Hi
This is the first time I have tried to use the nrf52840 dongle and the programmer v2.3.1, it can see the dongle( com10), but as soon as I select Device tis is the response I get from the log?
Can Anyone help please
Regards
David
Hi
Regards
David
Hi
I see this suggestion wasn't added in my last reply, but you have a rather old J-Link version installed according to the programmer app, can you try downloading the latest version to see if that helps? Does the DK work as expected with the nRFConnect apps on your computer? It sounds strange that it should slow your computer that much, is your computer by chance very old? Can you also describe how the Dongle is behaving when plugged in, is it pulsing red or behaving differently somehow?
Simon
Hi Simon
My Computer is very new AMD Ryzen 9 3900X, I have just downloaded the latest version of JLINK V7.6 installed fine, started up Programmer and still the log shows JLink version: JLink_V6.88a.
V7.6 is in C:\Program Files\SEGGER\JLink but programmer seems to be looking elsewhere.
Kind Regards
David
Hi Simon
I have now updated the Jlink the problem was Segger's default directory is C:/Program Files, but nRF Connect for Desktops default directory is C:/Program Files(x86).
Unfortunately though the problem still exists.
Kind Regards
David
Okay, can you explain what exactly you mean by the computer slowing down when using the DK? And does the DK work as intended or not?
There was a similar error in older nRFConnect versions (v3.8.0) with the same readFWinfo error, but we haven't seen this issue with the latest versions, but I guess you can try the workaround(s) described here: https://devzone.nordicsemi.com/f/nordic-q-a/81989/error-when-fetching-device-versions-readfwinfo-error/340278#340278
Simon
