Hello everyone,
I'm searching for examples or documentation on implementing UART XMODEM on my nRF52840. Could anyone assist me with this?
Thanks
Cedric
TRANSLATE...
Hello I am doing research for my paper which includes using MCPD distance measuring between nrf52840dk boards. I currently use nrf_dm sample to measure the distances. I have...
I am using nrf5340 audio dk for development. I had no trouble with gpio_pin_get_dt() function when reading from sw2. However, once I switched to interrupt. I had to...
nrfutil is generally making command-line activities with NCS easier so I tried updating our Github actions scripts to take advantage
The following script downloads the tool...
I recently bought PPK2.
But am unable to connect it to my Linux PC with Power Profiler v4.1.0.
Below is the log -
08:49:26.328 Error: Failed with exit code 1. Failed...
I am using the nrfconnectSDK v2.4.0 and zephyr
i called the function shown below
int notify_results = bt_gatt_notify_cb(conn, ¶ms);
with params containing
struct...
I am running a copy of the Peripheral_UART application on a nRF52 Dev Board (Segger PCA10040)
The device connects to iOS apps (such as nRF Connect and nRF Toolbox.
I can...
HI Nordic support team.
I have a question relate to TX power in ANT application:
- ANT Tx application using: ant_broadcast ->Tx
- ANT Rx application using: ant_continuous_scanning_controller...
Hi all,
NRF52832 NRF Connect 2.6.0
We need to configure interrupts on a GPIO on both edges. T here are several topics recommending to use GPIO_INT_TRIG_BOTH instead...
Hello everyone,
Thanks
Cedric
TRANSLATE...
I have new Thingy 53. Default Edge Inpulse demo works without any problem. But I have problem with Weather Station demo.
First I tested Zigbee version. After flashing using...
Hi all,
NRF5340 NRF Connect 2.6.0
We would like to perform the following operations on the NRF5340: * Read FICR.DEVICEADDR (BLE random MAC is also fine). * Set the BLE...
I have the peripheral BLE device. It is always had different mac addresses on disconnection/on reboot.
I use my mobile phone with Android OS to initiate pairing...
Below is the log -
struct...
I can...
Hi, I have an issue when I try to install the nRF connect SDK. I am using Linux Fedora 39, trying to isntall SDK v2.5.0. Steps taken so far:
Download and install nRF command...
I'm having problem with SPI devices using nRF Connect SDK 2.6 with a 9160DK. Following lesson 5 in the intermediate course I get BUS FAULTS when the application starts.
