I'm building a solution in which I would like to rely on the uniqueness of the default UID read when doing NFC tag emulation. I would like to know if the default UIDs...
Hello!
I'm following the NRF Academy Fundamentals course and I am facing an issue with I2C devices.
I have an STM32 board with HAL code (Non-Zephyr) and I am able...
Is it possible to impelement SPI communication without Zephyr driver library?
I want to use an SPI device which is not in the library of the Zephyr but I couldn't...
I have been trying to implement the wifi scan or wifi provisioning code on a module (MS12SF1) which is a combine wifi + ble module
The setup looks like the image shown below...
NRF52840 DK Debug out header using P20 NOT P19 : https://docs.nordicsemi.com/bundle/ug_nrf52840_dk/page/UG/dk/ext_programming_support.html
1) Is SH_VTG needed? In other...
HI!
I am currently working in an audio project using nRF5340 Audio DK. We are using the nRF only to configure Cirrus’ CS47L63. Our audio chain is picking up an external...
Hi
I'm using nrf toolchain/sdk 2.5.2.
Got a strange problem with my QSPI NOR flash interface. when i run flash_erase i get error message "qspi_nor: Failed to schedule...
I am following this page regarding Matter commissioning using the CHIP-TOOL.
I am using Ubuntu as the host for development and running the chip-tool. I want to commission...
Hello.
I'm using the /location/ground-fix endpoint with both lte and wifi data. My understanding is that the endpoint returns the best location it can.
My question is...
I am trying to build my application together with mcuboot, which is done automatically by NCS. To do it as I want to, I need to provide some configs for the mcuboot build...
What is the softdevice provided by Nordic? Does it include the BLE stack? How much memory and which part of the memory this softdevice occupies? Is the BLE radio transceiver...
I have found a bug in SDK v2.6.0 at zephyr/drivers/flash/nrf_qspi_nor.c while erasing the external MX25R64 flash.
Environment:
nRF5340 DK Hardware (MX25R64 external...
I am attempting to work thru the tutorial exactly per the instructions, and I'm stuck in Lesson 1 at
6. Wait for the device to connect to nRF Cloud.
The Cellular Monitor...
hello Nordic
i am working with ncs v2.5.0 (with nrf52840 and nrf52832) and trying to migrate to ncs v2.6.1
i have looked at this migration notes and guids:
https://docs...
I have a nRF52840 DK which is my Distributor and another nRF52840 DK which is my Target in DFU process
I utilize Device Manager app to upload bin file to Distributor...
I am developing UARTE using nRF52840.I use a wire to connect the TX and RX pins together, and send something out the TX.
However, RX did not receive any data, and the interrupt...
Hello!
I'm developing an IoT product using nRF52840 provided by Seeed (Xiao BLE) with a BME280 sensor connected via I2C on a custom PCB, without another peripheral that BME280...
Dear All:
I have followed the procedure as shown in the following to make a Mesh heartbeat application.
I started with the example of ligtht switch client and server for...
