External antenna J1 insert connector in nRF52833-DK
Hello! I use EK42423-03 and 52833-DK
Previous case
I understand plugging in the SWF connector, Will disconnecting from the PCB antenna and routing the signal to the cable.
EK42423-03-Datasheet
LS ->GND CTRL -> P0.26 ; GND -> GNDVDD -> VDDJ1 RFC -> J1 ANT
First follow this pic.
I added code in nrf52833dk_nrf52833.dts
    ant1: ant_1 {
			gpios = <&gpio0 26 GPIO_ACTIVE_LOW>; /*CTRL*/
			label = "ANT 1";
Using multimeter can measure from RF2 to Refer to the pic.
RF1 = 0Ω
RF2 = 20Ω
But why? EK42423-03 "J1"  insert 52833-DK "J1" After Refer to the pic.
RF1 = 0Ω
RF2 = 0Ω
I do not know what is causing.
Sorry, it's been two months and I still can't do it...
But I still hope you can give me advice!
Thanks again for your support.
  • Hi
    There is no point in looking at the raw IQ data as it needs to be converted into vector form to review it properly. You can check out this page for information on the various formulas used to translate IQ data between polar and rectangular form. Nordic will not provide the direction finding algorithm, and customers/users are expected to get that elsewhere. In order to use the IQ data you get from the beacon you will need an AOA algorithm, which we don't provide.
    Simon
  • I have a set of algorithms, but this is not the part that I am currently able to do.
    Back to the topic.
    The AoA mode still cannot be switched according to the antenna matrix configuration, am I doing something wrong?
    At the moment it looks like I'm only getting data from a single antenna.
  • Hi
    Okay, sorry about the misunderstanding. So how is this SPDT switch connected to the nRF52833 board. How is it set up to switch between the antennas exactly? What have you set up to trig the switching? Our sample application uses two GPIOs to enable the antenna switching as described in the documentation.
    Simon
  • 你好
    我們的示例應用程序使用兩個 GPIO來啟用天線切換,如文檔中所述。
    這裡所說的GPIO是指nrf52833-DK?
    是的,讓我解釋一下我做了什麼。
    1.我通過杜邦線連接了以下
    https://www.psemi.com/products/rf-switches/high-isolation-rf-switches/pe42423
    52833-DK
    EK42423-03
    P0.27 LS
    P0.26
    CTRL
    接地 接地
    VDD
    VDD
    J1 J1 RFC
    2. 根據數據表表 5。
    使用 direction_finding_connectionless_rx 示例
    在nrf52833dk_nrf52833.dts中添加代碼
    			gpios = <&gpio0 27 GPIO_ACTIVE_HIGH>; /*LS*/
    			label = "ANT 1";
                    ant2: ant_2 {
    			gpios = <&gpio0 26 GPIO_ACTIVE_HIGH>;  /*CTRL*/
    			label = "ANT 2";
    /* These aliases are provided for compatibility with samples */
    	aliases {
    		led0 = &led0;
    		led1 = &led1;
    		led2 = &led2;
    		led3 = &led3;
    *       ant1 = &ant1;
    *       ant2 = &ant2;
    		pwm-led0 = &pwm_led0;
    		sw0 = &button0;
    		sw1 = &button1;
    		sw2 = &button2;
    		sw3 = &button3;
    		bootloader-led0 = &led0;
    我將以下代碼設置為觸發。
    在nrf52833dk_nrf52833.overlay中添加代碼
     * Copyright (c) 2021 Nordic Semiconductor ASA
    &radio {
    	status = "okay";
    	/* This is a number of antennas that are available on antenna matrix
    	 * designed by Nordic. For more information see README.rst.
    	dfe-antenna-num = < 2 >;
            /*dfe-antenna-num = <12>;*/
    	/* This is a setting that enables antenna 12 (in antenna matrix designed
    	 * by Nordic) for Rx PDU. For more information see README.rst.
    	dfe-pdu-antenna = <0x2>;
            /*dfe-pdu-antenna = <0x0>;*/
    	/* These are GPIO pin numbers that are provided to
    	 * Radio peripheral. The pins will be acquired by Radio to
    	 * drive antenna switching when AoA is enabled.
