I have been developing some products over the nRF51822 BLE. Got my introduction with nRF about 2 months back and despite the steep learning curve I was able to integrate the softdevice with LESC passkey and some GPIO peripheral control for a BLE Lock product. NRF team has been a GREAT HELP.
Now I want to add one more peripheral that is a 125KHz RFID card reader. I have figured out the hardware for the same. It basically fires a 125KHz to the coil and depending on the load from RFID card, a data stream of one and zero is received from a comparator.
Refer this link https://www.serasidis.gr/circuits/RFID_reader/125kHz_RFID_reader.htm
I basically want to integrate this using the nordic mcu.
I figured out the PWM output using the app__pwm example. I am a bit stuck on capturing the waveform. I get that I have to start the timer in counter mode triggered by one GPIO but I am not able to do this along with the softdevice running in parellel.
Please let me know of any literature available or any example for the same.
What I had done so far :
1. BLE stack along with peer manager is working perfectly
2. A couple of notify and write characteristics are available to take care of the peripherals.
3. I have used two timers so far, one for the SD and one 100ms to do all my control related tasks.
4. I was able to generate a 125KHz PWM on one GPIO.
What I need to do :
To capture the pulses on one GPIO (pin P0.07 in my case). How I perceive this is that I can make an array to store the capture values and then process it any time. Let me know if I am looking at this in a wrong way.
Peripherals used so far :
/*****/control task timmer
APP_TIMER_INIT(0, 4, false);
err_code = app_timer_create(&m_control_timer_id,
APP_TIMER_MODE_REPEATED,
control_timeout_handler);
err_code = app_timer_start(m_control_timer_id, APP_TIMER_TICKS(100, 0), NULL);
/*****/peer manager timer
uint32_t err_code = app_timer_create(&m_sec_req_timer_id,
APP_TIMER_MODE_SINGLE_SHOT,
err_code = app_timer_start(m_sec_req_timer_id, SECURITY_REQUEST_DELAY, NULL);
sec_req_timeout_handler);
/*****/pwm output
app_pwm_config_t pwm1_cfg = APP_PWM_DEFAULT_CONFIG_1CH(8L, MCU1); // 125KHz on MCU1 pin
err_code = app_pwm_init(&PWM1,&pwm1_cfg,NULL);
app_pwm_enable(&PWM1);
app_pwm_channel_duty_set(&PWM1, 0, 50); //set initial duty as zero (instanct, channel, !duty)
/*****/general GPIOs on about 6 pins that are handled accross the code.I also got to know about the PPI+timer+gpiote method but I was not able to get it running.
Also for me power consumption is very critical since it is a battery operated device. Any extra hardware uses a lot of power as I observed so I want to make it very minimal.(< 0.5mA total during idle operation).
Thanks & Regards
