We have a device that acts as both a bluetooth central and a peripheral. The device does not actually have a display or a keyboard, but it has another input port...
I would like to use the BLE5 Advertising Extension to be able to transmit more data during advertisements. The extended advertisement works but, on the other hand...
Hi there,
As I’m currently evaluating our GNSS implementation, I’ve encountered some discrepancies in your documentation.
My inquiry pertains to the optimal implementation...
ive encounter a strange problem, when i try read data from lis3dh that are Y_L X_L Z_L they seem all right. buffer[0] buffer[2] buffer[4] but when it comes to X_H...
I have created an application that initiates a timer for 30 seconds and when it expires it calls an expiry function that switches the system off, if no button is pressed since...
Hello everyone,
I am starting a new project with nRF52833.
I would like to learn more about minimum connections and power configurations on this chip.
Let's say I don...
I need to create a VSCode project for the nRF5340 microcontroller.I use Zephyr OS. The problem is that this microcontroller has 2 cores.
I can create a VSCode project...
I want to add some build information (hard coded) into my binary. Is there any way how I can access the current date/time and maybe the revision number of a SVN repository...
We're using PPP over uart to an Onion Omega 2s running openwrt (linux).
That device does NOT have hardware flow-control.
We're limited also to a baud rate of 250 000 due...
Hi
I need to send data from nRF7002 to external CPU(STM32) use UART protocol, for HW nRF7002 P0.20 connect STM32 RX and RF7002 P0.22 connect STM32 TX, I try to use exercise...
Dear All:
I have followed the procedure as shown in the following to make a Mesh heartbeat application.
I started with the example of ligtht switch client and server for...
Hi guys,
We are building an IoT device on nRF9160
The main protocol is MQTT and we are using AWS IoT Core as a Cloud provider.
MQTT client is based on nRF Connect SDK...
I'm using nRF Connect v2.6.2 with Wireshark (3.6) and it is setup with the nRF sniffer + Nordic network keys configured.
I can decrypt packets from another Zigbee...
We have a custom board based on the nRF52805 that does not have a HFXO or LFXO. We are using NCS 2.6.1.
When the firmware thread is idle, current consumption as measured...
Hii, I'm using the ble_coex sample. My process involves connecting to WiFi, transmitting some data via HTTP, and then disconnecting from WiFi. This operation typically takes...
hello Nordic
i am working with ncs v2.5.0 (with nrf52840 and nrf52832) and trying to migrate to ncs v2.6.1
i have looked at this migration notes and guids:
https://docs...
image1, Flash "nrf802154_sniffer_nrf52840dongle.hex" onto the nrf52840-dongle, only one dongle is inserted but the computer displays two COMs.
If flash the old "nrf802154_sniffer...
Hey, I watched webinar with presentation of NDT and a Lidar as a reference data and if looks quite impressive for high precision calc method. We are using 7002 DK and we would...
I am evaluating the nRF5340 for a potential BLE audio application. I was able to program the kit following the instructions and using the build script (or through...
We have been trying to get MPSL up and running in a BLE and ESB coexistence project but haven't had much luck.
We use an app core image that enables the BLE interface and...
