SPI optimization
Hello I want to optimize SPI com as fast I can do: First I am using the fast spi data rate by SPI_FREQUENCY_FREQUENCY_M8 variable and I want to reduce at first the timing between the falling Chip Select edge and my first clock tick, and of course reduce the timing between the last clock tick and the rising Chip Select rising edge ...how can I process? Thanks!
  • I cannot help you with the case you asked, but there is one thing about spi: according to newest product specification (i assume you are using nrf51822) the max frequency is 4M, NOT 8M (although it is defined in SDK). You shouldn't go above 4mbps (i don't know exact reason why it is like that...) Some info here.
  • Hello: there are NORDIC drivers that are good but somewhat heavy in their overhead. The drivers employ software FIFOs, critical sections, etc. If you are sending a small number of bytes, and can wait for the transfer to complete, then it can be much faster to assert chip select, write 2 bytes to the SPI data register (it is double buffered), wait for two bytes to come back, and repeat until your transfer is done; then de-assert CS. Do this with interrupts enabled so that RF processes and timers can continue to run. You can still use the SPI driver init function, but disable ints from the SPI port after initializing, since you will be polling.
    Also, it helps to have a logic analyzer on the SPI port; you can infer from that where the SW delays reside.
  • Hi
    The official driver is interrupt based, and this adds a bit of overhead to each byte transfer. I wrote a polling based driver a while back, and it will be significantly quicker when running at higher bitrates: spi_master_fast.zip
    As mentioned above the SPI master is only ratified up to 4MHz, and the reason for this is that we can not guarantee that the fall/rise times of the GPIO's will be quick enough to support 8MHz operation under all circumstances. By using the SPI at 8MHz you risk getting a system that works fine on one board, but fails on another for instance.
    Under testing I find the library to give you a bitrate of approximately 4.2Mbps at 8MHz, and 3.5Mbps at 4MHz, so you are not gaining a lot of speed by using the 8MHz mode either.
    At 4MHz the driver runs at about 90% of the ideal bitrate, and at 2MHz or lower it runs at 100%.
    Best regards
    Torbjørn
