cmake failed
I have downloaded the nrf connect sdk 1.7.1 and want to use the newset version of nordic official sdk. However, I have tried so many times to delete and redownload the sdk, when I build the direction_finding_connectionless_rx or direction_finding_connectionless_tx, it always turns out cmake error.  By the way, I have chosen the right board, which is nrf52833dk-52833, and even the simplest project blinky_pwm wasn't working good. The error seemed the same.
error: Aborting due to Kconfig warnings
CMake Error at C:/Users/Marcous/ncs/v1.7.1/zephyr/cmake/kconfig.cmake:268 (message):
command failed with return code: 1
C:/Users/Marcous/ncs/v1.7.1/zephyr/cmake/app/boilerplate.cmake:554 (include)
C:/Users/Marcous/ncs/v1.7.1/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:24 (include)
C:/Users/Marcous/ncs/v1.7.1/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:35 (include_boilerplate)
CMakeLists.txt:4 (find_package)
error: cmake failed
create_nordic_project.py failed (1)
  • Hi Marte,
    I tried to build the demo in the command line, the error occurred with slight difference:
    Marcous@Marcous-rubbish-g7 MINGW64 /e/ncs/v1.8.0/zephyr/samples/hello_world ((v2.7.0-ncs1))
    $ west build -b nrf52833dk_nrf52833
    Including boilerplate (Zephyr base (cached)): E:/ncs/v1.8.0/zephyr/cmake/app/boilerplate.cmake
    -- Application: E:/ncs/v1.8.0/zephyr/samples/hello_world
    -- Using NCS Toolchain 1.8.0 for building. (E:/ncs/v1.8.0/toolchain/cmake)
    -- Zephyr version: 2.7.0 (E:/ncs/v1.8.0/zephyr), build: v2.7.0-ncs1
    -- Found west (found suitable version "0.12.0", minimum required is "0.7.1")
    -- Board: nrf52833dk_nrf52833
    -- Cache files will be written to: E:/ncs/v1.8.0/zephyr/.cache
    -- Found dtc: E:/ncs/v1.8.0/toolchain/opt/bin/dtc.exe (found suitable version "1.4.7", minimum required is "1.4.6")
    -- Found toolchain: gnuarmemb (E:/ncs/v1.8.0/toolchain/opt)
    -- Found BOARD.dts: E:/ncs/v1.8.0/zephyr/boards/arm/nrf52833dk_nrf52833/nrf52833dk_nrf52833.dts
    -- Generated zephyr.dts: E:/ncs/v1.8.0/zephyr/samples/hello_world/build/zephyr/zephyr.dts
    -- Generated devicetree_unfixed.h: E:/ncs/v1.8.0/zephyr/samples/hello_world/build/zephyr/include/generated/devicetree_unfixed.h
    -- Generated device_extern.h: E:/ncs/v1.8.0/zephyr/samples/hello_world/build/zephyr/include/generated/device_extern.h
    -- Including generated dts.cmake file: E:/ncs/v1.8.0/zephyr/samples/hello_world/build/zephyr/dts.cmake
    warning: the hex symbol NRF_MODEM_LIB_SHMEM_CTRL_SIZE (defined at E:/ncs/v1.8.0/nrf\lib\nrf_modem_lib/Kconfig:109) has a non-hex default NRF_MODEM_SHMEM_CTRL_SIZE (undefined)
    warning: MBEDTLS_SHA1_C (defined at E:/ncs/v1.8.0/nrf/modules/trusted-firmware-m\Kconfig.mbedtls.defconfig:9, E:/ncs/v1.8.0/nrf/modules/trusted-firmware-m\Kconfig.mbedtls_minimal.defconfig:1) defined without a type
    warning: MBEDTLS_TLS_LIBRARY (defined at E:/ncs/v1.8.0/nrf/modules/trusted-firmware-m\Kconfig.mbedtls_minimal.defconfig:9) defined without a type
    warning: MBEDTLS_X509_LIBRARY (defined at E:/ncs/v1.8.0/nrf/modules/trusted-firmware-m\Kconfig.mbedtls_minimal.defconfig:12) defined without a type
