Hi all
(I'm using vs studio code and nrf 2.5.1)
I'm having difficulty disabling the reset function related to the reset pin. I can't use the pin as GPIO and if I put 0V...
Hello Nordic team,
I have a central client BLE application on nrf52840 that performs GATT write on another BLE server device. From BLE specifications and from various posts...
Greetings,
I've been trying to implement a cloud-based solution for Bluetooth Mesh. I've got two questions that I would like to receive some comments on and I would be...
I am evaluating the Thingy 53 + nRF7002 EB for Wifi and Bluetooth scanning.
But depending on which power source I plug the devkit, the wifi interface doesn't set...
We are evaluating a solution for our product where we would like to use
Zephyr RTOS with NCS
nRF52840 + nRF7002 for a combined WiFi/BLE solution. nRF52 will...
I need to run a time-sensitive application on the NRF52840 platform, hence I require disabling and re-enabling the softdevice. After successfully disabling and re-enabling...
Hello!
Do you have a link to a ready-made RF cable which can connect the nrf5340 audio dk SWF output to the nrf21540 EK TRX input?
Henrik
Hi all
I have two products which are very similar. They differ in which pins are mapped to which functions. Let's call the Product A and Product B.
I made a mistake and left two...
Im using nRF Connect for VSCode on a Mac, creating a new application from any of the Matter samples works great with SDK 2.5.2.
However when using SDK 2.6.0 again creating...
I have an issue that I don't know how to debug. I take the latest version of Zigbee Light Bulb example code and the only change I make is add CONFIG_ZIGBEE_CHANNEL_SELECTION_MODE_MULTI...
On a new board based on nRF9160 I am having trouble figuring out how to bring up the board.
I am using Azure IoT hub and can successfully build an application that can connect...
I have a custom board and using an external LTE antenna. Please assist me with the configurations to connect to the internet. I once connected with the following but...
Is it possible to flash the application onto the nRF52840 USB dongle using this method?
https://developer.wirepas.com/support/solutions/articles/77000465762-how-to-flash...
Dear support team, The j-link firmware of my nRF52840-DK v3.0.1 is no longer available. Please provide the firmware of nRF5340 so that I can repair the DK.
BR,
zero
Hello Nordic team,
We recently got the NRF9151-DK and were trting to measure the e-DRX current on the system working on CAT-M1 network. The NRF9151 DK is loaded with Serial LTE Modem application...
I'm testing the IQ feature of the radio test. According to the documentation on https://developer.nordicsemi.com/nRF_Connect_SDK/doc/latest/nrf/samples/wifi/radio_test...
Greetings,
I am attempting to work thru the tutorial exactly per the instructions, and I'm stuck in Lesson 1 at
6. Wait for the device to connect to nRF Cloud.
The Cellular Monitor...
I am developing a custom nrf5340 board design, that is using the BL5340PA external antenna module to implement the nrf5340 chip in the design. The BL5340 module allows all...
