Installing the new nRF-Command-Line-Tools_10_4_0_OSX.pkg fails on MacOS (10.14.6). The installer gets to the summary stage and displays an error "please contact the supplier".
Installing the 10.3.0 in the same way succeeds.
Pertti
Pertti
Hi Tesc, nrfjprog still fails on my Mac after installing v10.4.1. The installer works fine, but running nrfjprog goes like this:
$ ./nrfjprog --reset --program /var/folders/tq/c6wwp0ks41zdg9d9w9t5y32w0000gn/T/arduino_build_392483/sketch_oct10a.ino.hex --sectorerase -f nrf52
ERROR: JLinkARM DLL load failed. Try again. If it keeps failing, please
ERROR: reinstall latest JLinkARM from Segger webpage.
I ran the JLink installer in the Nordic package, same effect.
I ran the official JLink installer from SEGGER, same effect.
Any ideas?
What board are you using, and have nrfjprog worked previously with your setup?
It may be a different error from what is indicated in the error message. Can you double check that there is indeed a J-Link programmer connected to the device, that it is an nRF52 device, and that the programmer and device are powered? If an nRF52 DK, there programmer should be on the board.
Try without the "-f nrf52" flag as well. nrfjprog should be able to auto-detect the family, and we have seen in some situations that providing the family flag may fail.
Terje
Hi Terje, here are some screenshots of the JLink apps working with my JLink programmer:
They work, but nrfjprog does not. The device and programmer are powered. I tried removing the flags as you suggested but it didn't help. I then shortened the command to simply erase the chip but the same error was displayed.
What else can I try?
Anders Nelson, I haven't managed to replicate it on my mac, but I think the nrfjprog log may give us a hint of what the issue is. Could you run "nrfjprog -e --log" and check in the log if both the nRF_open_dll and Segger_open_dll load paths match your installation?
The log I got for reference:
2019-Nov-15 10:07:56 -------------------------------------------------------------------------------- 2019-Nov-15 10:07:56 nrfjprog -e --log 2019-Nov-15 10:07:56 nrfjprog version 10.5.0 2019-Nov-15 10:07:56 -------------------------------------------------------------------------------- 2019-Nov-15 10:07:56 nRF_logger_open 2019-Nov-15 10:07:56 nRF_logger_open: nRFJProg logger opened to callback at address 0X1051FFAB0 2019-Nov-15 10:07:56 nRF_open_dll 2019-Nov-15 10:07:56 nRF_open_dll: Load library at "/Applications/Nordic Semiconductor/nrfjprog/libjlinkarm_unknown_nrfjprogdll.dylib". 2019-Nov-15 10:07:56 . nRFXX_logger_open 2019-Nov-15 10:07:56 . nRFXX_logger_open: nRFJProg logger opened to callback at address 0X105284130 2019-Nov-15 10:07:56 . . Segger_logger_open 2019-Nov-15 10:07:56 . . Segger_logger_open: nRFJProg logger opened to callback at address 0X1052B60C0 2019-Nov-15 10:07:56 . . Segger_open_dll 2019-Nov-15 10:07:56 . . Segger_open_dll: Load library at "/Applications/SEGGER/JLink/libjlinkarm.6.54.3.dylib".
When I first ran your suggestion, I got this:
$ nrfjprog -e --log
WARNING: No logging will be possible since nrfjprog.exe has no write permission
WARNING: to the current directory.
I then ran:
$ sudo ./nrfjprog -e --log
Password:
The log is here:
2019-Nov-17 15:10:05 --------------------------------------------------------------------------------
2019-Nov-17 15:10:05 ./nrfjprog -e --log
2019-Nov-17 15:10:05 nrfjprog version 10.4.1
2019-Nov-17 15:10:05 nRF_logger_open
2019-Nov-17 15:10:05 nRF_logger_open: nRFJProg logger opened to callback at address 0X10A16AD30
2019-Nov-17 15:10:05 nRF_open_dll
2019-Nov-17 15:10:05 nRF_open_dll: Load library at "/Applications/Nordic Semiconductor/nrfjprog/libjlinkarm_unknown_nrfjprogdll.dylib".
2019-Nov-17 15:10:05 . nRFXX_logger_open
2019-Nov-17 15:10:05 . nRFXX_logger_open: nRFJProg logger opened to callback at address 0X10A1EED40
2019-Nov-17 15:10:05 . . Segger_logger_open
2019-Nov-17 15:10:05 . . Segger_logger_open: nRFJProg logger opened to callback at address 0X10A221B00
2019-Nov-17 15:10:05 . . Segger_open_dll
2019-Nov-17 15:10:05 . . Segger_open_dll: Load library at "libjlinkarm.dylib".
2019-Nov-17 15:10:05 . . Segger_open_dll: Failed while loading a function from jlinkarm dll.
2019-Nov-17 15:10:05 . nRF_close_dll
2019-Nov-17 15:10:05 . . nRFXX_close_dll
2019-Nov-17 15:10:05 . nRF_close_dll: Freeing Library.
Here is the alias named ""libjlinkarm.dylib":
Any ideas?
