nrf9160 Custom Board connectivity to nrf cloud
Dear Nordic devzone community,
I am using nrf connect SDK version 1.8.0 for the asset tracker and 2.0.2 for AT client. IDE is Vscode Studio.
I have designed a custom board using nRF9160 and I am able to send and read out certain AT commands which confirms to me that most of the embedded part of the design functions fine.
1)Now in order to use the dashboard of nordic cloud I need to get the IMEI and Pin #, this is normally on the DK indicated with the sticker.
I am able to get the IMEI # by AT+CGSN command, now the issue is how to get 6 digits PIN # ?
2)To connect with the LTE Link monitor with my custom board I am using a Serial to USB converter (FTDI), the LTE Link monitor does not recognize this device. You can see that in the attached images. however, if I open my COMport I can send and receive AT commands..
3)The same is the case with the programmer, I want to load the certificates and modem firmware on a custom board nrf9160 chip .as you can see in the attached image.
4)Custom Board is replying to the AT commands as mentioned in the attached image but not responding to the AT+CPIN command to recognize the SIM. I have attached the schematic of the custom board as well.
A few observations while debugging the HW
a)1.8V output to SIM card is not provided by NRF9160(using the asset tracker FW, which is provided to the DK)
b)What we left open is DETECT pin from nrf9160. But the 1.8V output pin from NRF9160 is still connected to the SIM card connector.
I followed the following links
 Programming/Debugging nRF9160 SiP on custom board
https://devzone.nordicsemi.com/f/nordic-q-a/58055/nrf9160-custom-board---connect-uart-and-send-at-commands/238646#238646
 nrf9160 custom board AT client not working
 Getting HWID nRF9160 custom HW board and using LTE LINK monitor with custom Hardware
Thanks in Advance,
Best Regards,
Muhammad Usman
If anything is unclear please let me know then I can send more information or support with additional attachments.
  • Hi Muhammad,
    The log shows the modem does not work properly. Did you update the modem firmware to MFW v1.2.8?
    Can you test with the following commands after programming SLM and sharing the log file? remember to enable SETTINGS->Automatic requests on LTE Link Monitor.
    AT+CFUN=4
    AT+CFUN?
    AT%XSYSTEMMODE=1,0,0,0
    AT+CEREG=5
    AT+CFUN=1
    AT+CFUN?
    AT#XPING="www.google.com",45,5000,5,1000
    Charlie
  • Hi Charlie!
    Sorry for the late reply! The issue is that I am unable to update the modem firmware because it is only updated by nrf connect for Desktop ----> programmer .
    In start-up of this post, you have mentioned that,
    2)3) LTE Link Monitor only recognise nRF9160DK or Thingy91, but you can use any other general serial assistant software to access your device. Programmer only supports connecting with J-Link debugger, nRF9160DK has one onboard debugger so it is supported, Thingy91 has no onboard debugger so it is not supported. Your Serial to USB converter only supports serial connection, it is not a debugger which can be used to program the nRF9160.
     Can you please help me that how to load the modem firmware in the custom board/ LTE-iot-4 click board?
     Thanks & Regards,
  • Hi Muhammad,
    I did not play with LTE IoT 4 Click board before, so the easiest way is to check with Time-saving embedded tools - MIKROE support channel directly.
    It seems the LTE IoT 4 Click does not have an onboard debugger on it, which is similar to Thingy:91. You can use an external debugger like the onboard debugger on nRF9160DK to program it. Or updating just through UART or USB if its application firmware supports MCUboot. See Update the modem firmware on the nRF9160 SiP for these two methods.
    Charlie
  • Hi Charlie,
    Thank you so much for the support!
    Now modem firmware is upgraded to v1.2.8 as suggested by you.
    I  followed the link for connection between the nrf9160DK and Mikroe(LTE-iot-4 CLick) to upload the modem firmware
    https://infocenter.nordicsemi.com/index.jsp?topic=%2Fug_nrf91_dk%2FUG%2Fnrf91_DK%2Fhw_debug_out.html
    for reference this is also valid
    The purpose of testing this board was to debug the issue I faced with my custom board.
    My connectivity with the LTE IoT 4 Click board is:
    I was making a mistake that I was selecting my target board via FTDI. I should have to upload the modem via DK . Because it was acting as a debugger.
    The second issue is, as you suggested to load the SLM and run the AT commands. I did that but got no response from the modem.Means when i press AT and press Enter then get no OK from modem. So I again loaded the asset tracker firmware with updated modem firmware but still faced the same issue. I pasted the log of the asset tracker here.
