nRF Connect Installation on macOS (Automatic Installation)
I have not been able to create a stable development environment in macOS Monterey using the automatic installation process.
In order to better understand and document the issues, I am going to do four separate installations for comparison.
MacBook Pro 1:  Manual Installation
https://devzone.nordicsemi.com/f/nordic-q-a/88500/nrf-connect-installation-on-macos-manual-installation
MacBook Pro 2:  Automatic installation
Linux Ubuntu:     Manual Installation
Windows 11:       Automatic installation
This thread will cover the second case, the automatic installation on macOS. I will create separate support tickets for the other cases and provide links.
  • Hi Marte,
    Thanks very much, this is the result from executing env when opening Terminal from the nRF Connect SDK:
    220610 macOS Bash Environment.rtf
    (Computer and user names anonymised for security reasons)
    Is there anything that you wouldn't expect to see please?
    I had problems with Kconfig previously using the zsh shell, so I don't think this is related to which terminal shell I'm using.Please see existing open ticket:
    https://devzone.nordicsemi.com/f/nordic-q-a/85101/implementing-developing-bluetooth-low-energy-products-using-nrf-connect-video-on-nrf5340-dk
    My current project is the LE Audio demo on the nRF5340 Audio DK board, which I'm executing from Windows Command Prompt/Bash using the supplied Python script. I am focussed on getting this demo up and running (so far only achieved on Windows 11, but with glitching audio transmission/reception) before I go back to developing in VS Code.
    Al
    Are you able to build the project successfully? Because if not, that might explain the Kconfig error.
    Best regard,
    Marte
  • Hi Yes I can build and run successfully.
    In fact the guiconfig/menuconfig works fine as well. I do get that issue below, which might be related.
    The file definitely exists and changes to it and doing pristine build definitely take effect.
    It is only KConfig itself (the Nrf provided built-in editor) not working on M1 Mac.
  • Hi ,
    Can you generate support information in VS Code so I can forward that to the developers looking into this? Thank you.
    Marte
  • [08:35:37] west build --build-dir /Users/pieter/Programming/nordic/littlefs/littlefs/build /Users/pieter/Programming/nordic/littlefs/littlefs
    [08:35:46] Success.
    IMPORTANT: The data below could contain sensitive or confidential information about your environment.
    For help and support, visit the Nordic DevZone at https://devzone.nordicsemi.com/.
      "platform": {
        "os": "darwin",
        "osVersion": "Darwin Kernel Version 21.5.0: Tue Apr 26 21:08:37 PDT 2022; root:xnu-8020.121.3~4/RELEASE_ARM64_T6000",
        "osKernel": "21.5.0",
        "vscode": "1.68.0",
        "electron": "17.4.7",
        "node": "v16.13.0"
      "system": {
        "date": "2022-06-15T09:15:38.751Z",
        "vscodeRoot": "/Applications/Visual Studio Code.app/Contents/Resources/app",
        "vscodeUptime": "02:50:37",
        "osUptime": "26:06:08",
        "cpu": {
          "model": "Apple M1 Pro",
          "speed": "24 MHz",
          "count": 4
        "memory": {
          "total": "16.00 GB",
          "free": "0.12 GB"
      "workspace": {
        "name": "littlefs",
        "workspaceFile": null,
        "folders": [
          "/Users/pieter/Programming/nordic/littlefs/littlefs"
      "extensions": {
        "internal": {
            "version": "2022.6.142",
            "path": "/Users/pieter/.vscode/extensions/nordic-semiconductor.nrf-connect-2022.6.142",
            "isActive": true
            "version": "2022.4.61",
