nRF Cloud Add LTE Device nRR9160-DK, Error Code 40412
Hello, I am receiving error code 40412 when I attempt to activate my nRF9160-DK board. Following other similar DevZone tickets has not resolved my issue. My steps so far and logs are below.
Board: nRF9160-DK
  1. Use Programmer v3.0.0 to erase and write "nrf9160dk_asset_tracker_v2_ltem_2022-02-17_ec486dab.hex" and "mfw_nrf9160_1.3.1.zip" as instructed in Getting started with nRF9160 DK — nRF Connect SDK 1.9.99 documentation (nordicsemi.com)
  2. Activate iBASIS eSIM card on nRF Cloud. I have 10Mb of data remaining and it says "not connected to any device" underneath the SIM card number. Out of the six total nRF9160-DK's and Thingy91's I have, only two SIM cards were not expired. Both were from the Thingy91 boxes (are the iBASIS eSIM's that come with the Thingy91's compatible with the nRF9160-DK's?). I should be receiving replacement SIM cards from iBASIS next week.
  3. Open LTE Link Monitor v2.0.1 to check connectivity
    1. Confirm Security Tag = 16842753 (enter "AT+CFUN=4" then Update Certificates in Certificate Manager tab)
    2. Press board Reset Button
    3. Enter "AT+CFUN?" twice, then all 5 UART/Modem/UICC/LTE/PDN lights are green
    4. Receive LTE Link Monitor window below. Terminal output is at the very bottom.
    5. I see three quick blinks on LED3 and then a short pause, with this cycle repeating continuously.
  4. Attempt to add LTE device in the nRF Cloud
    1. I enter the IMEI in the "Device ID" field and the HWID without colons in the "PIN/HWID" fieild.
    2. Receive error screen below
Am I doing something improperly in the setup process? It seems that it is having trouble connecting to the cloud from the logs below? I don't know if I have provisioned the device yet, but I don't see anything about provisioning in the getting started instructions.
 Thanks.
LTELinkMonitorTerminal.docx
  • In case it helps, I will also provide information here about my attempt to add a Thingy91 using the same SIM card.
    I followed the firmware update instructions here, with the exception of pressing "SW3 while switching SW1 to the ON position" all three times. If I pressed "SW4 while switching SW1 to the ON position" as instructed in the tutorial for the nRF52840 System on Chip (SoC) application, I got the same "no matching trait found" error as this ticket. When I used SW3, the connectivity bridge hex file loaded without error.
    When I attempt to Add LTE Device in nRF Cloud, I seem to get more progress than I saw with the nRF9160-DK. I see the following two screens in succession, with my Thingy91's PIN removed because this is public.
    Hopefully this, in conjunction with the nRF9160-DK information above, helps triangulate the issue.
    Thanks.
    Thingy91_LTELinkInfo.docx
  • UPDATE:
    I moved to a different location and the Thingy91 now connects to nRF Cloud. I can see it reporting temperature, humidity, and location.
    However, I still get the error code 40412 when trying to add the nRF9160-DK.
  • Hi Brown27,
    Cloud you follow Provisioning the nRF Cloud certificate to reprovision your nRF9160DK and follow Getting started with nRF9160 DK again?
    If it still does not work, I am curious to know the hardware version of your nRF9160DK. You are able to output log through the OPEN LOG FILE button on the bottom of the LTE Link Monitor.
    Charlie
