I just started working with ZBus and even though Zephyr's documentation states that " Publishing, reading, claiming, and finishing are available in all RTOS thread contexts...
I was trying to decrypt an encrypted message I send form my phone using the psa/crypto library. I managed to send the encrypted message over to my board by ble correctly...
A current project of ours includes a nRF9151 and I stumbled across a contradiction in the datasheet (nRF9151 Objective Product Spec v0.7).
In Table 55, pins 112 and...
We have used hundreds of thousands of Nordics over the last few years and have never actually had any larger problems with programming.
In the last production batch, 200...
Hello Nordic!
We are currently in the process of incorporating the NRF9160 as the core 4G/GNSS module for our vehicle tracking system. However, based on our experience,...
Hi! I am using cellular GNSS example 6 provided by DEV Academy. I am getting compile time duplicate IRQ error message.
This is output of IRQ ERROR message.
Following...
I have a BLE peripheral project that is based on NCS 2.5.0 using the typical flags for firmware update:
CONFIG_NCS_SAMPLE_MCUMGR_BT_OTA_DFU=y CONFIG_NCS_SAMPLE_MCUMGR_BT_OTA_DFU_SPEEDUP...
Hi everyone,
i just started trying to work with ZBUS, i've created two threads that one publishes to a channel and the other what reads the value from the channel and sends...
I am attempting to work thru the tutorial exactly per the instructions, and I'm stuck in Lesson 1 at
6. Wait for the device to connect to nRF Cloud.
The Cellular Monitor...
We are currently working with Zigbee coordinator sample SDK version 2.1.0. When attempting to write data to a unavailable device, the stack sends an unimplemented signal four...
Abnormal power consumption is observed after using sd_temp_get to retrieve the MCU temperature on the nrf52840.
**SDK Ver: SDK17
**Source Code:
temperature.c
float...
Greetings.
I have a question that I hope someone can help me with. Recently, I've been working with the HX711 sensor to weigh with a certain precision. I have a custom board...
Hello
I am trying to connect the nRF9160 -DK board to nRFCloud using CoAP protocol. I have written an application for this case. I tested my application with two different...
On a new board based on nRF9160 I am having trouble figuring out how to bring up the board.
I am using Azure IoT hub and can successfully build an application that can connect...
Dear Support Team,
Hardware : nRF5340 Custom board
Software : nRF Connect SDK v2.2.0
I have implemented OTA FW update for nRF5340. I've used multi-image simultaneous...
I am developing nrf52832 with nRF5 SDK v17.1.0 and SoftDevice flash_s132_nrf52_7.2.0_softdevice.
The FW uses FreeRTOS. In standby mode of the program, it consume about 37...
I'm trying to merge together a couple of sample projects to make a prototype (in particular, the LTE-BLE gateway, and AWS-IoT samples) - to run on the nRF 9160DK...
We're developing an LwM2M application based on the lwm2m client sample with the goal of sending data to ThingsBoard as our main telemetry platform.
The Application in based...
I have two nRF52840 devices one peripheral and one central. Both devices feature the Nordic Uart Service. They are based on ble_app_uart example and e nrf52-ble-app...
