Unable to perform a BLE DFU when flash is at around 97 % capacity
I'm using a nrf52832 and NCS 1.9.0 and I would like to be able to use SMP to make firmware updates using BLE. I'm was able to perform FOTA, but the flash is divided by two because I'm using MCUBoot and my app would require more. My firmware is taking 98.82% of half of the flash capacity. When I try to do a DFU over BLE, it doesn't work and I think it may come from the fact that the image is too big. When I remove some features from my firmware and I reduce the image to 96.5%, I'm able to perform the DFU.
Do you have any idea of how I could reduce my image size? Is it possible to reorganize the partitions to get more space.
I know that I can't use a single application slot. (https://devzone.nordicsemi.com/f/nordic-q-a/86691/single-slot-dfu-using-mcuboot)
I would like to use the swap without scratch partition as mentioned here https://developer.nordicsemi.com/nRF_Connect_SDK/doc/1.9.1/mcuboot/design.html but the option MCUBOOT_SWAP_USING_MOVE is not a valid option in my project.
Alexandre
