NRFX_SPIM and Buttons don't work together?
I'm running into a frustrating issue where I can get the NRFX_SPIM and my own BSP examples to work, but when I try to combine them - the buttons stop triggering their interrupt handlers. At first, I thought I was overwriting the GPIO button pins but after looking at pca10056.h, that doesn't seem to be the problem.
I am using an nrf52840 dev kit, starting with the nrfx_spim example and adding button support code from the ble_app_blinky. The resulting main is below:
 * Copyright (c) 2017 - 2021, Nordic Semiconductor ASA
#include <stdint.h>
#include "nordic_common.h"
#include "nrf.h"
#include "app_timer.h"
#include "app_button.h"
#include "nrfx_spim.h"
#include "nrf_gpio.h"
#include "nrf_delay.h"
#include "boards.h"
#include "app_error.h"
#include <string.h>
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
#define NRFX_SPIM_SCK_PIN  3
#define NRFX_SPIM_MOSI_PIN 4
#define NRFX_SPIM_MISO_PIN 28
#define NRFX_SPIM_SS_PIN   29
#define NRFX_SPIM_DCX_PIN  30
#define BUTTON_DETECTION_DELAY          APP_TIMER_TICKS(100)
    // APP_SPIS_CS_PIN 31
    // APP_SPIS_MISO_PIN 30
    // APP_SPIS_MOSI_PIN 29
    // APP_SPIS_SCK_PIN 26
#define SPI_INSTANCE  3                                           /**< SPI instance index. */
static const nrfx_spim_t spi = NRFX_SPIM_INSTANCE(SPI_INSTANCE);  /**< SPI instance. */
static volatile bool spi_xfer_done;  /**< Flag used to indicate that SPI instance completed the transfer. */
#define TEST_STRING "Nordic123456789012345678901234567890"
static uint8_t       m_tx_buf[] = TEST_STRING;           /**< TX buffer. */
static uint8_t       m_rx_buf[sizeof(TEST_STRING) + 1];  /**< RX buffer. */
static const uint8_t m_length = sizeof(m_tx_buf);        /**< Transfer length. */
void spim_event_handler(nrfx_spim_evt_t const * p_event,
                       void *                  p_context)
    spi_xfer_done = true;
    NRF_LOG_INFO("Transfer completed.");
    if (m_rx_buf[0] != 0)
        NRF_LOG_INFO(" Received:");
        NRF_LOG_HEXDUMP_INFO(m_rx_buf, strlen((const char *)m_rx_buf));
static void log_init(void)
static void button_event_handler(uint8_t pin_no, uint8_t button_action)
    ret_code_t err_code;
    switch (pin_no)
        case BSP_BUTTON_0:
            NRF_LOG_INFO("Send button state change.");
        case BSP_BUTTON_1:
            if (button_action == APP_BUTTON_PUSH)
                NRF_LOG_INFO("BSP_BUTTON_2 clicked - start SPI TRX Timer");
                bsp_board_led_invert(BSP_BOARD_LED_0);
        case BSP_BUTTON_2:
                NRF_LOG_INFO("BSP_BUTTON_3 clicked - TOGGLE LED 1");
                bsp_board_led_invert(BSP_BOARD_LED_1);
            APP_ERROR_HANDLER(pin_no);
static void leds_init(void)
static void timers_init(void)
    // Initialize timer module, making it use the scheduler
static void buttons_init(void)
    //The array must be static because a pointer to it will be saved in the button handler module.
