Just see the screen shot - PPK2 is OFF yet it shows 200mA
hi Jared,
the crazy readings were not disappearing even when I disconnected ESP32, Only solved it when I closed the app and disconnected usb and then started new connection and application start.
But this was not the first time so I expect this to happen again and they I will follow what you said
Ok, great.
Please notify me if it happens often.
regards
Jared
it happens again:
power is off, but the graph shows crazy values
and as you asked: I disconnected the load - no change at all
what I will have to do it is to eject PPK2, disconnect from USB, restart the software and it will be back good again
this issue is repeating all the time however I am not able to narrow down what causes it.
However, it seems that it is enough to restore the proper behaviour of PPK2 by simply clicking this button - no need to close the program and disconnect PPK2 from USB.
but the solution is for another few measurements and the problem repeats - I find it super annoying ...
no, sometimes "eject" button does not make it working - so back to square 1: close the app, disconnect PPK2 from usb, start from the beginning and only then it works