    	 * Pin numbers are selected to drive switches on antenna matrix
    	 * desinged by Nordic. For more information see README.rst.
    	dfegpio0-gpios = <&gpio0 3 0>;
    	dfegpio1-gpios = <&gpio0 4 0>;
        dfegpio2-gpios = <&gpio0 28 0>;
        dfegpio3-gpios = <&gpio0 29 0>;
    在main.c中添加代碼
    修改 ant_patterns 切換。
    #define SLEEP_TIME_MS   1000
    #define ANT1_NODE DT_ALIAS(ant1)
    #if DT_NODE_HAS_STATUS(ANT1_NODE, okay)
    #define ANT1	DT_GPIO_LABEL(ANT1_NODE, gpios)
    #define PIN	DT_GPIO_PIN(ANT1_NODE, gpios)
    #define FLAGS	DT_GPIO_FLAGS(ANT1_NODE, gpios)
    #else
    /* A build error here means your board isn't set up to blink an LED. */
    #error "Unsupported board: led0 devicetree alias is not defined"
    #define ANT0	""
    #define PIN	0
    #define FLAGS	0
    #define ANT2_NODE DT_ALIAS(ant2)
    #if DT_NODE_HAS_STATUS(ANT2_NODE, okay)
    #define ANT2	DT_GPIO_LABEL(ANT2_NODE, gpios)
    #define PIN	DT_GPIO_PIN(ANT2_NODE, gpios)
    #define FLAGS	DT_GPIO_FLAGS(ANT2_NODE, gpios)
    #else
    #define ANT0	""
    #define PIN	0
    #define FLAGS	0
    static const uint8_t ant_patterns[] = { 0x2, 0xB };
    #endif /* CONFIG_BT_CTLR_DF_ANT_SWITCH_RX */
    同樣在main.c
    中參考閃爍示例。在void main(void)
    中添加了以下代碼
    但我認為這可能沒有任何意義
    void main(void)
            const struct device *dev;
    	bool ant_is_on = true;
    	int ret;
    	dev = device_get_binding(ANT1);
    	if (dev == NULL) {
    		return;
    	ret = gpio_pin_configure(dev, PIN, GPIO_OUTPUT_ACTIVE | FLAGS);
    	if (ret < 0) {
    		return;
    以上是我到目前為止所做的
    非常感謝您的回复
  • HI.
    I want to improve
    Query case
    I can find the code
    NRF_RADIO->PSEL.DFEGPIO[0] = 0x00000011; //(P0.17)
    NRF_RADIO->SWITCHPATTERN = 0x0; // before CTE - antenna 1
    NRF_RADIO->SWITCHPATTERN = 0x0; // reference - antenna 1
    NRF_RADIO->SWITCHPATTERN = 0x0; // slots 0, 2, 4... - antenna 1
    NRF_RADIO->SWITCHPATTERN = 0x1; // slots 1, 3, 5... - antenna 2
    So I currently modified the following
    radio_df.c
    void radio_df_ant_switch_pattern_set(uint8_t *patterns, uint8_t len)
    	for (uint8_t idx = 0; idx < len; ++idx) {
    		NRF_RADIO->PSEL.DFEGPIO[0] = 0x0000001A; //(P0.26)
    &radio {
    	status = "okay";
            /*dfe-pdu-antenna = <0x2>;*/
        dfegpio2-gpios = <&gpio0 26 0>;
        dfegpio3-gpios = <&gpio0 27 0>;
    Query case
    main.c
    RF1 0 | 1 = 0x1
    RF2 0 | 0 = 0x0
    static const uint8_t ant_patterns[] = { 0x1, 0x0, 0x1 };
    What am I missing?
    Thank!
