I am following this page regarding Matter commissioning using the CHIP-TOOL.
I am using Ubuntu as the host for development and running the chip-tool. I want to commission...
We have a device that acts as both a bluetooth central and a peripheral. The device does not actually have a display or a keyboard, but it has another input port...
I would like to use the BLE5 Advertising Extension to be able to transmit more data during advertisements. The extended advertisement works but, on the other hand...
Hi there,
As I’m currently evaluating our GNSS implementation, I’ve encountered some discrepancies in your documentation.
My inquiry pertains to the optimal implementation...
ive encounter a strange problem, when i try read data from lis3dh that are Y_L X_L Z_L they seem all right. buffer[0] buffer[2] buffer[4] but when it comes to X_H...
I have created an application that initiates a timer for 30 seconds and when it expires it calls an expiry function that switches the system off, if no button is pressed since...
Hello everyone,
I am starting a new project with nRF52833.
I would like to learn more about minimum connections and power configurations on this chip.
Let's say I don...
Hi I am using the nrf52832 with zephyr os I am trying to reduce ram usage Lately We implement pairing (encryption) on our devices therefore we increased the CONFIG_BT_RX_STACK_SIZE...
Generate Support Information fails dramatically:
I don't remember how to find the log. How many average users would have the slightest clue!!! Please help.
The other...
I have a product that needs an update. I have always seemed to have issues with DFU updating but it works most of the time. Currently nothing I do seems to be working. I use...
Could you please provide any insights or updates regarding when the Bluetooth Mesh Protocol 1.1 support is expected to be released in Android-nRF-Mesh-Library ?
Any...
I'm trying to test the RGB led on the thingy53.
Using the sample: C:\ncs\v2.6.0\zephyr\samples\basic\rgb_led which gives errors about the devices error: '__device_dts_ord_DT_N_ALIAS_red_pwm_led_P_pwms_IDX_0_PH_ORD...
I want to add some build information (hard coded) into my binary. Is there any way how I can access the current date/time and maybe the revision number of a SVN repository...
We're using PPP over uart to an Onion Omega 2s running openwrt (linux).
That device does NOT have hardware flow-control.
We're limited also to a baud rate of 250 000 due...
Hi
I need to send data from nRF7002 to external CPU(STM32) use UART protocol, for HW nRF7002 P0.20 connect STM32 RX and RF7002 P0.22 connect STM32 TX, I try to use exercise...
Dear All:
I have followed the procedure as shown in the following to make a Mesh heartbeat application.
I started with the example of ligtht switch client and server for...
Hi guys,
We are building an IoT device on nRF9160
The main protocol is MQTT and we are using AWS IoT Core as a Cloud provider.
MQTT client is based on nRF Connect SDK...
I'm using nRF Connect v2.6.2 with Wireshark (3.6) and it is setup with the nRF sniffer + Nordic network keys configured.
I can decrypt packets from another Zigbee...
We have a custom board based on the nRF52805 that does not have a HFXO or LFXO. We are using NCS 2.6.1.
When the firmware thread is idle, current consumption as measured...
