What is the softdevice provided by Nordic? Does it include the BLE stack? How much memory and which part of the memory this softdevice occupies? Is the BLE radio transceiver...
We are using Zephyr with nRF SDK v2.4.1 on nRF52840. We have a secure bootloader following the example. This all works. Inside the bootloader I can inspect the reason for...
When following the nordic academy instructions for building and flashing to an nRF522832 I ran into some issues. Initially, an error was occuring where "no debuggers...
Development Software: Segger Embedded Studio, nRF5_SDK_17.0.2_d674dde
Project consists of an nRF52DK-based peripheral (remote control) and a custom nRF52832-based central...
I am following this page regarding Matter commissioning using the CHIP-TOOL.
I am using Ubuntu as the host for development and running the chip-tool. I want to commission...
We have a device that acts as both a bluetooth central and a peripheral. The device does not actually have a display or a keyboard, but it has another input port...
I would like to use the BLE5 Advertising Extension to be able to transmit more data during advertisements. The extended advertisement works but, on the other hand...
I have a product that needs an update. I have always seemed to have issues with DFU updating but it works most of the time. Currently nothing I do seems to be working. I use...
Hi
This is my first time using nRF connect and Visual studio but I have been following through first the Fundamentals course on the Dev Academy using the nRF52840 DK with...
I have new Thingy 53. Default Edge Inpulse demo works without any problem. But I have problem with Weather Station demo.
First I tested Zigbee version. After flashing using...
I have built a BLE image transfer demo between iPhone 15 and nrf52840 using the following two code:
https://github.com/NordicPlayground/nrf52-ble-image-transfer-demo ...
I am trying to run the asset tracker v2.
I have completed the setup steps and configuration.
Can you please let me know what to do ?
I have read that the -128...
Generate Support Information fails dramatically:
I don't remember how to find the log. How many average users would have the slightest clue!!! Please help.
The other...
I want to implement a pwm output signal on a particular pin of the nRF52840DK working with the latest nRF Connect for VS Code. What would be the recommended way to setup...
Hello
I am trying to connect the nRF9160 -DK board to nRFCloud using CoAP protocol. I have written an application for this case. I tested my application with two different...
I've just purchased a PPK2 and before I did I check to see if OS X 11.7 is supported - it is ( https://docs.nordicsemi.com/bundle/nrf-connect-desktop/page/os_support.html...
Hello, and thank you for your time. We have designed an NPM1100 into a product, and are unclear on if the behaviour of the charge pin is correct (nor indeed what exactly is...
I have a custom PCBA with which has the flow of:
- Boot
- Advertise some temperature data read from TWI with a 5 second timeout using `ble_adv_fast_timeout`.
- I then...
I have been using the nrf connect mobile app (on android) to assist in debugging and testing of BLE applications before. Now I am working on a peripheral that has some custom...
Hi, I have an nRF5340 Audio DK. As the first step, I want to play a simple 1k Hz tone and output it via the AUX jack on the board.
Is there any related sample code for...
I'm doing a project for adding a Bluetooth capability to an embedded Linux device. The Linux master talks to the nRF52840-based Bluetooth module via a dedicated serial (UART...
