pc-ble-driver-py setup
I am trying to setup and run the existing scripts, which are part of pc-ble-driver-py.
The following are the steps and tools
1. Installed the pc-ble-driver-py
pip install pc-ble-driver-py
2. Python Installed version
Python 3.9.5
3. Hardware used :
NRF52840 Board
Tried with C:\Python39\Lib\site-packages\pc_ble_driver_py\examples>python serial_port_enum.py NRF52 COM3
the output shows the serial port details and it flashes already build firmware form hex folder.
But when we try the "Advertising" script, getting an error
C:\Python39\Lib\site-packages\pc_ble_driver_py\examples>python advertising.py NRF52 COM3
I have followed the existing thread and found that the baud rate the pc-ble-driver lib uses is 115k2. I have attempted that too. Still get the same error.
Can some one help how to try the existing script.
Note : As of now i am not trying to build the .hex files, just want to try the existing python scripts to make sure my setup is working.
Venkat
    The connectivity_4.1.4_1m_with_s132_5.1.0.hex is the connectivity firmware for using 1m baud on the uart. (The "1m" part fo the name represents the baud.) In other words, the flashed firmware should be correct.
    Since pc-ble-driver is also used for the nRF Connect for Desktop BLE app, you could try launching that one (and accepting programming the connectivity firmware for it) to confirm there is not something else wrong. You can then try the pc-ble-driver-py example, which should work without re-flashing the connectivity firmware (provided the API version used is the same.)
    Terje
  • I have tried flashing the image using nrf connect. Attempted with 115k2 baud rate image (this was given as solution in one of the earlier ticket).
    I have been struggling to bring up this setup.
    Is it possible to provide the working solution as zip file (pc-ble-api-py with correct firmware).
    I am trying this on a windows machine.
  • I have few more doubts
     My hardware works fine when i build an application and tested using NRF Mobile APP.
        Here i assume that the hardware is fine. When it comes to "NRF Soft device build with serialize" there is no response from the softdevice.
       Do we need to have any special jumper settings with "NRF Softdevice serializer"?
  • Thanks. Setup has started working now. After flashing the same image from NRF Connect. with 1m baud rate softdevice controller.
    You may have used a build of only the connectivity firmware, but without the SoftDevice. In that case you would need to program the SoftDevice as well.
    Also, please make sure you erase flash on the device before programming the connectivity firmware, since remaints in flash (especially in the UICR page) may cause issues.
    From your other reply I assume you got it working. The above tips are for if others with similar issues see this thread in the future.
    Terje
