I've been studying the CS47L63 register configuration file ( cs47l63_reg_conf.h ) included with the nr5340_audio application in extremely fine detail, and have discovered...
Hello folks,
I'm working on a device that needs a USB storage connection capability. I have put the "mass" sample into my application, and it works as expected except for...
We are testing four nrf21540dk boards with the onboard antenna, +3dbm, and +5dbm external antennas.
The onboard antennas and the +3dbm external antennas preform similarly...
We wanted to understand better the use of external NOR Flash for nRF9161 applications. For example, in nRF9161-DK, this would be the GD25WB256E chip.
For modem delta fw...
We had tried AT#XSLEEP=1 command in nRF SDK 2.5.0 and it worked. We saw it working for both modem FW 2.0.0 and 2.0.1.
When we updated SDK to 2.6.1 and modem FW 2.0.1, the...
Hello, we have a design that includes nRF9161 for LTE purpose and a separate MCU.
The power sequencing for nRF9161 is as follows
VDD1, VDD2 is supplied with 4.2V
ENABLE...
I'm building a solution in which I would like to rely on the uniqueness of the default UID read when doing NFC tag emulation. I would like to know if the default UIDs...
I have a same problem as in below link, my nRF52840 Dongle is programmed as nRF Sniffer using nRF Connect Desktop - Programmer. But I would like to revert back to the original...
We are trying to build an qspi external flash application with the nrf5340dk. However, I noticed, that when going from ncs v2.4.2 to v2.5.2, the qspi_nor flash driver no longer...
I am trying to run the asset tracker v2.
I have completed the setup steps and configuration.
Can you please let me know what to do ?
I have read that the -128...
Hi
I am using nrf connect to program my nrf52840 development kit. To use system view we need J-link but for snap-short of task synchronization we can use RAM as backend...
Using the nrf Connect Programmamer v4.2.0, I get the following error when connecting to J-Link on some of my custom boards (about 30%):
When I run nrfjprog...
Hello folks,
I'm trying to sample few sensors at 2 kHz with a timer. Even though nrf5340 application core can run at 128 MHz, I couldn't achieve exact 500 us delay with timer.
We have a device that acts as both a bluetooth central and a peripheral. The device does not actually have a display or a keyboard, but it has another input port...
I am following this page regarding Matter commissioning using the CHIP-TOOL.
I am using Ubuntu as the host for development and running the chip-tool. I want to commission...
ENABLE...
NCS v2.6.0
nRF52840
I'm trying to use GPIOTE + PPI to increment a TIMER in counter mode. Then when the counter reaches a compare value in channel 0 it triggers...