    warning: MBEDTLS_ECP_C (defined at E:/ncs/v1.8.0/nrf/modules/trusted-firmware-m\Kconfig.mbedtls_minimal.defconfig:21) defined without a type
    warning: MBEDTLS_CTR_DRBG_C (defined at E:/ncs/v1.8.0/nrf/modules/trusted-firmware-m\Kconfig.mbedtls_minimal.defconfig:24) defined without a type
    warning: MBEDTLS_CMAC_C (defined Parsing E:/ncs/v1.8.0/zephyr/Kconfig
    Loaded configuration 'E:/ncs/v1.8.0/zephyr/boards/arm/nrf52833dk_nrf52833/nrf52833dk_nrf52833_defconfig'
    Merged configuration 'E:/ncs/v1.8.0/zephyr/samples/hello_world/prj.conf'
    at E:/ncs/v1.8.0/nrf/modules/trusted-firmware-m\Kconfig.mbedtls_minimal.defconfig:33) defined without a type
    warning: MBEDTLS_CCM_C (defined at E:/ncs/v1.8.0/nrf/modules/trusted-firmware-m\Kconfig.mbedtls_minimal.defconfig:36) defined without a type
    warning: MBEDTLS_PSA_CRYPTO_STORAGE_C (defined at E:/ncs/v1.8.0/nrf/modules/trusted-firmware-m\Kconfig.mbedtls_minimal.defconfig:48) defined without a type
    warning: <choice MEMFAULT_HTTP_PERIODIC_UPLOAD_CONTEXT> (defined at E:/ncs/v1.8.0/nrf\modules\memfault/Kconfig:166) defined with type unknown
    warning: <choice MEMFAULT_HTTP_PERIODIC_UPLOAD_CONTEXT> (defined at E:/ncs/v1.8.0/nrf\modules\memfault/Kconfig:166) defined without a prompt
    warning: the default selection MEMFAULT_HTTP_PERIODIC_UPLOAD_USE_DEDICATED_WORKQUEUE (undefined) of <choice MEMFAULT_HTTP_PERIODIC_UPLOAD_CONTEXT> (defined at E:/ncs/v1.8.0/nrf\modules\memfault/Kconfig:166) is not contained in the choice
    warning: HAS_NORDIC_DRIVERS (defined at modules\hal_nordic\Kconfig:7) has direct dependencies 0 with value n, but is currently being y-selected by the following symbols:
    - SOC_SERIES_NRF52X (defined at soc/arm/nordic_nrf\nrf52\Kconfig.series:6), with value y, direct dependencies <choice> (value: y), and select condition <choice> (value: y)
    warning: HAS_NRFX (defined at modules\hal_nordic\nrfx/Kconfig:4) has direct dependencies 0 with value n, but is currently being y-selected by the following symbols:
    warning: NRFX_CLOCK (defined at modules\hal_nordic\nrfx/Kconfig:14) has direct dependencies HAS_HW_NRF_CLOCK && HAS_NRFX && 0 with value n, but is currently being y-selected by the following symbols:
    - CLOCK_CONTROL_NRF (defined at drivers/clock_control/Kconfig.nrf:13), with value y, direct dependencies SOC_COMPATIBLE_NRF && CLOCK_CONTROL (value: y), and select condition !CLOCK_CONTROL_NRF_FORCE_ALT && SOC_COMPATIBLE_NRF && CLOCK_CONTROL (value: y)
    warning: NRFX_CLOCK_LFXO_TWO_STAGE_ENABLED (defined at modules\hal_nordic\nrfx/Kconfig:18) has direct dependencies NRFX_CLOCK && HAS_NRFX && 0 with value n, but is currently being y-selected by the following symbols:
    - CLOCK_CONTROL_NRF_K32SRC_XTAL (defined at drivers/clock_control/Kconfig.nrf:36), with value y, direct dependencies <choice CLOCK_CONTROL_NRF_SOURCE> (value: y), and select condition !SOC_SERIES_BSIM_NRFXX && !CLOCK_CONTROL_NRF_FORCE_ALT && <choice CLOCK_CONTROL_NRF_SOURCE> (value: y)
    warning: NRFX_GPIOTE (defined at modules\hal_nordic\nrfx/Kconfig:65) has direct dependencies HAS_HW_NRF_GPIOTE && HAS_NRFX && 0 with value n, but is currently being y-selected by the following symbols:
    - GPIO_NRFX (defined at drivers/gpio/Kconfig.nrfx:4), with value y, direct dependencies SOC_FAMILY_NRF && GPIO (value: y), and select condition SOC_FAMILY_NRF && GPIO (value: y)
    warning: NRFX_PPI (defined at modules\hal_nordic\nrfx/Kconfig:101, drivers/serial/Kconfig.nrfx:371) has direct dependencies (HAS_HW_NRF_PPI && HAS_NRFX && 0) || (HAS_HW_NRF_PPI && (UART_0_NRF_HW_ASYNC || UART_1_NRF_HW_ASYNC || UART_2_NRF_HW_ASYNC || UART_3_NRF_HW_ASYNC) && UART_NRFX && SERIAL) with value n, but is currently being y-selected by the following symbols:
    - UART_ENHANCED_POLL_OUT (defined at drivers/serial/Kconfig.nrfx:388), with value y, direct dependencies (UART_0_ENHANCED_POLL_OUT || UART_1_ENHANCED_POLL_OUT || UART_2_ENHANCED_POLL_OUT || UART_3_ENHANCED_POLL_OUT) && UART_NRFX && SERIAL (value: y), and select condition HAS_HW_NRF_PPI && (UART_0_ENHANCED_POLL_OUT || UART_1_ENHANCED_POLL_OUT || UART_2_ENHANCED_POLL_OUT || UART_3_ENHANCED_POLL_OUT) && UART_NRFX && SERIAL (value: y)
    CMake Error at E:/ncs/v1.8.0/zephyr/cmake/kconfig.cmake:270 (message):
    E:/ncs/v1.8.0/zephyr/cmake/app/boilerplate.cmake:546 (include)
    E:/ncs/v1.8.0/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:24 (include)
    E:/ncs/v1.8.0/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:40 (include_boilerplate)
    CMakeLists.txt:5 (find_package)
    FATAL ERROR: command exited with status 1: 'E:\ncs\v1.8.0\toolchain\opt\bin\cmake.EXE' '-DWEST_PYTHON=E:\ncs\v1.8.0\toolchain\opt\bin\python.exe' '-BE:\ncs\v1.8.0\zephyr\samples\hello_world\build' '-SE:\ncs\v1.8.0\zephyr\samples\hello_world' -GNinja
    I have been trying to reproduce your issue, but so far I have not been able to do so.
    Have you made any changes to any of the files in the SDK? Are you using VPN when downloading the SDK and/or the toolchain through Toolchain Manager?
    Another option is to try to install the SDK manually, by following this guide: Installing manually.
    Marte
  • Hello again,
    I tried to install the SDK without a VPN and anti-virus software. The process of building any single demo sample always failed. I found the file path \modules\hal\nordic is empty, and I guess my situation is similar to the problem https://devzone.nordicsemi.com/f/nordic-q-a/79767/reply-button-not-found. and https://devzone.nordicsemi.com/f/nordic-q-a/79614/error-cmake-failed-andcreate_nordic_project-py-failed-1 That is, my log information with building the sample and information on the command line after typing west update are almost the same
    Since I am in China, I need a VPN to get the access to github, but you mentioned somehow a VPN could affect the downloading. Maybe I should change a VPN?
  • Updates:
    By using VPN and some other command, I can get access to github and using the command "west update", I successfully downloaded the latest SDK of version v1.8.0. I will give the detailed solution in the following days for those who have encoutered the same problem with me.
    I am happy to hear that you managed to download the SDK! We have seen some issues with downloading it in China and when using VPN, so it is good to hear that you found a solution to it.
    Marte
