Hi all
(I'm using vs studio code and nrf 2.5.1)
I'm having difficulty disabling the reset function related to the reset pin. I can't use the pin as GPIO and if I put 0V...
Hello Nordic team,
I have a central client BLE application on nrf52840 that performs GATT write on another BLE server device. From BLE specifications and from various posts...
Greetings,
I've been trying to implement a cloud-based solution for Bluetooth Mesh. I've got two questions that I would like to receive some comments on and I would be...
I am evaluating the Thingy 53 + nRF7002 EB for Wifi and Bluetooth scanning.
But depending on which power source I plug the devkit, the wifi interface doesn't set...
We are evaluating a solution for our product where we would like to use
Zephyr RTOS with NCS
nRF52840 + nRF7002 for a combined WiFi/BLE solution. nRF52 will...
I need to run a time-sensitive application on the NRF52840 platform, hence I require disabling and re-enabling the softdevice. After successfully disabling and re-enabling...
Hello!
Do you have a link to a ready-made RF cable which can connect the nrf5340 audio dk SWF output to the nrf21540 EK TRX input?
Henrik
I'm testing the IQ feature of the radio test. According to the documentation on https://developer.nordicsemi.com/nRF_Connect_SDK/doc/latest/nrf/samples/wifi/radio_test...
Hello Nordic!
We are currently in the process of incorporating the NRF9160 as the core 4G/GNSS module for our vehicle tracking system. However, based on our experience,...
Hi all
I have two products which are very similar. They differ in which pins are mapped to which functions. Let's call the Product A and Product B.
I made a mistake and left two...
Im using nRF Connect for VSCode on a Mac, creating a new application from any of the Matter samples works great with SDK 2.5.2.
However when using SDK 2.6.0 again creating...
I have an issue that I don't know how to debug. I take the latest version of Zigbee Light Bulb example code and the only change I make is add CONFIG_ZIGBEE_CHANNEL_SELECTION_MODE_MULTI...
On a new board based on nRF9160 I am having trouble figuring out how to bring up the board.
I am using Azure IoT hub and can successfully build an application that can connect...
I have a custom board and using an external LTE antenna. Please assist me with the configurations to connect to the internet. I once connected with the following but...
Is it possible to flash the application onto the nRF52840 USB dongle using this method?
https://developer.wirepas.com/support/solutions/articles/77000465762-how-to-flash...
Dear support team, The j-link firmware of my nRF52840-DK v3.0.1 is no longer available. Please provide the firmware of nRF5340 so that I can repair the DK.
BR,
zero
Hello Nordic team,
We recently got the NRF9151-DK and were trting to measure the e-DRX current on the system working on CAT-M1 network. The NRF9151 DK is loaded with Serial LTE Modem application...
Greetings,
I am attempting to work thru the tutorial exactly per the instructions, and I'm stuck in Lesson 1 at
6. Wait for the device to connect to nRF Cloud.
The Cellular Monitor...
