URGENT: Device not found after nrf connect for desktop upgrade
Hi there,
This morning I updated to the latest version of the nrf connect for desktop, along with all the extensions (LTE Link Monitor, Programmer, Toolchain Manager).
However I cannot seem to detect my nrf9160 DK anymore. It does not pop up in the "Select device" on any of the apps. This is extremely frustrating. When we toggle the switch to the nrf52 however, the dk gets detected, but when toggling the switch to the nrf9160 position, we can not detect the DK, and only the J-link pops up within Programmer app:
Unfortunately I do not remember the previous versions of any of the app I had. Please advise a workaround for this ASAP!
  • Hi Charlie,
    We are not able to reprogram the default firmware as described in the link. We are only able to program the nrf52.
    When connecting the DK with the SW10 in the nrf52 position, we connect successfully and the following log appears below:
    11:35:21.564	Using @nordicsemiconductor/nrf-device-lib-js to communicate with target via JLink
    11:35:21.564	JLink OB firmware version J-Link OB-K22-NordicSemi compiled Jul 2 2021 10:44:28
    11:35:21.566	Device family NRF52
    11:35:21.567	Device version NRF52840_xxAA_REV2
    11:35:21.569	Board version PCA10090
    11:35:21.570	Loading readback protection status for Application core
    11:35:22.258	Readback protection status: NRFDL_PROTECTION_STATUS_NONE
    11:35:22.882	Parse memory regions for Application core
    11:35:22.889	Update files regions according to Application core
    11:35:22.889	Parse memory regions for file
    11:35:22.898	Device is loaded and ready for further operation
    When connecting the DK with SW10 in the nrf91 position, we are not able to connect to the devkit at all (the Jlink shows up, but is not seen as the DK):
    When selecting the JLink, we get the following log"
    11:39:02.064	Unsupported device. The detected device could not be recognized as neither JLink device nor Nordic USB device.
    And we are not able to program the device:
  • Hi Frikkie,
    Frikkie Badenhorst said:
    I have connected a different devkit to my PC this morning and everything is working fine, hence the problem should be on the devkit of the original device.
    Do you mean another nRF9160DK?
    Could you share the full log file like in this ticket so I can learn more about your environment?
    We have recently played around with the VDD_IO switch (SW9) on the DK. According to this post this can also cause issues?
    If you suspect something wrong happened during your operation(like an unintentional short circuit), this may cause the chip dead, and you can verify if the chip has the correct power input or unusually high temperature. Its hardware file can be downloaded here: nRF9160 DK - Downloads - nordicsemi.com
    Charlie
  • Hi Charlie,
    Yes
    The chip is not completely dead as I am still able to communicate to it via the external pins.
    Here is the log from Programmer app
    2022-05-18T11:27:09.954Z DEBUG Application data folder: C:\Users\xxxx\AppData\Roaming\nrfconnect\pc-nrfconnect-programmer
    2022-05-18T11:27:10.063Z INFO Using nrf-device-lib-js version: 0.4.5
    2022-05-18T11:27:10.063Z INFO Using nrf-device-lib version: 0.11.0
    2022-05-18T11:27:10.064Z INFO Using nrfjprog DLL version: 10.15.1
    2022-05-18T11:27:10.064Z INFO Using JLink version: JLink_V7.58b
    2022-05-18T11:27:10.145Z DEBUG App pc-nrfconnect-programmer v3.0.0 official
    2022-05-18T11:27:10.145Z DEBUG App path: C:\Users\xxxx\.nrfconnect-apps\node_modules\pc-nrfconnect-programmer
    2022-05-18T11:27:10.145Z DEBUG nRFConnect 3.11.0, required by the app is (^3.10.0)
    2022-05-18T11:27:10.145Z DEBUG nRFConnect path: C:\Users\xxxx\AppData\Local\Programs\nrfconnect\resources\app.asar
    2022-05-18T11:27:10.145Z DEBUG HomeDir: C:\Users\xxxx
    2022-05-18T11:27:10.145Z DEBUG TmpDir: C:\Users\xxxx~1\AppData\Local\Temp
    2022-05-18T11:27:11.470Z DEBUG iface: Ethernet
    2022-05-18T11:27:11.470Z DEBUG IP4:
    2022-05-18T11:27:11.470Z DEBUG IP6:
    2022-05-18T11:27:11.470Z DEBUG MAC: c0:3e:ba:75:cb:15
    2022-05-18T11:27:11.471Z DEBUG Client Id: d50b4c3884463e72376ff503bcfe62405907ae47
    2022-05-18T11:27:11.471Z DEBUG Google Analytics for category pc-nrfconnect-programmer has initialized
    2022-05-18T11:27:14.821Z ERROR Unsupported device.
  • Hi Frikkie,
    Thanks for the information. It seems this chip is partly dead on the programming interface. I have no clue on the cause by far either.
    How do you know the chip is still running when it is powered on? Do you have programmed some firmware before?
    Do you test with some other external connection?
    VDD_IO is set to 3V now?
    Charlie
  • Do you have programmed some firmware before?
    Yes I have programmed it previously with the Serial LTE Modem application and latest modem firmware and everything was working fine.
    I know it is still working as we are able to still send and receive AT commands via the usb cable VCOM port, which is connected to the 9160. We are also able to do this via the external pins connected to the 9160 uart.
    Have tried both 3V and 1.8V