    [00:01:03.560,638] <ESC><inf> asset_tracker: LTE cell changed: Cell ID: 90084118, Tracking area: 13801<ESC><CR><LF>
    [00:01:03.623,809] <ESC><inf> asset_tracker: RRC mode: Connected<ESC><CR><LF>
    [00:01:15.484,497] <ESC><inf> asset_tracker: RRC mode: Idle<ESC><CR><LF>
    [00:01:25.591,613] <ESC><inf> asset_tracker: RRC mode: Connected<ESC><CR><LF>
    [00:01:29.817,291] <ESC><inf> asset_tracker: Network registration status: Connected - roaming<ESC><CR><LF>
    [00:01[00:01:29.826,721] <ESC><inf> asset_tracker: PSM parameter update: TAU: 1152000, Active time: 20<ESC><CR><LF>
    :29.825,958] <ESC><inf> asset_tracker: Connected to LTE network.<ESC><CR><LF>
    [00:01:29.841,796] <ESC><inf> asset_tracker: Connecting to cloud, attempt 1 of 8<ESC><CR><LF>
    [00:01:29.849,243] <ESC><inf> asset_tracker: Cloud connection request sent.<ESC><CR><LF>
    [00:01:29.856,231] <ESC><inf> asset_tracker: Connection response timeout is set to 30 seconds.<ESC><CR><LF>
    [00:01:29.864,990] <ESC><inf> asset_tracker: DATE_TIME_OBTAINED_MODEM<ESC><CR><LF>
    [00:01:29.871,429] <ESC><dbg> nrf_cloud.nfsm_set_current_state_and_notify: state: 1<ESC><CR><LF>
    [00:01:29.879,150] <ESC><dbg> nrf_cloud.api_event_handler: NRF_CLOUD_EVT_TRANSPORT_CONNECTING<ESC><CR><LF>
    [00:01:29.887,725] <ESC><inf> asset_tracker: CLOUD_EVT_CONNECTING<ESC><CR><LF>
    [00:01:30.090,209] <ESC><dbg> nrf_cloud_transport.nct_connect: IPv4 address: 3.224.146.136<ESC><CR><LF>
    [00:01:30.098,510] <ESC><dbg> nrf_cloud_transport.nct_mqtt_connect: MQTT clean session flag: 1<ESC><CR><LF>
    [00:01:30.817,443] <ESC><inf> asset_tracker: DATE_TIME_OBTAINED_MODEM<ESC><CR><LF>
    [00:01:32.106,231] <ESC><dbg> nrf_cloud_transport.nct_mqtt_connect: Using socket send timeout of 60 seconds<ESC><CR><LF>
    [00:01:32.116,027] <ESC><dbg> nrf_cloud.nrf_cloud_run: Cloud connection request sent<ESC><CR><LF>
    [00:01:34.264,678] <ESC><dbg> nrf_cloud_transport.nct_mqtt_evt_handler: MQTT_EVT_DISCONNECT: result = -128<ESC><CR><LF>
    [00:01:34.274,353] <ESC><dbg> nrf_cloud.nfsm_set_current_state_and_notify: state: 1<ESC><CR><LF>
    [00:01:34.282,104] <ESC><dbg> nrf_cloud.api_event_handler: NRF_CLOUD_EVT_TRANSPORT_DISCONNECTED<ESC><CR><LF>
    [00:01:34.290,863] <ESC><inf> asset_tracker: CLOUD_EVT_DISCONNECTED: 1<ESC><CR><LF>
    [00:01:34.297,424] <ESC><inf> asset_tracker: Disconnected by the cloud.<ESC><CR><LF>
    [00:01:34.304,077] <ESC><inf> asset_tracker: This can occur during initial nRF Cloud provisioning.<ESC><CR><LF>
    [00:01:34.313,140] <ESC><inf> asset_tracker: Attempting reconnect in 10 seconds...<ESC><CR><LF>
    [00:01:34.320,800] <ESC><err> nrf_cloud_transport: MQTT input error: -128<ESC><CR><LF>
    [00:01:34.327,880] <ESC><dbg> nrf_cloud.nfsm_set_current_state_and_notify: state: 1<ESC><CR><LF>
    [00:01:34.335,632] <ESC><dbg> nrf_cloud.api_event_handler: NRF_CLOUD_EVT_TRANSPORT_DISCONNECTED<ESC><CR><LF>
    [00:01:34.344,390] <ESC><inf> asset_tracker: CLOUD_EVT_DISCONNECTED: 1<ESC><CR><LF>
    [00:01:34.350,952] <ESC><inf> asset_tracker: Disconnected by the cloud.<ESC><CR><LF>
    [00:01:34.357,635] <ESC><inf> asset_tracker: This can occur if the device has the wrong nRF Cloud certificates<ESC><CR><LF>
    [00:01:34.367,736] <ESC><inf> asset_tracker: or if the device has been removed from nRF Cloud.<ESC><CR><LF>
    [00:01:34.376,434] <ESC><inf> asset_tracker: Attempting reconnect in 480 seconds...<ESC><CR><LF>
    [00:01:34.384,155] <ESC><dbg> nrf_cloud.nrf_cloud_run: The cloud socket is already closed<ESC><CR><LF>
    [00:01:37.677,368] <ESC><inf> asset_tracker: RRC mode: Idle<ESC><CR><LF>
    Should I run the at commands on asset tracker FW? Will it help you to diagnose the issue?
    Thanks & Regards,
    Muhammad Usman
  • Hi Muhammad,
    For the SLM communication, can you use Termite with the following configuration to make sure CL+LF is attached at the end of each command?
    You will get something like
    Let's continue with assert tracker v2 if you get a similar result.
    Charlie
