I just started working with ZBus and even though Zephyr's documentation states that " Publishing, reading, claiming, and finishing are available in all RTOS thread contexts...
I was trying to decrypt an encrypted message I send form my phone using the psa/crypto library. I managed to send the encrypted message over to my board by ble correctly...
A current project of ours includes a nRF9151 and I stumbled across a contradiction in the datasheet (nRF9151 Objective Product Spec v0.7).
In Table 55, pins 112 and...
Hello Nordic!
We are currently in the process of incorporating the NRF9160 as the core 4G/GNSS module for our vehicle tracking system. However, based on our experience,...
Hi! I am using cellular GNSS example 6 provided by DEV Academy. I am getting compile time duplicate IRQ error message.
This is output of IRQ ERROR message.
Following...
I have a BLE peripheral project that is based on NCS 2.5.0 using the typical flags for firmware update:
CONFIG_NCS_SAMPLE_MCUMGR_BT_OTA_DFU=y CONFIG_NCS_SAMPLE_MCUMGR_BT_OTA_DFU_SPEEDUP...
I have two products which are very similar. They differ in which pins are mapped to which functions. Let's call the Product A and Product B.
I made a mistake and left two...
I have been working with some code for a nrf5340 DK and now want to add a custom board to the project as an additional build configuration, but I need to now pull out configurations...
We have used hundreds of thousands of Nordics over the last few years and have never actually had any larger problems with programming.
In the last production batch, 200...
we are facing an issue of loading the application written with nRF Connect SDK to the nRF52840 which has nRF5 SDK's secure bootloader. Update process should be performed...
Our product need CE approval. For that the radio must be set into an active transmitting mode among other. I have read the radio_test example is a good option.
To get a...
I am developing an app using DFU and that part is going well using the nRF Device Manager app. However, the features using shell to send commands do not work, all say Command...
I am trying to use PPI / GPIO to measure the 32 kHz clock accuracy for crystal tuning as described in this ticket:
However, the solution points to an example project ( https...
I have two nRF52840 devices one peripheral and one central. Both devices feature the Nordic Uart Service. They are based on ble_app_uart example and e nrf52-ble-app...
Hi everyone,
i just started trying to work with ZBUS, i've created two threads that one publishes to a channel and the other what reads the value from the channel and sends...
I am attempting to work thru the tutorial exactly per the instructions, and I'm stuck in Lesson 1 at
6. Wait for the device to connect to nRF Cloud.
The Cellular Monitor...
We are currently working with Zigbee coordinator sample SDK version 2.1.0. When attempting to write data to a unavailable device, the stack sends an unimplemented signal four...
Abnormal power consumption is observed after using sd_temp_get to retrieve the MCU temperature on the nrf52840.
**SDK Ver: SDK17
**Source Code:
temperature.c
float...
Greetings.
I have a question that I hope someone can help me with. Recently, I've been working with the HX711 sensor to weigh with a certain precision. I have a custom board...
Hello
I am trying to connect the nRF9160 -DK board to nRFCloud using CoAP protocol. I have written an application for this case. I tested my application with two different...
On a new board based on nRF9160 I am having trouble figuring out how to bring up the board.
I am using Azure IoT hub and can successfully build an application that can connect...
