Can a high reflection coefficient (say -1dB instead of wanted <-6dB) damage the LTE transceiver or does it have internal protection?
Is it possible to disable the unwanted...
Hello
I am trying to connect the nRF9160 -DK board to nRFCloud using CoAP protocol. I have written an application for this case. I tested my application with two different...
Hello Team,
I have soldered an MFF2 SIM at U6 location of the NRF9161 DK PCA 10153 ver 0.9.1. I do not insert the plastic sim in J5 position. I am unable to make the MFF2...
We have used hundreds of thousands of Nordics over the last few years and have never actually had any larger problems with programming.
In the last production batch, 200...
Hello Nordic!
We are currently in the process of incorporating the NRF9160 as the core 4G/GNSS module for our vehicle tracking system. However, based on our experience,...
I am developing nrf52832 with nRF5 SDK v17.1.0 and SoftDevice flash_s132_nrf52_7.2.0_softdevice.
The FW uses FreeRTOS. In standby mode of the program, it consume about 37...
Hi! I am using cellular GNSS example 6 provided by DEV Academy. I am getting compile time duplicate IRQ error message.
This is output of IRQ ERROR message.
Following...
Hello!
I'm trying to change the output TX power in the nrf5340 audio dk. I'm setting:
CONFIG_BLE_CONN_TX_POWER_NEG_40DBM=y
CONFIG_BLE_ADV_TX_POWER_NEG_40DBM=y
Hi ,
I'm Using nRFconnect SDKV2.3.0 and in the central device i'm jus trying to read RSSI in connnection Callback but it's always reads as 127.
These are my configurations...
While using Visual Code I have noticed that:
First compile always generates errors, which is fine. The error notifications are persistent even after they have been fixed...
We have a project based on nrf5340 audio demo,Now we upgrade SDK from NCS2.4 to NCS2.6.
But when I built the DFU, I found that FLASH was not enough
I know this problem...
On a new board based on nRF9160 I am having trouble figuring out how to bring up the board.
I am using Azure IoT hub and can successfully build an application that can connect...
I have purchased two nRF5340 development kits and I am trying to run the peripheral_uart sample using VS Code. I am unable to flash the code to the board. I have tried using...
Hi Nordic,
In my project, I have a NRF9160 and a NRF52832 with a ble host/controller stack over SPI HCI on NCS v2.5.2 As soon as I activate the HCI SPI in my project, the...
Hi supporter
SDK version:v2.5.2 IDE: VSCODE computer platform:window10 64 bits
I try to connect nRF5340-DK or nRF7002-DK to extenal board(nRF7002 and nRF5340 combo modules...
Hi Team,
I have a need to use the AS encryption in my application. I tried adding the library files <mbedtls/aes.h> in my NCS SDK but couldnot successfully add it. How do...
So, my issue is weird. Just followed SDK course, installed everything as described, setup, all good, working, updating board etc, couple time freezed but recovered...
Dear Support Team
For the nRF52805, If we use D5 and D6 as the GPIO and use internal 32.768khz, do this affect the stability of the BLE connection? Many thanks.
I am migrating one of Segger Embedded Studio based project to NRF Connect SDK for nrf53 series of board.
I migrated the function that uses GPIOTE feature using relevant...
Hello
Dear support team, The j-link firmware of my nRF52840-DK v3.0.1 is no longer available. Please provide the firmware of nRF5340 so that I can repair the DK.
BR,
zero
