Using RTT and RTT terminal under VS Code
When using RTT for debugging on the nRF5340, after every flash i have to press the following button:
Then every time i get presented with the following dialog:
Then followed by:
Where i have to manually find and choose the correct part
This can be very time consuming as i have to do it again after everytime i flash the part during debug
How can i set VS Code/JLink tools to automatically select the part so the RTT will work as soon as i press the button?
Also, how do we clear the contents of the nRF Terminal if we want to start afresh? I cannot find a clear option anywhere (and under windows the copy/paste does not work from the nRF terminal)
Many thanks
    This feature was added in the last version of nRF Terminal that was released just yesterday, so if you update the extension and reload VS Code you should be able to use the feature. You can either do it by clicking the clear button next to the RTT or serial port connection:
    Or you can use command palette and write nRF Terminal: Clear.
    I have asked the developers if there is a simpler way to do this or if it is possible to add a feature where you can select the core directly in VS Code instead of having to go through the target device settings. I am still waiting for a response to this, and I will update you when I hear back from them.
    Marte
    The behavior when connecting to RTT is caused by how the extension gets the device name. In the extension, the device name is retrieved from the device version returned by nrfjprog, which also includes the revision of the chip, e.g. _ENGD, _REV2 etc. Segger does not handle revisions and only use the general device name. This causes inconsistencies between the name provided by the VS Code extension when connecting to RTT and the device name used by Segger. The developers are looking into options on how to solve this.
    Marte
  • Hi, I find it quite time consuming as well, to always have to manually select the device.
    This ticket is almost 4 years old. If you are experiencing issues, please create a new ticket.
    Marte
  • it is inappropriate to say to open a new ticket. It may be 4 years old, but it still isn't fixed! This worked in SEGGER years and years ago; there is a fundamental expectation for this to work for nRF52, 53, 54, etc. Nordic don't need users to tell it their own dev kit revision ids!
    It is basic missing behavior that is contributing to the recommendation not to use this chipset and this software.