            "path": "/Users/pieter/.vscode/extensions/nordic-semiconductor.nrf-terminal-2022.4.61",
            "isActive": true
          "nordic-semiconductor.devicetree": null,
          "nordic-semiconductor.kconfig": null
        "external": {
          "marus25.cortex-debug": "1.4.4",
          "ms-vscode.cpptools": "1.10.6",
          "ms-vscode.js-debug": "1.68.0",
          "ms-vscode.js-debug-companion": "1.0.18",
          "ms-vscode.vscode-js-profile-table": "1.0.2",
          "ms-vscode.references-view": "1.0.0",
          "aaron-bond.better-comments": "3.0.0",
          "alex-young.pm2-explorer": "0.0.7",
          "bajdzis.vscode-database": "2.2.3",
          "bbenoist.QML": "1.0.0",
          "ckolkman.vscode-postgres": "1.4.0",
          "cschlosser.doxdocgen": "1.4.0",
          "dan-c-underwood.arm": "1.7.4",
          "dbaeumer.vscode-eslint": "2.2.2",
          "eamodio.gitlens": "12.1.0",
          "eg2.vscode-npm-script": "0.3.25",
          "esbenp.prettier-vscode": "9.5.0",
          "flowtype.flow-for-vscode": "2.1.0",
          "formulahendry.auto-rename-tag": "0.1.10",
          "formulahendry.code-runner": "0.11.8",
          "formulahendry.terminal": "0.0.10",
          "gamunu.vscode-yarn": "2.1.0",
          "GitHub.vscode-pull-request-github": "0.44.0",
          "jdinhlife.gruvbox": "1.7.0",
          "jeff-hykin.better-cpp-syntax": "1.15.16",
          "josetr.cmake-language-support-vscode": "0.0.4",
          "meganrogge.template-string-converter": "0.6.0",
          "mongodb.mongodb-vscode": "0.9.3",
          "ms-azuretools.vscode-docker": "1.22.0",
          "ms-dotnettools.csharp": "1.25.0",
          "ms-dotnettools.vscode-dotnet-runtime": "1.5.0",
          "ms-vscode-remote.remote-containers": "0.238.2",
          "ms-vscode-remote.remote-ssh": "0.82.1",
          "ms-vscode-remote.remote-ssh-edit": "0.80.0",
          "ms-vscode-remote.remote-wsl": "0.66.3",
          "ms-vscode.cmake-tools": "1.11.26",
          "ms-vscode.cpptools-extension-pack": "1.2.0",
          "ms-vscode.cpptools-themes": "1.0.0",
          "ms-vscode.makefile-tools": "0.5.0",
          "ms-vscode.vscode-embedded-tools": "0.1.1",
          "ms-vscode.vscode-serial-monitor": "0.1.0",
          "ms-vsliveshare.vsliveshare": "1.0.5615",
          "ms-vsliveshare.vsliveshare-audio": "0.1.91",
          "naumovs.color-highlight": "2.5.0",
          "ritwickdey.LiveServer": "5.7.5",
          "searKing.preview-vscode": "2.2.5",
          "shardulm94.trailing-spaces": "0.3.1",
          "solnurkarim.html-to-css-autocompletion": "1.1.2",
          "spmeesseman.vscode-taskexplorer": "2.9.1",
          "sporiley.css-auto-prefix": "0.1.7",
          "streetsidesoftware.code-spell-checker": "2.2.4",
          "Tobermory.es6-string-html": "2.12.0",
          "tonka3000.qtvsctools": "0.11.0",
          "twxs.cmake": "0.0.17",
          "VisualStudioExptTeam.vscodeintellicode": "1.2.21",
          "vknabel.vscode-swiftformat": "1.5.1",
          "voldemortensen.rainbow-tags": "0.4.1",
          "vscode-icons-team.vscode-icons": "11.12.0",
          "vscodevim.vim": "1.22.2",
          "wayou.vscode-todo-highlight": "1.0.5",
          "xabikos.JavaScriptSnippets": "1.8.0",
          "Zignd.html-css-class-completion": "1.20.0"
      "tools": {
        "/Applications/SEGGER/JLink/JLinkExe": "7.66b",
        "/usr/local/bin/nrfjprog": "10.16.0",
        "nrfutil": "Not found",
        "/opt/nordic/ncs/toolchains/v2.0.0/bin/cmake": "3.20.5",
        "/opt/nordic/ncs/toolchains/v2.0.0/bin/west": "0.13.1",
        "/opt/nordic/ncs/toolchains/v2.0.0/bin/python3": "3.9.6",
        "/opt/nordic/ncs/toolchains/v2.0.0/bin/ninja": "1.10.2",
        "/opt/nordic/ncs/toolchains/v2.0.0/bin/gperf": "3.1",
