I want to implement an audio feature via the nRF52, using PWM, I want to play a audio sequence, changing the PWM definitions in a fast rate, and thus would like to use...
I am running the nrf5340_audio application on NCS v2.6.0 in broadcast mode (CONFIG_TRANSPORT_BIS=y) using 2 nRF5340 Audio DK's.
On my gateway, I have encryption...
I am trying to implement LittleFS on 1Gb QSPI NOR flash (W25Q01JV) on the nRF5340.
I am running nRF Connect SDK version 2.4.2 and am using a slightly modified version of...
I am using the nRF52840 as modbus client and experiencing some missing bytes during communication (RTU mode) when using a high baud rate (460800). This tends to happen...
Hi guys, my setup:
- nRf Connect 2.6.0
- VS Code 1.88.1
- Apple Macbook M3 Max (ARM64 CPU)
- nRF52840-DK
I created a new project based on the zephyr button sample...
We have nRF52833 on the custom board, now we want to do DFU over Bluetooth. During my initial research reults with following questions:
If you use 1. " nRF Connect...
Device: nRF52840 + nRF21540 Wireshark: v4.2.4 nRF Sniffer: nrf802154_sniffer_nrf52840dongle.hex (downloaded yesterday)
I am trying to evaluate Tx power using the nRf52840...
I am trying to use PPI / GPIO to measure the 32 kHz clock accuracy for crystal tuning as described in this ticket:
However, the solution points to an example project ( https...
Hi! I am using cellular GNSS example 6 provided by DEV Academy. I am getting compile time duplicate IRQ error message.
This is output of IRQ ERROR message.
Following...
While using Visual Code I have noticed that:
First compile always generates errors, which is fine. The error notifications are persistent even after they have been fixed...
I am developing an app using DFU and that part is going well using the nRF Device Manager app. However, the features using shell to send commands do not work, all say Command...
Hi all, i have some problem while i try to estabilish an LTE connection . I'm using nordic n9160dk. I just search through the site, and i see a lot of topic like this , or...
Hi
I am stuck using a proximus M2M sim card with the AWS-IoT sample. I did get it working with an Ibasis sim card but now I want to use a Proximus M2M sim card but I keep...
I am having problems connecting to LTE and AWS.
We had consultants developing the prototype code, and it worked perfectly on our 3 first hardware revisions (custom product...
Hi guys, my setup:
- nRf Connect 2.6.0
- VS Code 1.88.1
- nRF52840-DK
I'm currently working on using a MAX86141 sensor ( datasheet found here ), and I've been running into some issues with communicating with it since this is the first...
Hi, Im working in nrf9160dk, I'm referring aws iot document there they given a code 6278.aws_iot_tutorial.rar there im getting this error .what i need to do?
Executing task...
