We are evaluating a solution for our product where we would like to use
Zephyr RTOS with NCS
nRF52840 + nRF7002 for a combined WiFi/BLE solution. nRF52 will...
I need to run a time-sensitive application on the NRF52840 platform, hence I require disabling and re-enabling the softdevice. After successfully disabling and re-enabling...
Hello!
Do you have a link to a ready-made RF cable which can connect the nrf5340 audio dk SWF output to the nrf21540 EK TRX input?
Henrik
I just started working with ZBus and even though Zephyr's documentation states that " Publishing, reading, claiming, and finishing are available in all RTOS thread contexts...
I was trying to decrypt an encrypted message I send form my phone using the psa/crypto library. I managed to send the encrypted message over to my board by ble correctly...
A current project of ours includes a nRF9151 and I stumbled across a contradiction in the datasheet (nRF9151 Objective Product Spec v0.7).
In Table 55, pins 112 and...
Hello Nordic!
We are currently in the process of incorporating the NRF9160 as the core 4G/GNSS module for our vehicle tracking system. However, based on our experience,...
I have found that nrf5340 support the usb device function. It can be used for sound card which can receive the audio signal from the PC, and output the mic signal to PC. ...
I have a custom board and using an external LTE antenna. Please assist me with the configurations to connect to the internet. I once connected with the following but...
Hi there
I'm working on nRF5340 chip and looking for a way to preserve the factory data that is saved in factory_data region. I tried playing around with the factory data...
Hi! I am using cellular GNSS example 6 provided by DEV Academy. I am getting compile time duplicate IRQ error message.
This is output of IRQ ERROR message.
Following...
I have DK of nRF5340, I want to get started with it and create the development env, as well as I need to measure the sleep current for this module?
Any quick tutorial which...
I am developing a custom nrf5340 board design, that is using the BL5340PA external antenna module to implement the nrf5340 chip in the design. The BL5340 module allows all...
Hi Team, I have 1 nRF5340 Audio DK. With the steps mentioned in below links, I configured Json file to Gateway and I'm able to achieve it. ( https://developer.nordicsemi.com...
Hi everyone,
I am planning to use the cadence/publish interval property within a mesh network. I can not find any examples on how to use it. I know I can set it in the nrf...
Is there any strategy/method or example of how to perform (non Nordic) MCU to (non Nordic) MCU firmware update via UART ? We want the non Nordic chip to do the firmware...
Hello everyone,
I'm working on a Zigbee project that has the Thingy:53 as an end node. The program of the Thingy is a variation of the Zigbee Weather Station .
I'm measuring...
Hello!
Henrik
I have been working with some code for a nrf5340 DK and now want to add a custom board to the project as an additional build configuration, but I need to now pull out configurations...
We have used hundreds of thousands of Nordics over the last few years and have never actually had any larger problems with programming.
In the last production batch, 200...
