How to use uart in mesh, or printf?
When I use 52832 to develop a mesh project and want to use uart to print information, I find that the code always reports an error because of the existence of printf. The sdk used in my development environment is NRF1710sdk and nrf mesh SDK5.0.0, developed in ses,what should I do to make it work normally?
    If you didn't have undefined references to e.g. mesh_adv_start(), let us assume that fixing the first will help with (most of) the rest.
    Since the compile found the definition of APP_UART_INIT(), I assume you have added:
    #include "app_uart.h"
    near the top of your main.c.
    Did you include app_uart_fifo.c to your project? Is APP_UART_ENABLED defined in your sdk_config.h? Is it defined to 0 or 1? (Try setting it to 1).
    Let us start with that.
    Edvin
  • Hi Edwin. I think the APP_UART_ENABLED you mentioned might be something I need to pay attention to, but I don't find anything for APP_UART in the sdkconfig. I have added app_uart_fifo.c before, but it still doesn't work properly. After I re-added it, it is grayed out, indicating that it is not enabled. According to the instructions in the code, I found nordic_common.h, but it doesn't seem to be enabled here. What should I do? do to enable it? The mesh_adv_start() you mentioned did not report a definition problem when removing the uart code. Is it because it conflicts with the UART code?
    Sorry, I accidentally pressed the button to confirm the answer, do I need to ask again?
    unvblestudy
    It goes back to status OPEN when you reply, so it is fine.
    Ok, I see. So
    #if NRF_MODULE_ENABLED(APP_UART)
    uses the macro NRF_MODULE_ENABLED, which translates to :
    ((defined(module ## _ENABLED) && (module ## _ENABLED)) ? 1 : 0)
    Which means that it really says.
    #if ((defined(module ## _ENABLED) && (module ## _ENABLED)) ? 1 : 0)
    where "module" is what's inside the parenthesis, and ## is a way to "stitch" strings together.
    So basically it checks whether APP_UART_ENABLED is defined, and whether APP_UART_ENABLED is defined to 1. If not both of those are true, then it will exclude the rest of the file (until the corresponding #endif comes).
    Add this to your sdk_confi.h file somewhere:
    // <e> APP_UART_ENABLED - app_uart - UART driver
    #ifndef APP_UART_ENABLED
    #define APP_UART_ENABLED 1
    // <o> APP_UART_DRIVER_INSTANCE  - UART instance used
    // <0=> 0
    #ifndef APP_UART_DRIVER_INSTANCE
    #define APP_UART_DRIVER_INSTANCE 0
    // </e>
    (I copied it from the ble_app_uart example's sdk_config.h file, which is an example that I know uses the app_uart).
    If you find a line in your sdk_config.h saying:
    // <h> nRF_Libraries
    You can paste it somewhere below there.
    Edvin
  • Thanks for your guidance, Edvin! I have now solved the related error and got it running successfully, but when I use app_uart_put('p');, I don't see the output on the serial port software, how can I check if it is working properly?
    unvblestudy
  • Hi, Edvin, I have browsed many other posts about uart and found that some people mentioned that rtt and uart cannot be used together, I am wondering if this is the problem I have encountered,because I use rtt in my code  for debugging observations.
    unvblestudy