    static app_button_cfg_t buttons[] =
        {BSP_BUTTON_0, false, BUTTON_PULL, button_event_handler},
        {BSP_BUTTON_1, false, BUTTON_PULL, button_event_handler},
        {BSP_BUTTON_2, false, BUTTON_PULL, button_event_handler}
    err_code = app_button_init(buttons, ARRAY_SIZE(buttons),
                               BUTTON_DETECTION_DELAY);
    log_init();
    leds_init();
    timers_init();
    buttons_init();
    nrfx_spim_xfer_desc_t xfer_desc = NRFX_SPIM_XFER_TRX(m_tx_buf, m_length, m_rx_buf, m_length);
    nrfx_spim_config_t spi_config = NRFX_SPIM_DEFAULT_CONFIG;
    spi_config.frequency      = NRF_SPIM_FREQ_1M;
    spi_config.ss_pin         = NRFX_SPIM_SS_PIN;
    spi_config.miso_pin       = NRFX_SPIM_MISO_PIN;
    spi_config.mosi_pin       = NRFX_SPIM_MOSI_PIN;
    spi_config.sck_pin        = NRFX_SPIM_SCK_PIN;
    //spi_config.dcx_pin        = NRFX_SPIM_DCX_PIN;
    spi_config.dcx_pin        = NRFX_SPIM_PIN_NOT_USED;
    spi_config.use_hw_ss      = true;
    spi_config.ss_active_high = false;
    APP_ERROR_CHECK(nrfx_spim_init(&spi, &spi_config, spim_event_handler, NULL));
    NRF_LOG_INFO("NRFX SPIM example started.");
    while (1)
        // Reset rx buffer and transfer done flag
        memset(m_rx_buf, 0, m_length);
        spi_xfer_done = false;
        //APP_ERROR_CHECK(nrfx_spim_xfer_dcx(&spi, &xfer_desc, 0, 15));
        APP_ERROR_CHECK(nrfx_spim_xfer(&spi, &xfer_desc, 0));
        while (!spi_xfer_done)
            __WFE();
        NRF_LOG_FLUSH();
        //bsp_board_led_invert(BSP_BOARD_LED_0);
        nrf_delay_ms(500);
my pca10056.h is:
 * Copyright (c) 2016 - 2019, Nordic Semiconductor ASA
 * All rights reserved.
#ifndef PCA10056_H
#define PCA10056_H
#ifdef __cplusplus
extern "C" {
// LEDs definitions for PCA10056
#define LEDS_NUMBER    4
#define LED_1          NRF_GPIO_PIN_MAP(0,13)
#define LED_2          NRF_GPIO_PIN_MAP(0,14)
#define LED_3          NRF_GPIO_PIN_MAP(0,15)
#define LED_4          NRF_GPIO_PIN_MAP(0,16)//24
#define LED_START      LED_1
#define LED_STOP       LED_4
#define LEDS_ACTIVE_STATE 0
#define LEDS_LIST { LED_1, LED_2, LED_3, LED_4 }
#define LEDS_INV_MASK  LEDS_MASK
#define BSP_LED_0      13
#define BSP_LED_1      14
#define BSP_LED_2      15
#define BSP_LED_3      16 // 24-on our board
#define BUTTONS_NUMBER 4
#define BUTTON_1       11 //11
#define BUTTON_2       12 //12
#define BUTTON_3       24 //24
#define BUTTON_4       25 //25
#define BUTTON_PULL    NRF_GPIO_PIN_PULLUP
#define BUTTONS_ACTIVE_STATE 0
#define BUTTONS_LIST { BUTTON_1, BUTTON_2, BUTTON_3, BUTTON_4 }
#define BSP_BUTTON_0   BUTTON_1
#define BSP_BUTTON_1   BUTTON_2
#define BSP_BUTTON_2   BUTTON_3
#define BSP_BUTTON_3   BUTTON_4
#define RX_PIN_NUMBER  8
#define TX_PIN_NUMBER  6
#define CTS_PIN_NUMBER 7
#define RTS_PIN_NUMBER 5
#define HWFC           true
#define BSP_QSPI_SCK_PIN   19
#define BSP_QSPI_CSN_PIN   17
#define BSP_QSPI_IO0_PIN   20
#define BSP_QSPI_IO1_PIN   21
#define BSP_QSPI_IO2_PIN   22
#define BSP_QSPI_IO3_PIN   23
// serialization APPLICATION board - temp. setup for running serialized MEMU tests
#define SER_APP_RX_PIN              NRF_GPIO_PIN_MAP(1,13)    // UART RX pin number.
