I've just purchased a PPK2 and before I did I check to see if OS X 11.7 is supported - it is ( https://docs.nordicsemi.com/bundle/nrf-connect-desktop/page/os_support.html...
We are using Zephyr with nRF SDK v2.4.1 on nRF52840. We have a secure bootloader following the example. This all works. Inside the bootloader I can inspect the reason for...
When following the nordic academy instructions for building and flashing to an nRF522832 I ran into some issues. Initially, an error was occuring where "no debuggers...
Development Software: Segger Embedded Studio, nRF5_SDK_17.0.2_d674dde
Project consists of an nRF52DK-based peripheral (remote control) and a custom nRF52832-based central...
I have built a BLE image transfer demo between iPhone 15 and nrf52840 using the following two code:
https://github.com/NordicPlayground/nrf52-ble-image-transfer-demo ...
I am following this page regarding Matter commissioning using the CHIP-TOOL.
I am using Ubuntu as the host for development and running the chip-tool. I want to commission...
We have a device that acts as both a bluetooth central and a peripheral. The device does not actually have a display or a keyboard, but it has another input port...
Hi, I have an nRF5340 Audio DK. As the first step, I want to play a simple 1k Hz tone and output it via the AUX jack on the board.
Is there any related sample code for...
I'm doing a project for adding a Bluetooth capability to an embedded Linux device. The Linux master talks to the nRF52840-based Bluetooth module via a dedicated serial (UART...
Hi All,
My issue is may connected to
I'm using:
nRF52 DK dev. board
nrf52dk_nrf52832_defconfig
I get communication errors very several times. (More than...
Hello Team,
I am working on nrf9160dk. I have installed the nrf connect for desktop.
I am going through the Quick start . In quick start, in the Select an application...
I've got a project that I'm going to want to do DFU through the UART, and in order to transfer files in a follow-on activity, I want SMP running in the application. Therefore...
I'm running into issues with programming external boards (an NRF52832_xxAA_REV2, an NRF52810_xxAA_REV2, an NRF51xxx_xxAC_REV3, and an NRF52832_xxAA_REV3) through a custom...
I am reaching out regarding some challenges I've encountered with SPI communication on the nRF7002DK when interfacing with the ETH Wiz Click | Mikroe module and a...
Hi all,
currently I am trying to send sensor series in bluetooth mesh. I set up the sensor observer (client) example and the sensor server example. I can get the sensor...
I tried the following ticket for out of tree developement ( )
It works,but i cannot able to access the header files of my driver from application, even from driver...
My main goal is to update the firmware over FOTA on a nRF5340, but with a signed firmware update file, and the bootloader verifies it. This is possible with mcuboot and works...
Hi, we are using nRF52832 for our project. SDK version is nRF5_SDK_17.1.0_ddde560. SoftDevice is S132.
The project requires TWI to read data from a sensor and send that...
