Just see the screen shot - PPK2 is OFF yet it shows 200mA
zyghom said:this app used to work flawlessly, then the upgrade happened (I am on 3.5.2) and the issues started.
See below the mac info.
I'll check with the developers if there is anything in the new update that could cause this.
Is the PPK2 connected to anything other than the computer? Is it connected to a DUT via Vin or Vout? Could you take a picture of the PPK2 that shows how it's connected and upload it here?
thanks,
Jared
o yes, of course
micro USB: "power plus data" connected to macbook
Vout and GND connected to my ESP32
PPK2 used as a source of the power for ESP32
no other pin connected on PPK2
Can you share the revision and build code for your PPK2? You can read it of the sticker on the PCB.
regards
Jared
Hi Zygfryd,
Could you disconnect the ESP32 from the PPK and only connect it to the Macbook. Are you still measuring unreasonable values when it's not connected to anything except for the Macbook?
regards
Jared
