Currently, we are using nRF5340 and nRF Connect SDK v2.4.1 for our development. We have implemented the DFU-OTA over SMP-BLE and it is working fine.
We are using the Single...
I want to implement an audio feature via the nRF52, using PWM, I want to play a audio sequence, changing the PWM definitions in a fast rate, and thus would like to use...
I am running the nrf5340_audio application on NCS v2.6.0 in broadcast mode (CONFIG_TRANSPORT_BIS=y) using 2 nRF5340 Audio DK's.
On my gateway, I have encryption...
I am trying to implement LittleFS on 1Gb QSPI NOR flash (W25Q01JV) on the nRF5340.
I am running nRF Connect SDK version 2.4.2 and am using a slightly modified version of...
I am using the nRF52840 as modbus client and experiencing some missing bytes during communication (RTU mode) when using a high baud rate (460800). This tends to happen...
Hi guys, my setup:
- nRf Connect 2.6.0
- VS Code 1.88.1
- Apple Macbook M3 Max (ARM64 CPU)
- nRF52840-DK
I created a new project based on the zephyr button sample...
We have nRF52833 on the custom board, now we want to do DFU over Bluetooth. During my initial research reults with following questions:
If you use 1. " nRF Connect...
So, my issue is weird. Just followed SDK course, installed everything as described, setup, all good, working, updating board etc, couple time freezed but recovered...
I have two products which are very similar. They differ in which pins are mapped to which functions. Let's call the Product A and Product B.
I made a mistake and left two...
I've been working on maximizing BLE throughput between a nrf52840 dongle and a peripheral device. As I've tried to narrow down variables I've ended up with just using two...
I am trying to use PPI / GPIO to measure the 32 kHz clock accuracy for crystal tuning as described in this ticket:
However, the solution points to an example project ( https...
Hi! I am using cellular GNSS example 6 provided by DEV Academy. I am getting compile time duplicate IRQ error message.
This is output of IRQ ERROR message.
Following...
While using Visual Code I have noticed that:
First compile always generates errors, which is fine. The error notifications are persistent even after they have been fixed...
I am developing an app using DFU and that part is going well using the nRF Device Manager app. However, the features using shell to send commands do not work, all say Command...
Hi all, i have some problem while i try to estabilish an LTE connection . I'm using nordic n9160dk. I just search through the site, and i see a lot of topic like this , or...
Hi
I am stuck using a proximus M2M sim card with the AWS-IoT sample. I did get it working with an Ibasis sim card but now I want to use a Proximus M2M sim card but I keep...
I am having problems connecting to LTE and AWS.
We had consultants developing the prototype code, and it worked perfectly on our 3 first hardware revisions (custom product...
