Connection interval and tx throughput
I'm testing maximum tx throughput.
I'm using ble_app_hrs example and mcu is nRF52832(s132). (sdk : 16.0.0)
The goal is transmit data at 96Kbps.
I read that the throughput is related to connection interval and MTU size. (in this post)
MTU size of ble_app_hrs example is 247. So, i changed connection interval.
I have some question about tx throughput.
1. When i set connection interval (both MIN and MAX) to 400ms, peripheral disconnected (reason:BLE_HCI_CONNECTION_TIMEOUT).
#define MIN_CONN_INTERVAL                   MSEC_TO_UNITS(400, UNIT_1_25_MS)
#define MAX_CONN_INTERVAL                   MSEC_TO_UNITS(400, UNIT_1_25_MS)
This is the log.
14:14:09.545	Connecting to device
14:14:12.799	Connected to device EB:6B:7A:0D:87:72: interval: 7.5ms, timeout: 4000ms, latency: 0
14:14:12.829	ATT MTU updated for device EB:6B:7A:0D:87:72, new value is 247
14:14:12.839	Data length updated for device EB:6B:7A:0D:87:72, new value is 251
14:14:13.072	Attribute value read, handle: 0x03, value (0x): 48-45-48-30-30-31-20-38-37-3A-37-32
14:14:17.852	Connection parameters updated for device EB:6B:7A:0D:87:72: interval 400ms, timeout 4000ms, latency: 0
14:14:22.256	Disconnected from device EB:6B:7A:0D:87:72, reason: BLE_HCI_CONNECTION_TIMEOUT
2. About Data length extension.
Is ble_app_hrs example is applied Data length extension?
If not, what code should I modify?
    The Central device will set the connection interval that best suits its needs given a requested range from a peripheral device. This means that you are not guaranteed to get the connection interval that you desire. You could use the default setting as the ble_app_hrs example.
    Data length extension enables the softdevice to overstay the configured event length in sdk_config.h (see NRF_SDH_BLE_GAP_EVENT_LENGTH). Also, see this post.
    Amanda
