GPIO setup parameters for AoA Antenna switching
I have an issue with getting the I/Os correctly setup for antenna switching.
I am running the radio_test example code with the following modifications.
So far, I have the following code for the GPIO setup:
//Defines are at top of file
#define ANT1 NRF_GPIO_PIN_MAP(0,17)
#define ANT2 NRF_GPIO_PIN_MAP(1,8)
#define ANT3 NRF_GPIO_PIN_MAP(1,7)
#define ANT4 NRF_GPIO_PIN_MAP(1,6)
//other support code
//Pin config
nrf_gpio_pin_clear(ANT1);
nrf_gpio_cfg_output(ANT1);
nrf_gpio_pin_clear(ANT2);
nrf_gpio_cfg_output(ANT2);
nrf_gpio_pin_clear(ANT3);
nrf_gpio_cfg_output(ANT3);
nrf_gpio_pin_clear(ANT4);
nrf_gpio_cfg_output(ANT4);
//DFE pin config
NRF_RADIO->PSEL.DFEGPIO[0] = ANT1; //(P0.17)
NRF_RADIO->PSEL.DFEGPIO[1] = ANT2; //(P1.08)
NRF_RADIO->PSEL.DFEGPIO[2] = ANT3; //(P1.07)
NRF_RADIO->PSEL.DFEGPIO[4] = ANT4; //(P1.06)
NRF_RADIO->SWITCHPATTERN = 1; //Only P0.07 active
NRF_RADIO->SWITCHPATTERN = 2; //Only P1.08 active
NRF_RADIO->SWITCHPATTERN = 4; //Only P1.07 active
NRF_RADIO->SWITCHPATTERN = 8; //Only P1.06 active
NRF_RADIO->DFEMODE = RADIO_DFEMODE_DFEOPMODE_AoA;
NRF_RADIO->DFECTRL1 = 10 << RADIO_DFECTRL1_NUMBEROF8US_Pos |
                       1 << RADIO_DFECTRL1_DFEINEXTENSION_Pos;
Then in the radio_test.c file, I include in the function radio_rx( ...)
uint32_t g_iq_packet[RADIO_MAX_PAYLOAD_LEN];
void radio_rx(....)
//orig example code still exists here, only not shown
    NRF_RADIO->DFEPACKET.PTR = (uint32_t)g_iq_packet;
From a board running the radio_test example, I issue the 'start_tx_modulated_carrier' command the immediately issue the 'start_rx" command on a seperate DK also running the radio_test example with the above modifications.
I expected to see a short duration square wave on each of the antenna GPIO pins, so, 4 square waves cascading in time. However from my logic analyzer capture, you can clearly see that is not the case.
How should I be setting up the config registers to fire each of the pins.  Nothing else is connected to the board except the logic analyzer.
Also, how do I correlate the IQ data from the DFEPACKET.PTR to the specific antenna?
  • Yes, as I wrote, there is continuous sampling after the gap - sample data is present for switching periods too.
  • Hi everyone!
    Glad to see such a lively discussion on direction-finding here on the forum. I just wanted to say that Dmitry is doing a great job explaining direction finding in this post, and can confirm that what he's saying is correct.
    Simon
  • Hi there,
    Sorry for answering here (or joining the discussion), but I can't answer directly for first message in the thread.
    I hope information below will add something to the discussion and improve understanding what is going on about I/Q samples.
    Below is your configuration of radio:
    NRF_RADIO->DFECTRL1 = 3 << RADIO_DFECTRL1_NUMBEROF8US_Pos |
    1 << RADIO_DFECTRL1_DFEINEXTENSION_Pos |
    3 << RADIO_DFECTRL1_TSWITCHSPACING_Pos |
    1 << RADIO_DFECTRL1_TSAMPLESPACINGREF_Pos |
    3 << RADIO_DFECTRL1_TSAMPLESPACING_Pos ;
    That means you have:
    1. 3*8us = 24us for duration of whole CTE
    2. sampling in the reference period is set to be 4us
    3. antennas are switched every 1us (in switching period, after reference period). That meas "switch slot" is 500ns and "sample slot" is 500ns
    4.  sampling in switch period is 1us.
    Total time of CTE is 28 us. Guard time is 4us. That period does not contribute to samples, so we have left 20us of time when some samples are taken.
    Ref. period is 8us long and has 4us sampling time, so it gives us 2 samples.Also it leaves us with 12us for switching period.
    Switching period has set 1us sampling and gives us 12 samples.
    Total 2 samples from ref period + 12 samples from switch period gives 14 samples. The value read from the NRF_RADIO->DFEPACKET.AMOUNT register.
    One more thing related with mapping of antennas to samples. In all diagrams there is an information that after reference period there is a switch-slot/sample-slot pairs sequence. Unfortunately there is a gap. The gap lasts for single switch-slot. So first sample you receive is taken in first sampling-slot. After that each sample is stored in configured delay.
    That does matter for mapping of antennas to samples, especially in case of oversampling.
    Let take for example following settings:
    • NUMBEROF8US=3 ->24us
    • TSWITCHSPACING=2us
    • TSAMPLESPACING=250ns
    • TSAMPLESPACINGREF=250ns
    Number of samples would be: Ref period 8us/0.25 = 32, switch-period 12/0.25=48
    First sample from switch-period would be taken in first sampling slot, so you would have a time delay of 4 samples (1us - swtich slot).
    After that delay you would have samples:
    • 4 samples taken in 1st sampling-slot (antenna 1)
    • 4 samples taken in 2nd switch-slot (antenna 2)
    • 4 samples taken in 2nd sampling-slot (antenna 2)
    • 4 samples taken in 3rd switch-slot (antenna 3)
    Samples taken during switch slot are not reliable so they should be discarded.
    I hope that would help in understanding the topic.
  • Hi Dmitry,
    I'm struggling to understand how you have so many sample points between phase cycles (83-84?). What parameters are you using?
    Cheers
    Pete
  • Hi Pete,
    that diagram is with two antennas, 0.125us sampling interval and 2us/2us sample/switch slots - we have 8us (64 samples) between same points in cycle.
