerate::enumerate_task: Start
    2022-02-04T19:59:33.101Z VERBOSE [nrfdl][trace](12:59:33.090) DeviceLister::enumerate: Found device with serial number: FT5OMIES
    2022-02-04T19:59:33.102Z VERBOSE [nrfdl][trace](12:59:33.090) DeviceLister::enumerate: device registered to device list
    2022-02-04T19:59:33.103Z VERBOSE [nrfdl][trace](12:59:33.090) DeviceLister::enumerate: Found device with serial number: {63625DD5-77E3-11EC-9DA9-D4D252955827}
    2022-02-04T19:59:33.104Z VERBOSE [nrfdl][trace](12:59:33.090) DeviceLister::enumerate: Found device with serial number: FT5OMITZ
    2022-02-04T19:59:33.105Z VERBOSE [nrfdl][trace](12:59:33.090) DeviceLister::enumerate: device registered to device list
    2022-02-04T19:59:33.106Z VERBOSE [nrfdl][trace](12:59:33.090) DeviceLister::enumerate: Found device with serial number: 0024001C3156501920323443
    2022-02-04T19:59:33.107Z VERBOSE [nrfdl][trace](12:59:33.090) DeviceLister::enumerate: device registered to device list
    2022-02-04T19:59:33.108Z VERBOSE [nrfdl][trace](12:59:33.090) DeviceLister::enumerate: Found device with serial number: {00000000-0000-0000-FFFF-FFFFFFFFFFFF}
    2022-02-04T19:59:33.109Z VERBOSE [nrfdl][trace](12:59:33.090) DeviceLister::enumerate: device registered to device list
    2022-02-04T19:59:33.109Z VERBOSE [nrfdl][trace](12:59:33.090) DeviceLister::enumerate: Found device with serial number: {00000000-0000-0000-FFFF-FFFFFFFFFFFF}
    2022-02-04T19:59:33.110Z VERBOSE [nrfdl][trace](12:59:33.090) DeviceLister::enumerate: Found device with serial number: {13F3CBD4-FCA9-54C2-8577-8006E01F7F4D}
    2022-02-04T19:59:33.111Z VERBOSE [nrfdl][trace](12:59:33.090) DeviceLister::enumerate: Found device with serial number: 001015000264
    2022-02-04T19:59:33.112Z VERBOSE [nrfdl][trace](12:59:33.090) DeviceLister::enumerate: device registered to device list
    2022-02-04T19:59:33.112Z VERBOSE [nrfdl][trace](12:59:33.090) DeviceLister::enumerate: Found device with serial number: {94190868-251F-11EC-9D91-D4D25295582A}
    2022-02-04T19:59:33.113Z VERBOSE [nrfdl][trace](12:59:33.090) DeviceLister::enumerate: Found device with serial number: {D8631B00-9684-5861-B614-BDFCD3ACA8D4}
    2022-02-04T19:59:33.114Z VERBOSE [nrfdl][trace](12:59:33.090) DeviceLister::enumerate: Found device with serial number: {00000000-0000-0000-FFFF-FFFFFFFFFFFF}
    2022-02-04T19:59:33.115Z VERBOSE [nrfdl][trace](12:59:33.090) DeviceLister::enumerate: device registered to device list
    2022-02-04T19:59:33.116Z VERBOSE [nrfdl][trace](12:59:33.090) DeviceLister::enumerate: Completed waiting for enumerate task
    2022-02-04T19:59:33.117Z VERBOSE [nrfdl][trace](12:59:33.090) DeviceLister::enumerate: done
    I have forwarded the log to the developers, and I will update you on what they find.
    Marte
    According to the developers we do not support the Flasher series devices from Segger in our software tools as they are production programming oriented.
    Marte
  • Hi Marte,
    Since we will need to flash boards with nRF9160 chips in a mass volume production setting, how does Nordic recommend we do this? Is it possible to flash multiple targets connected to the same computer simultaneously?