#define SER_APP_TX_PIN              NRF_GPIO_PIN_MAP(1,14)    // UART TX pin number.
#define SER_APP_CTS_PIN             NRF_GPIO_PIN_MAP(0,2)     // UART Clear To Send pin number.
#define SER_APP_RTS_PIN             NRF_GPIO_PIN_MAP(1,15)    // UART Request To Send pin number.
#define SER_APP_SPIM0_SCK_PIN       NRF_GPIO_PIN_MAP(0,27)     // SPI clock GPIO pin number.
#define SER_APP_SPIM0_MOSI_PIN      NRF_GPIO_PIN_MAP(0,2)      // SPI Master Out Slave In GPIO pin number
#define SER_APP_SPIM0_MISO_PIN      NRF_GPIO_PIN_MAP(0,26)     // SPI Master In Slave Out GPIO pin number
#define SER_APP_SPIM0_SS_PIN        NRF_GPIO_PIN_MAP(1,13)     // SPI Slave Select GPIO pin number
#define SER_APP_SPIM0_RDY_PIN       NRF_GPIO_PIN_MAP(1,15)     // SPI READY GPIO pin number
#define SER_APP_SPIM0_REQ_PIN       NRF_GPIO_PIN_MAP(1,14)     // SPI REQUEST GPIO pin number
// serialization CONNECTIVITY board
#define SER_CON_RX_PIN              NRF_GPIO_PIN_MAP(1,14)    // UART RX pin number.
#define SER_CON_TX_PIN              NRF_GPIO_PIN_MAP(1,13)    // UART TX pin number.
#define SER_CON_CTS_PIN             NRF_GPIO_PIN_MAP(1,15)    // UART Clear To Send pin number. Not used if HWFC is set to false.
#define SER_CON_RTS_PIN             NRF_GPIO_PIN_MAP(0,2)     // UART Request To Send pin number. Not used if HWFC is set to false.
#define SER_CON_SPIS_SCK_PIN        NRF_GPIO_PIN_MAP(0,27)    // SPI SCK signal.
#define SER_CON_SPIS_MOSI_PIN       NRF_GPIO_PIN_MAP(0,2)     // SPI MOSI signal.
#define SER_CON_SPIS_MISO_PIN       NRF_GPIO_PIN_MAP(0,26)    // SPI MISO signal.
#define SER_CON_SPIS_CSN_PIN        NRF_GPIO_PIN_MAP(1,13)    // SPI CSN signal.
#define SER_CON_SPIS_RDY_PIN        NRF_GPIO_PIN_MAP(1,15)    // SPI READY GPIO pin number.
#define SER_CON_SPIS_REQ_PIN        NRF_GPIO_PIN_MAP(1,14)    // SPI REQUEST GPIO pin number.
