Connecting the npm1300 to a custom board
Good Day.
I'm trying to run the "npm1300_fuel_gauge" example on a custom board (nRF52840), but I'm getting errors that I don't know how to fix.
The first thing I did was to get the PMIC configuration overlay file (config.overlay) through nPM PowerUP. Then I transferred the code from config.overlay to the custom board device tree file (custom_board_nrf52840.dts). I plan to connect the PMIC via I2C1.
custom_board_nrf52840.dts -->
&i2c1 {
	compatible = "nordic,nrf-twi";
	/* Cannot be used together with spi1. */
	status = "okay";
	pinctrl-0 = <&i2c1_default>;
	pinctrl-1 = <&i2c1_sleep>;
	npm1300_ek_pmic: pmic@6b {
		compatible = "nordic,npm1300";
		reg = <0x6b>;
		npm1300_ek_gpio: gpio-controller {
			compatible = "nordic,npm1300-gpio";
			gpio-controller;
			#gpio-cells = <2>;
			ngpios = <5>;
		npm1300_ek_regulators: regulators {
			compatible = "nordic,npm1300-regulator";
	npm1300_ek_buck1: BUCK1 {
	 regulator-min-microvolt = <1000000>;
	 regulator-max-microvolt = <3300000>;
	 retention-microvolt = <1200000>;
	npm1300_ek_buck2: BUCK2 {
	 retention-microvolt = <1800000>;
	npm1300_ek_ldo1: LDO1 {
	 regulator-initial-mode = <NPM1300_LDSW_MODE_LDSW>;
	 // soft-start-microamp = <10000>;
	npm1300_ek_ldo2: LDO2 {
	npm1300_ek_charger: charger {
	 compatible = "nordic,npm1300-charger";
	 term-microvolt = <4200000>;
	 term-warm-microvolt = <3600000>;
	 // term-current-percent = <10>;
	 current-microamp = <100000>;
	 // trickle-microvolt = <2900000>;
	 dischg-limit-microamp = <1000000>;
	 vbus-limit-microamp = <500000>;
	 thermistor-ohms = <10000>;
	 thermistor-beta = <3380>;
	 charging-enable;
	npm1300_ek_leds: leds {
	 compatible = "nordic,npm1300-led";
	 nordic,led0-mode = "error";
	  nordic,led1-mode = "charging";
	  nordic,led2-mode = "host";
custom_board_nrf52840-pinctrl.dtsi -->
i2c1_default: i2c1_default {
		group1 {
			psels = <NRF_PSEL(TWIM_SDA, 0, 15)>,
				<NRF_PSEL(TWIM_SCL, 0, 17)>;
			bias-pull-up;
	i2c1_sleep: i2c1_sleep {
		group1 {
			low-power-enable;
The following errors occur in the .dts file (see screenshot).
I know that these values should be taken from the "fuel_gauge.h" file, but that doesn't happen for some reason.
I see an error in the prj.conf file too (see screenshot).
When building the project, I see the following information -->
I have not changed the CMakeLists.txt files.
# Copyright (c) 2023 Nordic Semiconductor ASA
cmake_minimum_required(VERSION 3.20.0)
set(SHIELD npm1300_ek)
find_package(Zephyr REQUIRED HINTS $ENV{ZEPHYR_BASE})
project(my_npm1300_fuel_gauge)
add_subdirectory(src)
Can you please tell me where I am making a mistake when transferring this example to my custom board?
Thank you.
  • 1. Measurement time about 50 minutes with an update period of 10 seconds.
    2. I am using a 600 mAh LiPo battery. The technical documentation says:
    Normal Voltage - 3.7V
    Initial Voltage - 3.85-3.95V
    Limited Charge Voltage - 4.2V
    Standart Charging Current - 120 mA (0.2C)
    Standart Charging Time - 6-7 hours
    Standart Charging Method - 0.2C CC current charge to 4.2V, then CV charge till current declines to 0.01C.
    Here is my overlay file with the PMIC charging settings:
    			current-microamp = <120000>;
    			dischg-limit-microamp = <600000>;
    			charging-enable;
    So I need to specify a lower value of V(TERM) than 4.2V (according to the technical documentation of the battery)? What is the usual value of V(TERM) set when charging such batteries?
    Thanks.
  • One other thing I'm curious about...
    When profiling the battery, I set the voltage to 4.2V and the charge current to 120mA. If I now change these parameters (voltage and current) in the overlay file for PMIC, will it affect the algorithm for calculating the battery charge?
    I think V(TERM) is usually between 4.1V and 4.2V, but to be sure I have asked our PMIC experts.
    I do not quite understand why you ask this?
    Myself, I do not know the algorithm, but it would make sense that changing the speed and max for a battery charge, you will affect the algorithm a bit. Like, it should show that you are done sooner if you choose 4.1V instead of 4.2V, no?
  • Hi.
    I got it. Thanks for your answers.
    This ticket can be considered closed.
    They say "The overlay file looks correct for his battery. "
    And they add some bonus info: "Once Vbat reaches 4.2V nPM1300 will keep charging in CV mode (Vbat 4.2V) until charge current drops to 0.1C (10% of Ichg), above the customer battery limit of 0.01C (1% of Ichg)."
    That is what you wanted to know, right?
