NRF5340 low-power measurement with PPK2
I aw various other posts ( nRF5340-DK Low Power Configuration Issues)
and the post on Optimizing power on nRF53 designs  but I never get results that low.
The Blog post doesn't really help, since it only states the Zephyr settings and not the
real software settings. Using the example from the post mentioned above gets the same
results (650 uA on 1800 mV)
Our setup:
PPK as power supply for NRF5430-DK (version 0.11.0)
SB40 is bridged
SW6 to DEFAULT (if no nRFOnly, more current seems to run)
SW9 to VDD
SW10 to ON
For software:
basic loop, while(1) { WFI(); }
and 100 Hz RTC1 based TICK.
HFCLKSRC = HFINT
Other peripherals idle.
When I measure is still get around 650 uA when setting PPK supply to 1800 mV. (around 1000 uA when 3000 mV).
So 2 questions:
- is the hardware setup ok?
- what can we do in the software?
  • Hi
    The current consumption you refer to here is the HF crystal ramp up of an nRF9160 DK I believe, and should definitely not be seen if you only have the empty app core running on an nRF5340 Dk on your end. Can you use the nRF Programmer to check what is on the APP and NET core of your DK? Both have the bare minimum on my end which should result in what I showed below.
  • To double check we verified the flash for net core, which is empty.
    We erased again. Then programmed the hex file you attached above.
    Verification with a read in nrfCOnnect indeed shows content in the app core.
    Again. Can we schedule a call ?  Then you can see what's going on.
  • And... you rule out the "retained registers" as problem ?
  • Hi
    We can do a meeting if you'd like, but that would have to wait until Monday (I will be free from 10:30 to 11:30 and 14:00 to 15:30). Unfortunately it seems like you have two defect PPK2's though, if the behavior is like this on both PPKs, where all the maximum spikes are exactly the same (713.24µA on the one you sent to us).
    If you have a resistor available (3kOhm or larger) it would be helpful to see what you measure over a known load in Source Meter mode with 3V applied. 3V on a 3kOhm should show a 1mA current consumption. It would also help if you have a resistor large enough to get under 10µA available (so larger than 300kOhm).
    Finally, if we could get the serial numbers of the PPKs you have we can check the test logs of them as well.
    Simon
  • My serial sticker reads : PCA63100, 1.0.1, 2022.13, ECESD384; Is that what you're looking for ?
    The power profiler v3.4.4 talks about serial : ECE5D3B48A27
    The other one is at Bas' place.
    The proposed time, 14:00 - 15:30, we will be there. Already discussed in the company mail.
    I will see what resistors I have here and try to validate the device itself.
