When following the nordic academy instructions for building and flashing to an nRF522832 I ran into some issues. Initially, an error was occuring where "no debuggers...
Development Software: Segger Embedded Studio, nRF5_SDK_17.0.2_d674dde
Project consists of an nRF52DK-based peripheral (remote control) and a custom nRF52832-based central...
I have built a BLE image transfer demo between iPhone 15 and nrf52840 using the following two code:
https://github.com/NordicPlayground/nrf52-ble-image-transfer-demo ...
I am following this page regarding Matter commissioning using the CHIP-TOOL.
I am using Ubuntu as the host for development and running the chip-tool. I want to commission...
We have a device that acts as both a bluetooth central and a peripheral. The device does not actually have a display or a keyboard, but it has another input port...
I would like to use the BLE5 Advertising Extension to be able to transmit more data during advertisements. The extended advertisement works but, on the other hand...
Hi there,
As I’m currently evaluating our GNSS implementation, I’ve encountered some discrepancies in your documentation.
My inquiry pertains to the optimal implementation...
Hello Team,
I am working on nrf9160dk. I have installed the nrf connect for desktop.
I am going through the Quick start . In quick start, in the Select an application...
Hi all,
currently I am trying to send sensor series in bluetooth mesh. I set up the sensor observer (client) example and the sensor server example. I can get the sensor...
I tried the following ticket for out of tree developement ( )
It works,but i cannot able to access the header files of my driver from application, even from driver...
Hi All,
My issue is may connected to
I'm using:
nRF52 DK dev. board
nrf52dk_nrf52832_defconfig
I get communication errors very several times. (More than...
My main goal is to update the firmware over FOTA on a nRF5340, but with a signed firmware update file, and the bootloader verifies it. This is possible with mcuboot and works...
Hi, we are using nRF52832 for our project. SDK version is nRF5_SDK_17.1.0_ddde560. SoftDevice is S132.
The project requires TWI to read data from a sensor and send that...
We are evaluating Nordic BLE chip as part of our future product, and we want to know the maximum throughput between iPhone and Nordic. I am trying to use the below...
hi ,I am using nrf52840dk- nrf52840 board to interface the IMU Sensor using I2C using nrf connect sdk for vs code. But I am facing error:
i'm using the code in ncs/samples...
I have a project with a node that on battery is an LPN node and on USB power the node is a relay & friend node.
As a result, I will need to switch between them...
Hi I am using the nrf52832 with zephyr os I am trying to reduce ram usage Lately We implement pairing (encryption) on our devices therefore we increased the CONFIG_BT_RX_STACK_SIZE...
Generate Support Information fails dramatically:
I don't remember how to find the log. How many average users would have the slightest clue!!! Please help.
The other...
I have a product that needs an update. I have always seemed to have issues with DFU updating but it works most of the time. Currently nothing I do seems to be working. I use...