#define SER_CONN_CHIP_RESET_PIN     NRF_GPIO_PIN_MAP(1,1)    // Pin used to reset connectivity chip
// Arduino board mappings
#define ARDUINO_SCL_PIN             27    // SCL signal pin
#define ARDUINO_SDA_PIN             26    // SDA signal pin
#define ARDUINO_AREF_PIN            2     // Aref pin
#define ARDUINO_13_PIN              NRF_GPIO_PIN_MAP(1, 15)  // Digital pin 13
#define ARDUINO_12_PIN              NRF_GPIO_PIN_MAP(1, 14)  // Digital pin 12
#define ARDUINO_11_PIN              NRF_GPIO_PIN_MAP(1, 13)  // Digital pin 11
#define ARDUINO_10_PIN              NRF_GPIO_PIN_MAP(1, 12)  // Digital pin 10
#define ARDUINO_9_PIN               NRF_GPIO_PIN_MAP(1, 11)  // Digital pin 9
#define ARDUINO_8_PIN               NRF_GPIO_PIN_MAP(1, 10)  // Digital pin 8
#define ARDUINO_7_PIN               NRF_GPIO_PIN_MAP(1, 8) // Digital pin 7
#define ARDUINO_6_PIN               NRF_GPIO_PIN_MAP(1, 7) // Digital pin 6
#define ARDUINO_5_PIN               NRF_GPIO_PIN_MAP(1, 6) // Digital pin 5
#define ARDUINO_4_PIN               NRF_GPIO_PIN_MAP(1, 5) // Digital pin 4
#define ARDUINO_3_PIN               NRF_GPIO_PIN_MAP(1, 4) // Digital pin 3
#define ARDUINO_2_PIN               NRF_GPIO_PIN_MAP(1, 3) // Digital pin 2
#define ARDUINO_1_PIN               NRF_GPIO_PIN_MAP(1, 2) // Digital pin 1
#define ARDUINO_0_PIN               NRF_GPIO_PIN_MAP(1, 1) // Digital pin 0
#define ARDUINO_A0_PIN              3     // Analog channel 0
#define ARDUINO_A1_PIN              4     // Analog channel 1
#define ARDUINO_A2_PIN              28    // Analog channel 2
#define ARDUINO_A3_PIN              29    // Analog channel 3
#define ARDUINO_A4_PIN              30    // Analog channel 4
#define ARDUINO_A5_PIN              31    // Analog channel 5
#ifdef __cplusplus
#endif // PCA10056_H
Also just in case it's helpful, here is a screenshot of my project directory:
I've spent 2 days on this and am feeling pretty dumb at this point - writing and re-writing just trying to get a demo where I can start SPIM/easyDMA transfers with a push button! Any/all advice would be much much appreciated. Why would I pull in code from ble_app_blinky? Well I'm putting together some firmware that essentially turns an nrf52840 into a SPI <-> BLE pipe. I have all the BLE side of things working in another project, I wanted to spin up the SPI side of things separate but I wanted to use similar blocks that already exist in my BLE firmware.
  • Hi there,
    Did you modify the sdk_config.h file accordingly when you merged the two projects? The program does not hit the breakpoint if you set it at the beginning of the button handler and press a button?
    regards
    Jared
  • Hi Jared,
    Thanks for your quick response. I didn't change the sdk_config.h because as far as the nrfx_spim already had the following:
    // <q> BUTTON_ENABLED - Enables Button module
    #ifndef BUTTON_ENABLED
    #define BUTTON_ENABLED 1
    I couldn't see anything else relevant for buttons in the ble_app_blinky project. Do you know if there's more to getting buttons enabled?
    Also correct, breakpoints aren't being tripped. Also no errors are returned when I run:
    Is there something special about nrfx_spim that I'm missing? I've attached my sdk_config.h in case you were wondering about something else.
    Thank you so much for your help. This has been really annoying and I'm out of ideas hahaha -you're my life line :D.
    Kindest regards,
    Ryan
    7271.sdk_config.h
    Looking at the code your posted, I can't see that you're calling app_button_enable() anywhere. You need to call this function after initializing the module to actually enable the GPIOTE event. Can you add this function call at the end of the init routine?
    regards
    Jared
  • That's a great catch - unfortunately, that didn't fix the problem :(.
    I added it at the end of the buttons_init() function and the buttons still didn't trigger an event. I double checked and can confirm that GPIOTE_ENABLED is 1 in the sdk_config. The LEDs are still working (if I put any led_invert(...) calls in the main loop.
    Is this the proper way to instantiate buttons? I've seen other examples use "bsp_init()" and that seems to do some more checks in addition to using app_buttons_init/enable. Is there more I should be doing?
    Thanks so far for your help!
  • Hi there,
    Could you share your project? I would like to try to reproduce this on my end. Please include everything that is necessary to build the project successfully. Also, what SDK version are you using?
    Using the BSP module is ok, but note that it's made for our development kits in case you're not going to use our devkits in the future.
    regards
    Jared
