I'm trying to erase/read an external flash ( MX25L6433F) connected to an nrf52840 using nrfjprog. I've created a .toml file for the configuration, see attached. The...
What is the softdevice provided by Nordic? Does it include the BLE stack? How much memory and which part of the memory this softdevice occupies? Is the BLE radio transceiver...
We are using Zephyr with nRF SDK v2.4.1 on nRF52840. We have a secure bootloader following the example. This all works. Inside the bootloader I can inspect the reason for...
When following the nordic academy instructions for building and flashing to an nRF522832 I ran into some issues. Initially, an error was occuring where "no debuggers...
Development Software: Segger Embedded Studio, nRF5_SDK_17.0.2_d674dde
Project consists of an nRF52DK-based peripheral (remote control) and a custom nRF52832-based central...
I am following this page regarding Matter commissioning using the CHIP-TOOL.
I am using Ubuntu as the host for development and running the chip-tool. I want to commission...
We have a device that acts as both a bluetooth central and a peripheral. The device does not actually have a display or a keyboard, but it has another input port...
we are facing an issue of loading the application written with nRF Connect SDK to the nRF52840 which has nRF5 SDK's secure bootloader. Update process should be performed...
Hello Team,
I am working on nrf9160dk. I have installed the nrf connect for desktop.
I am going through the Quick start . In quick start, in the Select an application...
Is it possible to use configure MPSL to use multiple FEMs? I see that you can configure it to use a simple GPIO interface, which works fine for a single FEM with fixed gain...
Generate Support Information fails dramatically:
I don't remember how to find the log. How many average users would have the slightest clue!!! Please help.
The other...
I have a product that needs an update. I have always seemed to have issues with DFU updating but it works most of the time. Currently nothing I do seems to be working. I use...
Hi
This is my first time using nRF connect and Visual studio but I have been following through first the Fundamentals course on the Dev Academy using the nRF52840 DK with...
I have new Thingy 53. Default Edge Inpulse demo works without any problem. But I have problem with Weather Station demo.
First I tested Zigbee version. After flashing using...
I have built a BLE image transfer demo between iPhone 15 and nrf52840 using the following two code:
https://github.com/NordicPlayground/nrf52-ble-image-transfer-demo ...
I am trying to run the asset tracker v2.
I have completed the setup steps and configuration.
Can you please let me know what to do ?
I have read that the -128...
I want to implement a pwm output signal on a particular pin of the nRF52840DK working with the latest nRF Connect for VS Code. What would be the recommended way to setup...
Hello
I am trying to connect the nRF9160 -DK board to nRFCloud using CoAP protocol. I have written an application for this case. I tested my application with two different...
I've just purchased a PPK2 and before I did I check to see if OS X 11.7 is supported - it is ( https://docs.nordicsemi.com/bundle/nrf-connect-desktop/page/os_support.html...
Hello, and thank you for your time. We have designed an NPM1100 into a product, and are unclear on if the behaviour of the charge pin is correct (nor indeed what exactly is...