        "/opt/nordic/ncs/toolchains/v2.0.0/bin/dtc": "1.6.1",
        "/opt/nordic/ncs/toolchains/v2.0.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/arm-zephyr-eabi-gcc": "0.14.1",
        "/opt/nordic/ncs/toolchains/v2.0.0/bin/gn": "2039",
        "/opt/nordic/ncs/toolchains/v2.0.0/bin/git": "2.32.0"
      "sdks": [
          "version": "2.0.0",
          "path": "/opt/nordic/ncs/v2.0.0"
      "toolchains": [
          "version": "2.0.0",
          "path": "/opt/nordic/ncs/toolchains/v2.0.0"
      "connectedDevices": [],
      "deviceProviders": [
        "nrfjprog"
      "config": {
          "topdir": "${nrf-connect.sdk:2.0.0}",
          "toolchain": {
            "path": "${nrf-connect.toolchain:2.0.0}"
          "ozonePath": "",
          "applications": [
          "applicationOptions": {},
          "kconfig": {
            "interface": "kconfig"
          "welcome": {
            "showOnStartup": false
          "west": {
            "env": {
              "$base": "terminal"
          "boardRoots": [
            "${workspaceFolder}"
          "enableTelemetry": true,
          "taskBindings": {}
          "terminalMode": "character"
        "nordic-semiconductor.devicetree": {
          "modules": [
            "${zephyrBase}",
            "${zephyrBase}/../nrf",
          "zephyr": "",
          "ctxFile": "",
          "defaultBoard": ""
        "nordic-semiconductor.kconfig": {
          "root": "",
          "env": {},
          "cfiles": true,
          "disable": false,
          "zephyr": {
            "base": ""
          "python": "/opt/homebrew/bin/python3",
          "liveValue": true
        "marus25.cortex-debug": {
          "armToolchainPath": null,
          "armToolchainPrefix": "arm-none-eabi",
          "gdbPath": null,
          "objdumpPath": null,
          "JLinkGDBServerPath": null,
          "openocdPath": null,
          "pyocdPath": null,
          "PEGDBServerPath": null,
          "stutilPath": null,
          "stlinkPath": null,
          "stm32cubeprogrammer": null,
          "flattenAnonymous": false,
          "registerUseNaturalFormat": true,
          "variableUseNaturalFormat": true,
          "dbgServerLogfile": null,
          "showRTOS": true,
          "showDevDebugOutput": "none"
      "environment": {
        "westExe": "/opt/nordic/ncs/toolchains/v2.0.0/bin/west",
        "westEnv": {
          "ELECTRON_RUN_AS_NODE": "1",
          "GIT_EXEC_PATH": "/opt/nordic/ncs/toolchains/v2.0.0/Cellar/git/2.32.0_1/libexec/git-core",
          "HOME": "/Users/pieter",
          "PATH": "/opt/nordic/ncs/toolchains/v2.0.0/bin:/opt/nordic/ncs/toolchains/v2.0.0/opt/bin:/opt/nordic/ncs/toolchains/v2.0.0/opt/zephyr-sdk/arm-zephyr-eabi/bin:/opt/nordic/ncs/toolchains/v2.0.0/arm-zephyr-eabi/bin:/opt/homebrew/bin:/opt/homebrew/sbin:/usr/local/bin:/usr/bin:/bin:/usr/sbin:/sbin:/Library/Apple/usr/bin",
          "ZEPHYR_BASE": "/opt/nordic/ncs/v2.0.0/zephyr",
          "ZEPHYR_SDK_INSTALL_DIR": "/opt/nordic/ncs/toolchains/v2.0.0/opt/zephyr-sdk",
          "USER": "pieter"
        "inherited": {
          "PATH": "/opt/homebrew/bin:/opt/homebrew/sbin:/usr/local/bin:/usr/bin:/bin:/usr/sbin:/sbin:/Library/Apple/usr/bin",
          "USER": "pieter"
        "toolchainPath": "/opt/nordic/ncs/toolchains/v2.0.0",
        "toolchainBinPath": "/opt/nordic/ncs/toolchains/v2.0.0/opt/zephyr-sdk/arm-zephyr-eabi/bin",
        "toolchainVersion": "2.0.0"
      "terminal": {
        "shell": null,
        "defaultProfile": null
    It may be important to also let you know the NRF icon in the side bar disappeared after yesterday's update. Reverting did not restore it. The Nrf functions do show up in the debug and run icon however. See screenshot below:
