I have a BLE peripheral project that is based on NCS 2.5.0 using the typical flags for firmware update:
CONFIG_NCS_SAMPLE_MCUMGR_BT_OTA_DFU=y CONFIG_NCS_SAMPLE_MCUMGR_BT_OTA_DFU_SPEEDUP...
I initially tried communicating between the nRF52840-DK and an Adafruit CP2102N - USB to Serial Converter to ensure the peripheral_uart example code on the nRF Connect SDK...
I have two products which are very similar. They differ in which pins are mapped to which functions. Let's call the Product A and Product B.
I made a mistake and left two...
I have purchased two nRF5340 development kits and I am trying to run the peripheral_uart sample using VS Code. I am unable to flash the code to the board. I have tried using...
Hi, I'm currently trying to enable softAP mode and have an HTTP server set up at the same time with the nRF7002DK.
The programs/samples I'm using for each are: HTTP server...
I am developing an app using DFU and that part is going well using the nRF Device Manager app. However, the features using shell to send commands do not work, all say Command...
We have a product in production that we need to update to a newer version of NCS. We currently use the mpsl_radio_notification_cfg_set() interface to drive some custom HW...
Dear support team, The j-link firmware of my nRF52840-DK v3.0.1 is no longer available. Please provide the firmware of nRF5340 so that I can repair the DK.
BR,
zero
I have found that nrf5340 support the usb device function. It can be used for sound card which can receive the audio signal from the PC, and output the mic signal to PC. ...
I am trying to use PPI / GPIO to measure the 32 kHz clock accuracy for crystal tuning as described in this ticket:
However, the solution points to an example project ( https...
hello,
While conducting a CS (Susceptiblility) test, unexpected data was generated from the UART. When I checked the data, the data was output as follows.
Of course, I...
As Pevious ticket: Using NRF24L01+ with pure assembler programing becomes very long, I open a new one as Torbjørn suggested
This is a description about what I have doing...
I know they are older libraries, but I'm still using the Mesh v5.0.0 SDK and nRF5 v17.1.0 for a product that uses a nRF52832 as it's radio. I've been able to implement my...
hi
I am developing using nRF52832 and SDK 17.0.1 (NUS).
I configured paring using BLE Name filter...
I can't find the part that modifies the central response...
hi
I am configuring a product using nRF52832 and NUS.
This time, I'm trying to view BLE wireless data (raw) from central and peripheral, but I can't find a way to do...
Hello, I'm trying to provision nRF9160 DK in nRF Cloud using https://docs.nordicsemi.com/bundle/nrf-cloud/page/SecurityServices/ProvisioningService/ProvisioningOverview.html...
I used this guide to add FOTA over BLE for nRF5340.
https://developer.nordicsemi.com/nRF_Connect_SDK/doc/latest/nrf/device_guides/working_with_nrf/nrf53/nrf5340...
I'm currently working on using a MAX86141 sensor ( datasheet found here ), and I've been running into some issues with communicating with it since this is the first...
