I see in the documentation that there should be a NRF Debug tab, in the VS Code panel.
Just wondering where I would enable it.
Thanks Marshall
Thanks Marshall
Hi Marshal,
When you say that it still doesn't work, do you mean that the Debug tab doesn't appear? Or is there a build issue? In that case it might be better to open a new ticket, since the original issue is solved.
However, I must say that I just tried building the Asset Tracker v2 application for the nRF9160dk_nRF9160_ns board with debug options enabled, and encountered the following:
Error: Image size (0x67f60) + trailer (0x630) exceeds requested size 0x68000
Is this what you are experiencing? And are you using the same board?
Raoul
Thanks Raoul, I had that same issue, so I went down the rabbit hole of using external flash for the FOTA, to give me more flash for the application.
I now have almost the full 1MB for application code.
I got the NRF-Debug tab working, but not the debug yet.
You can close this ticket.
Thanks
Marshall
Noted, thanks!
